Have a 2012 Panasonic Smart HDTV or Blu-Ray player and want to Skype on the cheap? Very nice, and cheap, compatible webcam found! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-08-2013, 09:01 PM - Thread Starter
Wineaux2's Avatar
http://www.amazon.com/Logitech-HDTV-Widescreen-Video-Cam/dp/B0040QE98Y/
Confirmed working and tested by me on a 2012 TC-L47ET5 and a DMP-BDT220 using the onboard Skype app! Works perfectly right out of the box. Just plug it into the USB port on your TV or BD player, run the Skype app, log in, and start making video calls. Current low price as of this post is $39.95 SHIPPED with Prime (Fulfilled By Amazon)! That lowest price is back ordered till 01/16/13, or it is in stock and shipping now with Prime for $49.95.
This is Logitech's $199 720p TV Cam for the Logitech Revue, but it works perfectly with the 2012 Panasonic's. If you have another brand of HDTV that has a USB port and a built in Skype app, you might want to give it a try, but I can't guarantee anything. If you find it works with other brands, please post years and models here.
See clearly with widescreen, HD (720p) video resolution
Know who's calling with on-screen notification and caller ID
Get up close and personal with 5x digital zoom
See it all with wide-angle lens
Enjoy razor-sharp images with Carl Zeiss optics
Hear clearly with two digital directional microphones to reduce noise and echoes
Enjoy and have fun!
PS... Also tested and working out of the box without any drivers or other hacks with both Facetime and Skype on a mid-2012 Mac Mini running Snow Leopard. This is my Plex media server which is connected to my TC-L47ET5 and it's working perfectly as a video conferencing webcam on my Panasonic HDTV.
Of Note: You should restart your Mac after plugging in the Logitech TV Cam to fully enable support for the webcam. Facetime required that I ran the app, quit it, and then restarted the app in order to recognize the webcam. Skype required a full reboot of my Mac Mini in order to recognize the video portion of the webcam, although audio worked perfectly the first time.
Wineaux2 is offline
post #2 of 3 Old 11-04-2013, 11:20 PM
ebass5str's Avatar
Does the DMP-BDT220 still work with the logitech webcam for you?  I tried that exact model hoping that it would work in the rear camera usb port and the bluray player said that no camera was found when I tried opening skype.  The camera itself did flash blue when it was plugged in and when I tried to open skype.  I was wondering if this might be a firmware update incompatibility or if you might have any tips!
Thanks so much!
ebass5str is offline
post #3 of 3 Old 12-31-2013, 05:43 PM
AFRETIEDVET's Avatar
I had the same problem with my ~DMP-BDT220, have you found a resolution yet?  I am wondering what date is on the SKYPE app that was working first post?
AFRETIEDVET is offline
Reply OLED Technology and Flat Panels General
