No 50" on higher end LED models - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-16-2013, 12:39 PM - Thread Starter
flemo123's Avatar
Is there a good reason that Samsung and other manufacturers are not offering 50" LED models on the higher series. I would ideally like a 50" LED, from Samsungs 7000 or 8000 range but this doesn't exist today. Searched for an answer but no luck elsewhere on AVS.
flemo123 is offline
post #2 of 3 Old 05-20-2013, 06:07 AM
walford's Avatar
Probably because they can not manufacturer 50" panels as efficiently as they can make 55" panels and there appears to be a very small market for 50" panels instead of 55" panels. So it does not make sense for a manufacturer to offer both a 50 and a 55" model using the latest high end video processing chips and have them both be profitable.
walford is offline
post #3 of 3 Old 05-20-2013, 11:34 AM
Steve S's Avatar
Liked: 46
For whatever reason the 50" led/lcd sets are marketed as economy models. This screen size for lcds has only been available for a bit less than a year and probably all the 50" panels come from the same oem.
I'd speculate that they are less than high end panels used in an attempt to make a 50" lcd at a price point similar to a 50" plasma and not suitable for high end application.
Also there's been size creep on high end sets for the last 4 or 5 years meaning that mfgs have long been eliminating flagship status in smaller screen sizes for some time now.
Steve S.
Steve S is offline
Reply OLED Technology and Flat Panels General
Samsung Un46b7000 46 Inch Led Hdtv
