Are all TV mounts created equally? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-23-2011, 10:17 PM - Thread Starter
blackrain's Avatar
Quoted: 20 Post(s)
What do you think of this TV mount?
http://www.amazon.com/gp/product/B00...=5336055023-20
Monoprice seems to be a little cheaper at $10-$20 + shipping, but not sure if the monoprice mounts are reliable. I don't understand how Sanus mounts are $100+ and this amazon VideoSecu mount retails for $159, but the monoprice mounts are less than $20. Are they complete garbage?
By the way, as far as my needs go, I am looking for a fairly straightforward mount with the ability to tilt. Swivel would be a plus. But don't need fully articulating. This will go on plain old drywall.
blackrain is offline
post #2 of 9 Old 06-23-2011, 10:19 PM
powertoold's Avatar
No, Monoprice mounts are perfectly adequate. The higher quality ones may provide better instructions / customer support.
powertoold is offline
post #3 of 9 Old 06-24-2011, 12:08 AM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
Monoprice mounts are lacking nothing. Solid and well built. If you find the instructions lacking you certainly should not be mounting your own TV.
Buy Monoprice with 100% confidence.
Matt L is offline
post #4 of 9 Old 06-24-2011, 02:49 PM
JeffreySmith's Avatar
Try this one, good mount and speaking from experience good tech support as well.
http://www.av-express.com/AV-Catalog...-inch-104-1120
JeffreySmith is offline
post #5 of 9 Old 06-24-2011, 07:18 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
No. Most are created in China, so quality can and will vary...
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 9 Old 06-27-2011, 01:02 PM
agogley's Avatar
Quoted: 56 Post(s)
Liked: 24
True enough, but most mounts are conceptually the same. A piece of metal bolted to the wall with two rails connected to the TV that hang on aforementioned piece of metal. So long as the metal isn't aluminum foil, it's hard to justify paying $100 more for a mount with a name brand (unless it has some other feature you like).
agogley is offline
post #7 of 9 Old 06-27-2011, 10:41 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Do pay enough to get decent welds though...MonoPrice seems to have enough quality.
olyteddy is offline
post #8 of 9 Old 06-27-2011, 11:39 PM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
I've installed 5 or 6 mounts form Monoprice, all were fine quality wise...
Matt L is offline
post #9 of 9 Old 06-27-2011, 11:50 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
No. But the real question you want to ask is, a $120 mount is 5x better than a $20 mount?
My company bought an expensive mount, came with complete instructions, clear english, well "presented" product.
I bought a cheap Monoprice at home, soft metal, I was able to quite easily dremel it to fit (a good thing otherwise I'd be going %&$^@ with a tough metal), Chin-english instructions, but meh I figure $80 cheaper I'd put up with a little cheapi-ness for something that nobody is going to see once mounted. Locking mechanism funky, I had to run out to the hardware store to buy two longer screws.
Bottom line: Somebody else's $, I buy the expensive one. My money: Monoprice.
MrBobb is offline
Reply OLED Technology and Flat Panels General
