Connecting a cable box to a pdp-433cmx cable box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-23-2012, 07:05 PM - Thread Starter
rjt021's Avatar
I've got a pioneer pdp-433cmx plasma TV and was wondering how I set it up to a regular cable box. Thanks!
-Bob
rjt021 is offline
post #2 of 4 Old 07-23-2012, 08:33 PM
Otto Pylot's Avatar
Quoted: 1629 Post(s)
Liked: 1024
There were no instructions on how to hook it up? I would think you could just run a coax from the cable box to the CATV/Antenna coax input on the tv, and set the tv to cable.
Otto Pylot is offline
post #3 of 4 Old 07-24-2012, 09:59 AM
walford's Avatar
I am not sure what a "regular cable box" is but if it has composite or HDMI outputs I would use them to the TV since you can then send HD content instead of coax since the signals oiver coax are normally in NTSC SD fornmat.
walford is offline
post #4 of 4 Old 07-24-2012, 06:28 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 781
What type of connections does your 433CMX have?
What type of connections does your "regular cable box" have?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Reply OLED Technology and Flat Panels General
