Best mount for 60inch tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-14-2013, 08:22 PM - Thread Starter
rock324's Avatar
I'm buying a 60inch Samsung LED (ES6100 series/ weighs 60 lbs) for living room and wanted to see what my options were for mounts. Since it's ultra slim, I would like it to look as flush as possible. I've been doing some research but wanted to get some of your opinions of what I should look into. Also, I'm assuming that anything with that swivel will stick out quite a bit, even when the "arm" is not extended? Or do they make a mount that is decently flush? Thanks!
rock324 is offline
post #2 of 2 Old 03-15-2013, 07:40 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Plenty to choose from at MonoPrice.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply OLED Technology and Flat Panels General
Samsung 50 Inch Led Hdtv Un50es6100
