New TV Time - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-08-2013, 09:58 AM - Thread Starter
Paulus102's Avatar
It's time to buy a new TV (my old one died) and I am leaning towards a Panasonic P50ST60. Are there any comparable LED/LCD tvs for a similar price/feature set that I should consider. Viewing will be mainly in the evening with some day time viewing with venetian blinds closed to decrease light in the room. I'm not too bothered about 3D functionality. I had a search through the forum but didn't see anything specific.
Thanks in advance for your suggestions.
Paulus102 is offline
post #2 of 3 Old 04-08-2013, 11:09 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 623
In case you have not seen it here is cnets take on it
http://reviews.cnet.com/best-hdtvs-56-inches-and-above/
They rate The Panasonic as top value I'm sure same would apply to 2013 models
that P50ST 60 looks like a good set probably be hard to match the Pansonic for picture quality vs price. I bough a 50" plasma in Feb best picture quality
that I could find without spending a ton more .
The new Sony XBR sets are supposed to be the best LCD,LED type
not cheap though they start at $2639.00
The new Sharp 60 LED inch is supposed to be good also
Maybe check out the Plasma sub forum here
or here
tubetwister is offline
post #3 of 3 Old 04-15-2013, 06:52 AM - Thread Starter
Paulus102's Avatar
Thanks for the response.
Reply OLED Technology and Flat Panels General
