TV for outside - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-27-2013, 05:02 PM - Thread Starter
vasnv's Avatar
Looking to get a 47-55 TV for outside on the patio. It will be installed on the wall under a roof, however in the late afternoon it may get some sunlight on it. Not sure which is better in this scenario, LCD or LED? Thanks.
vasnv is offline
post #2 of 7 Old 05-28-2013, 02:24 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Sunbrite makes LCD TV's specifically for outdoor use. They've received good reviews from HT Magazine, but they're not cheap.
http://www.sunbritetv.com/
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #3 of 7 Old 05-30-2013, 08:05 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
LED TVs are LCD TVs. Both types of TV have the exact same type of LCD (Liquid Crystal Display) screen. The only difference is that "LED" TVs are illuminated with LED chips (usually around the edges of the screen on all but a few models) where traditional LCD TVs are illuminated with CFL backlights behind the panel. "LED" TVs are marketed as being different and even superior to "LCD" but that is intentionally misleading. Edge-lit LED is actually inferior to backlit LCDs and are cheaper to manufacture and the TV buying public falls for it.
No TV is good with direct sunlight shining on the screen, so you may want to consider buying an inexpensive LCD or LED LCD and blocking the afternoon sun with an inexpensive Levelor Solar Shade from Lowes strategically located so it blocks the sun when lowered.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 7 Old 05-30-2013, 09:06 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Sunbright TV's are designed specifically for outdoor use. They are very bright, (although no set will resist the glare from direct sunlight) and they are weather proof. If your installation precludes you from moving the set indoors during inclement weather, even if the set is under a roof, I would not recommend a indoor TV.
Ian
mailiang is offline
post #5 of 7 Old 06-04-2013, 08:03 AM
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
Just got the latest issue of S&V and a Sunbright 60' set was mentioned in the new products section. I'd like to see some Sunbright reviews.
jbug is offline
post #6 of 7 Old 06-04-2013, 02:04 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
http://www.hometheater.com/content/sunbritetv-model-4660hd-outdoor-lcd-hdtv
mailiang is offline
post #7 of 7 Old 06-05-2013, 08:22 AM
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
jbug is offline
Reply OLED Technology and Flat Panels General
