Best LCD/LED 50-60 inch for less than $900 - AVS Forum | Home Theater Discussions And Reviews
Old 02-27-2012, 01:59 AM - Thread Starter
Undeadpaladin's Avatar
My old rear projection LCD is about to go and I'd like to replace it on a budget of about $900 or less. Not interested in Plasma.
- Could care less about 3D
- Prefer LED due to reduced energy usage
- Don't care about Apps or any of that extra stuff
- MOST IMPORTANT, It must have an ability to turn that "smooth motion" stuff off, I think it is the most distracting thing watching a movie imho.
So just a cut and dry good old HDTV with no fluff or smoothing action. Let me know some ideas. Thanks!
Undeadpaladin is offline
Old 02-28-2012, 12:44 AM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
Good luck.....
Matt L is offline
Old 02-28-2012, 05:12 AM
pokekevin's Avatar
Liked: 102
Try checking out costco?
pokekevin is offline
Old 03-04-2012, 12:26 PM
stopdrpnro's Avatar
Quoted: 14 Post(s)
I know you said you'd like led but if you can afford $900 you can afford the extra $12/ yr it'd cost to run a plasma instead. pn51d550 is a great choice for well under $900. That would give you 3d and a much better picture than 98% of the leds in that price range just my 2 cents
stopdrpnro is offline
Old 03-04-2012, 09:46 PM
Tracydick's Avatar
That is a good option I posted in another thread that last years best buy 55" LW5600 are $900 on sale now.
Plasma if you have a bright room might not be an option and if your that worried about power check bestbuy I know they don't to rain checks so if they don't have any more stock your SOL.
Tracydick is offline
