LG 39LN4500 Series LED TV Direct Channel Change - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-04-2013, 03:02 AM - Thread Starter
FalsEye05's Avatar
Hello Everyone,
I hope someone can help me out with this question because the user manual didn't help, and neither did the LG Website...
I just got a LG LN4500 Series LED TV TV (39"). It seems easy enough, but I can't figure out how to bypass the "easy" channel presets, and get to the direct channel switching from the remote control. and I just finished the channel scan from my rooftop antenna. The scan went fine but the way that the TV stores the channels is by channel presets instead of the actual channel number. (This is so you have easy access to your favorite channels. For example...Preset 1 - channel 15, preset 2- channel 34, etc.). So the way the remote is setup is by Channel presets also. So if you press #1 into the number pad of the remote, it will take you to channel 15. And I just want to press 1-5 and get channel 15. Press 02 and get channel 2... not 34. But I cant figure out how to turn off the presets. Any help is appreciated. Thanks in advance.
FalsEye05 is offline
Reply OLED Technology and Flat Panels General
