in the market for a new tv> - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-03-2013, 11:06 AM - Thread Starter
fifthalarm's Avatar
should i wait untill the fall or winter for 4k pricing to come down some more then they already have, or should i just buy a tv now.
i am looking at led tv's like the Samsung un60f7050 and tv's in that range....
i was also looking at the Sharpe elite but that was 4200 and that would be streachting it for me budget wise. in you guys need more info let me know. thx for any advise
fifthalarm is offline
post #2 of 7 Old 06-03-2013, 11:34 AM
sytech's Avatar
Quoted: 1996 Post(s)
Liked: 1407
Really better off waiting on 4K until every thing like HDMI 2.0 and H.265 codec is ironed out. Large 4K sets are around $7,000-$15,000, way above your budget. There probably won't be much 4K content until 2015 anyway. If you need a display right now, I would grab one on the cheap Panasonic plasmas like the 65" Panasonic S64 for $1500 and waiting it out.
DON'T ARGUE WITH ME. I AM NEVER WONG.
sytech is online now
post #3 of 7 Old 06-03-2013, 03:39 PM - Thread Starter
fifthalarm's Avatar
thx for that advise pal i will look into it... do you think i should keep my 50' dlp Panasonic for another two years?
post #4 of 7 Old 06-03-2013, 05:51 PM
KOF
KOF's Avatar
Quoted: 269 Post(s)
Liked: 225
If you're thinking about buying a Samsung, at least wait a year until HDMI 2.0 arrives, then you can get compatibility fixes via Evolution kits. This is what I am planning as well since I've decided to go with the Samsung plasma.
KOF is offline
post #5 of 7 Old 06-03-2013, 07:54 PM - Thread Starter
fifthalarm's Avatar
in a year from now 4k would prob be cheaper also and have usb 2.0 ..
post #6 of 7 Old 06-03-2013, 11:23 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 231
Hdmi 2.0
blee0120 is online now
post #7 of 7 Old 06-05-2013, 11:31 AM - Thread Starter
fifthalarm's Avatar
yeah thats what i meant lol
Reply OLED Technology and Flat Panels General
Samsung Smart 60 Inch Led Hdtv 3d Wi Fi Un60f7050
