Need help from the Collective in choosing a TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-21-2013, 10:43 AM - Thread Starter
docmhale's Avatar
Hi All!
I need help in choosing a tv. This is going in the family room that has windows on the east and south sides of the 4 sides so it is fairly bright in the daytime. Main use of the tv will be for tv and some Blu-Ray movies in the afternoon and evening and I don't need 3D or gaming. Somewhat energy efficient would be nice and I don't have a limiting factor on size. My budget for this is $1K. So what says the Collective! Thanks for the help.
docmhale is offline
post #2 of 13 Old 01-21-2013, 03:51 PM
hoozthatat's Avatar
Liked: 38
Originally Posted by docmhale View Post
Hi All!
I like the LM7600 from L.G., and its an edge lit local dimming LED/LCD, only thing I'm not a fan of in that FP is the glossy screen. Performance wise it's pretty solid, in the 47" size it sits right at the top of your budget but again it's a worth while consideration.
The LE640U from Sharp is another worthy option. My only problem with what I've seen from the Sharp's from 2012 is the inability to handle motion too terribly well. I've seen the LE640U in action with several sporting events from hockey and football to basketball and horse racing and the FP didn't handle the temporal resolution too well.
The EH6000 series from Samsung is definitely a great value, no frills TV. You don't get a ton of input options which may or may not be a big deal for some. However it is a direct backlit LED/LCD and typically you'll get better uniformity from the backlight on those over the edge lits.
Lastly the EX645 from Sony deserves a look. I personally think there are better options out there but still it's a decent performing FP. I like the fact that it comes with a swivel base, quirky or not. I just felt like from what I've seen on the Sony whites tend to be too cool and blacks too washed and gray.
The LG I mentioned would be a 47" for your budget, the Sharp a 52", the Samsung a 55", and the Sony a 50"
If 47" will suffice I think the LM7600 is the best performer of this bunch. I tried to go from most viable option to last ditch here.
Anyway, best of luck and cheers!
60F8000; RX-V367; TSi300 x2; YST-SW102; Harmony 650; Apple TV; Microsoft Xbox One Console; RF-HTS120;
xRite i1 Display Pro (OEM); CalMAN 5 Basic; ColorHCFR
hoozthatat is offline
post #3 of 13 Old 01-23-2013, 03:26 PM - Thread Starter
docmhale's Avatar
I forgot to add that I need the tv to have an OTA digital tuner feature.
docmhale is offline
post #4 of 13 Old 01-23-2013, 05:07 PM
andy sullivan's Avatar
Quoted: 754 Post(s)
Liked: 403
If size is in the equation then get the 60" Vizio.
andy sullivan is offline
post #5 of 13 Old 01-23-2013, 07:23 PM
hoozthatat's Avatar
Liked: 38
If you have any sense you won't buy anything Vizio.
post #6 of 13 Old 01-23-2013, 07:24 PM
hoozthatat's Avatar
Liked: 38
Not a fan of any of the above mentioned FP's?
post #7 of 13 Old 01-23-2013, 09:41 PM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
There are a great many sets I'd buy long, long before I even considered a Vizio. Not being on top of the market, but LG has a 60" BOL plasma that often shows up in your price range. There are also a few Sharps that might fit the bill. Avoid Vizio.
Matt L is online now
post #8 of 13 Old 01-24-2013, 10:18 AM
Quoted: 754 Post(s)
Liked: 403
That's like saying "avoid Hyundai" based on old assumptions. I'm not saying that Vizio is a top tier performer, but read the reviews in Sound and Vision Magazine, or Home Theater Magazine, or Home Theater Review, or CNET. Not great but considered a solid value for the person looking for "bang for their buck". Once you get away from top plasmas or top tier LED/LCD's with local dimming the mix becomes much closer in PQ. Vozio uses a Sharp Next Gen screen and the ones I've seen look very nice. Just my opinion but not based on biases formed two or three years ago.
post #9 of 13 Old 01-24-2013, 08:51 PM
hoozthatat's Avatar
Liked: 38
A Taiwanese company called Amtran makes Vizio's TV. They're worthless. To say that they give you "great bang for the buck" is comical. Where did you get Sharp from as a "screen" supplier?
post #10 of 13 Old 01-24-2013, 09:16 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Then I suggest you contact Sound And Vision, CNET and Home Theater Magazine and set them straight!
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #11 of 13 Old 01-24-2013, 09:29 PM
hoozthatat's Avatar
Liked: 38
I respect their reviews and I trust in them whole heartedly. My issue with Vizio is solely from a reliability and quality stand point on the manufacturing end. For lack of a better analogy, you can paint crap gold but in the end it's still crap wink.gif
You own a Panasonic PDP and a damn good one at that, you've got you're head on straight biggrin.gif
post #12 of 13 Old 01-24-2013, 09:53 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
I also own a Toshiba LCD. I guess you can say I'm bipartisan.
mailiang is offline
post #13 of 13 Old 01-24-2013, 10:07 PM
hoozthatat's Avatar
Liked: 38
Cheers!
Reply OLED Technology and Flat Panels General
