Looking for a simple slim line TV mount that has ability to pull out 1-2" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-24-2012, 11:38 AM - Thread Starter
.Capstone's Avatar
I'm looking for a mount that holds the TV approx .5" to 1" from the wall, but can pull straight out (only needs to pull out 1" - 2") and then be pushed back in to .5" - 1" from the wall. My TV is 58 inches and is plasma (weighs more than LED/LCD). I don't care about swivel capability or tilt capability.
Any suggestions?
We're putting travertine around the column the TV hangs. We're going to line the TV with the travertine and rather than trying to buy a mount that holds the TV the exact depth from the wall (with the travertine depth added), I'd like to find one with a little "play". Basically can go from .5" to 2". This way I've got some wiggle room. Anything like this out there?
.Capstone is offline
post #2 of 3 Old 04-24-2012, 01:22 PM
Jim McC's Avatar
Quoted: 188 Post(s)
Liked: 66
I don't know, but check Monoprice.com
Jim McC is offline
post #3 of 3 Old 06-15-2012, 04:08 AM
wallmountworld's Avatar
Have you looked into a recessed wall mount box. Chief makes an in-wall box that will have the back of your TV just .6" from the wall. It is a full motion mount that can extend out but, there is not a mount made that we are aware of that has a pullout range of .5" - 2".
wallmountworld is offline
Reply OLED Technology and Flat Panels General
