How to watch video files from a flash drive on a flat panel that does not have a usb input? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-26-2013, 12:41 PM - Thread Starter
wharfrat's Avatar
No usb input on my old vizio. Is there a way to utilize the existing a/v inputs to take files off a flash drive? No computer oriented solutions please but would consider an inexpensive media player of some sort....all i need it to do is give me a way to connect the flash drive to the flat panel with a player program and remote control.
Rat
wharfrat is offline
post #2 of 12 Old 01-26-2013, 12:55 PM
Ken Ross's Avatar
Quoted: 5702 Post(s)
Liked: 6070
Have you considered a PS3? Attached via the HDMI connection, it's a great way to play video files.
Ken Ross is offline
post #3 of 12 Old 01-26-2013, 01:02 PM - Thread Starter
wharfrat's Avatar
Thanks for the reply but note that i stated "inexpensive" as well as only needing the one function.
Rat
wharfrat is offline
post #4 of 12 Old 01-26-2013, 05:26 PM
walford's Avatar
Do I understand that you old Vizio only has NTSC standard definition composite A/V inputs (Yellow, Red and White)?
If yes then could you use a VCR?
walford is offline
post #5 of 12 Old 01-26-2013, 06:21 PM - Thread Starter
wharfrat's Avatar
I need something with a USB input.
Rat
wharfrat is offline
post #6 of 12 Old 01-26-2013, 06:27 PM
hoozthatat's Avatar
Liked: 38
Try looking at the WD TV Live media player. Friend of mine uses that unit for his 4 TB hard drive and it works like a charm. Just plug the flash drive into the USB input, run either an HDMI out or a composite and stereo audio cables. The box can be found on sale for any where from $69.99 to its full price of $99.99
60F8000; RX-V367; TSi300 x2; YST-SW102; Harmony 650; Apple TV; Microsoft Xbox One Console; RF-HTS120;
xRite i1 Display Pro (OEM); CalMAN 5 Basic; ColorHCFR
hoozthatat is offline
post #7 of 12 Old 01-26-2013, 06:35 PM
MikeyD360's Avatar
Liked: 26
Seconded.
I have a WDTV Live mainly for wireless media library access, but also does USB.
Was so happy with it, I just bought another.
Generally better and quicker than most 'smart TV' interfaces.
MikeyD360 is offline
post #8 of 12 Old 01-27-2013, 04:44 AM - Thread Starter
wharfrat's Avatar
AH!
That looks like a very nice option. This leads me to another thought....(Yes, I may now be departing from my "inexpensive" requirement....just exploring the options)...
Is there also a media hub out there that has a HDD as well as being able to login to a Wi-Fi signal to communicate with my slingbox at another location?
Rat
wharfrat is offline
post #9 of 12 Old 01-27-2013, 04:56 AM
MikeyD360's Avatar
Liked: 26
Google NAS (Network Attached Storage) that might be what you're after, like this:
http://www.netgear.com.au/home/products/storage/prosumer/RND4000.aspx
I don't know if this works with WDTV or if its even any good - but one of these is around $300 in Aus plus cost of HDD(s)
post #10 of 12 Old 01-27-2013, 06:51 AM - Thread Starter
wharfrat's Avatar
Originally Posted by MikeyD360 View Post
Seconded.
Hey,
thanks to both of you.
This solution looks good.
I checked out the WD site to see the specs. It says "built in WiFi" and one of you mention wireless media library access.
I wonder.....
1-does this mean that i could also login to my mobile hotspot with the WD live and communicate with my Slingbox back home?
and then i thought of another question....
2-could I just as well plug an external HDD into the USB port as I can a flash drive?
either of these two options would be great. Both would be simply amazing.
Thanks for your help!!
Rat
wharfrat is offline
post #11 of 12 Old 01-27-2013, 11:45 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
AH!
There's a whole sub-forum \/ down there \/ about streamers and storage. http://www.avsforum.com/f/39/networking-media-servers-content-streamers
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #12 of 12 Old 01-27-2013, 01:47 PM - Thread Starter
wharfrat's Avatar
Thank you,
I'll check it out.
Rat
wharfrat is offline
Reply OLED Technology and Flat Panels General
