Display Choice for HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-06-2010, 11:05 AM - Thread Starter
slader99's Avatar
I've built myself a nice, silent, HTPC. In addition to a media center the intent is also to use the box as a replacement for all the other PC's we currently have (word processing ect). As such its extremely important to me how my HTPC HDMI out looks on the set.
Space is a constraint in the room - looking at either a 40-42 inch set. I've narrowed it down to two TV's I'm interested in. I've hooked my HTPC up to both at different friends houses (unfortunately not side by side).
LCD _> Aquos LC40E77U
PLASMA _> TCP42G15
I was very happy with the picture on both these sets without any tweaking of settings. I'm not convinced the plasma will be worth the extra 2hun.... I'm hoping that the experts in the forum can help me decide between these sets (and/or offer another alternative in this size and price range).
I'd be very appreciative if anyone who is using one of the sets above in a HTPC situation can weigh in.
Cheers,
Colin
i7 920 @ 3.15GHz, Asus PT6, Radeon 5850, LG CH08.
slader99 is offline
post #2 of 9 Old 02-06-2010, 01:14 PM
Nielo TM's Avatar
I would avoid Sharp ASV panels due to the delta pixel architecture. For text based content, it's better to opt for a strip pixel instead.
As for PDP, it will no doubt produce excellent image (especially after ICC profiling), but I'm not sure about viewing text as it may cause eyestrain.
Nielo TM is offline
post #3 of 9 Old 02-06-2010, 01:36 PM - Thread Starter
slader99's Avatar
Nielo,
Appreciate the response. It sounds like the LCD I am considering might not be my best bet (due to delta vs strip pixel arrangement). I will read up more on this as I am not familiar with these terms as of yet - would you be able to suggest an alternate LCD with a similar price tag?
Colin
slader99 is offline
post #4 of 9 Old 02-06-2010, 01:45 PM
Nielo TM's Avatar
I'm in the UK, so I won't be much of help in that regard.
However, if you can quote your budget, I could search around some sites (but I'm only aware of Walmart, BB and NewEgg)
As for Delta vs Strip, you can find more information about via the link below
http://miyahan.com/me/report/compute..._SHARP_AQUOS_P
Nielo TM is offline
post #5 of 9 Old 02-06-2010, 01:55 PM - Thread Starter
slader99's Avatar
Budget is less than $1100 bucks. I've been using amazon.com for getting prices - I will use that to get a local store to match.
Thanks for the link - Im reading up on that new information as well as the guide in your sig.
Does moving to a strip based pixel mean I take a bit of a hit in all departments other than text content?
Cheers,
Colin
slader99 is offline
post #6 of 9 Old 02-06-2010, 02:32 PM
Nielo TM's Avatar
Strip addressing provides better definition by default compared to delta.
As for the set, Samsung series 5 and 6 are very good and they accept number of VESA timings via HDMI/DVI.
However, in the UK, the entire series 6 have static 10-bit processing which results in higher input lag. Hopefully the new models feature dual processing akin to the Sharp LE700 series.
In the US, I believe certain series 6 have identical lag to series 5, but I'm sure of the model number.
Hopefully, some one here can provide such information in detail.
Nielo TM is offline
post #7 of 9 Old 02-07-2010, 01:40 PM - Thread Starter
slader99's Avatar
I've found the samsung LN40B610 available at a reasonable price.
I still am struggling with the LCD vs Plasma decision for this application. Is input lag a reasonable sacrifice in order to get 24p support?
Once again I would like to request that someone with a HTPC hooked up to their Sharp LC40E77U \\ Samsung LN40B610 \\ Panasonic TCP42G15 weigh in.
slader99 is offline
post #8 of 9 Old 02-08-2010, 08:40 PM - Thread Starter
slader99's Avatar
bump.
I'd love some feedback guys - if I could push past this in-decision I would go out and upgrade my 20" tube this week!
slader99 is offline
post #9 of 9 Old 02-08-2010, 08:58 PM
Nielo TM's Avatar
There's no need to sacrifice one over the other
Nielo TM is offline
Reply OLED Technology and Flat Panels General
