Samsung adapter to eliminate 90 degree power plug? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-30-2013, 10:53 AM - Thread Starter
tripleM's Avatar
Just bought a Sammy LED for the bedroom wall & the OEM power plug is 90 degrees.
Unfortunately, I have a recessed 2 plug outlet that won't accommodate the Sammy 90 degree plug.
1) can I replace the OEM Sammy chord with straight adapter of some sort?
2) or replace the cord altogether? would this cause issues with the Sammy?
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #2 of 4 Old 06-30-2013, 10:08 PM
Matt L's Avatar
Quoted: 297 Post(s)
Liked: 265
It's just a power cord. Most are just a standard cable used on most if not all desktop computers. Swap it out.
Matt L is offline
post #3 of 4 Old 06-30-2013, 11:22 PM
Norde's Avatar
I have a Samsung D8000 and the female power cord going in to the panel is not the usual shape.
Prior to getting this set, most of the miniature power input plugs that I came across were polarized, meaning that one of the female inputs was circular while the other was a squared off circle. This type of plug will not fit into my Samsung. Get a specific Samsung plug with a straight end going into the wall plug. Search for "Samsung Power Plug".
If the recessed plug is behind the set is there enough room for a regular three pin to two pin adapter, or will that cause the panel to stick out too far?
Norde is offline
post #4 of 4 Old 07-01-2013, 08:31 AM - Thread Starter
tripleM's Avatar
What caused this original post was that the 90 degree plug took up the space needed for a second plug from a Tivo Mini I am mounting behind the TV.
Hmmm... never thought about getting a 3 to 2 adapter without the polarized 3rd prong.
tripleM is offline
Reply OLED Technology and Flat Panels General
