PN59D550 or REIMBURSEMENT? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-23-2012, 08:02 AM - Thread Starter
saiwhsiwi's Avatar
Two years ago I purchased a Samsung PN58C8000 with a 3 year warranty. Recently I've noticed a 'bright' stripe running across the top of the screen. This TV was serviced before and now warranty company claims repair will exceed value. So instead they are offering me a replacement TV - PN59D550 - or a check for $1295.00. Would like to get some suggestions as to which option would be best. Reviews I've seen for the D550 are mostly favorable, though some complain of a humming sound.
saiwhsiwi is offline
post #2 of 2 Old 04-26-2012, 10:43 AM
audio1der's Avatar
Tough call; I just installed my PN64D550, and can't imagine the picture getting any better; it's stunning. that said, I didn't want the features of the upper-scale models such as the newer 8000's, and the hum you mentioned IS there, and is grating on my nerves. It eminates from the front of the panel, and is clearly audible at low-normal listening levels. I don't know if that is also the case for higher end, new Samsungs.
If you love the 8000 and can make use of its features, I would take the $ and put it towards a higher end model.
audio1der is offline
Reply OLED Technology and Flat Panels General
Samsung Pn59d550 59 Inch 1080p 600hz 3d Plasma Hdtv
