LG 55EA9800 55" OLED Owner's thread - Page 158 - AVS Forum
post #4711 of 6977 Old 06-30-2014, 07:55 AM
Theplague13's Avatar
Quoted: 102 Post(s)
Liked: 328
Originally Posted by Barrybud View Post
I saw some pretty good banding last night and I wonder if any of you are able to reproduce it.
I was watching a Showtime On Demand series called Penny Dreadful. Season 1, episode 2 in the opening scene set in old London during a foggy night and we see a lamplighter emerging from the fog.
Let me know if you see it.
As we know My set is uncalibrated and this is HD content via Comcast on a box that I am not thrilled about. I rarely see banding on this display and never on Blu-Ray or HD-DVD only on cable. I am currently using the ISF 1 setting out of the box with the only change I made to it was a small bump in brightness to 52. I have the motion set to User and I think its set to 2 and 6. I have all other video processing and noise reduction off.
I'll check this tonight. Your settings shouldn't have any effect on banding, however.
If I sow a wind now, I will reap a storm.
Theplague13 is offline
post #4712 of 6977 Old 06-30-2014, 08:18 AM
Foxbat121's Avatar
Quoted: 240 Post(s)
Liked: 250
This will be a perfect scene for MPEG compression artifacts/banding as well (smoke/fog/gray clouds are very difficult to compress without artifacts if bandwidth is limited).
herpderp likes this.
Foxbat121 is online now
post #4713 of 6977 Old 06-30-2014, 08:20 AM
mo949's Avatar
Liked: 579
Calibrated or not, you are going to see banding on an 8 bit display at times. If you ever watch Robert Redford's, "All is Lost", you'll see loads of it. The type of scene you referenced above is typically one that will present compression artifacts as well.
To compare severity of it you'd have to throw up some color gradient charts. Some settings can make the gradient steps worse/better.
mo949 is offline
post #4714 of 6977 Old 06-30-2014, 08:33 AM
Ken Ross's Avatar
Quoted: 1380 Post(s)
Liked: 1494
Barry, artifacts that are usually only seen on cable and not other sources, can usually be attributed to compression artifacts by the service provider. Even if someone reports watching the same scene and has no artifacts, you'd need to know what service provider they're using. Compression will be different via Comcast, Cablevision, FIOS etc.
But I'd bet what you saw isn't panel related.
Ken Ross is offline
post #4715 of 6977 Old 06-30-2014, 08:37 AM
tgm1024's Avatar
Quoted: 631 Post(s)
Liked: 926
Originally Posted by Masterbrew2 View Post
Was just notified of a new 600mb software update for the TV. Have downloaded and installed, don't notice anything changed. Gotta love updates without changelogs...
LOL.....and then everyone wakes up the next day and >poof< their TV is flattened. That's one hell of an update....
Yes, it's true that color does not exist in the physical universe: it exists only in the brain. But this doesn't mean that one person can see blue internally as yellow and that another could see it as red. The reactions and recognition of colors is neurological in nature. Once it occurs there isn't yet another evaluation that takes place. Blue looks to me as blue in precisely the same way it does to you, by definition.
tgm1024 is online now
post #4716 of 6977 Old 06-30-2014, 09:23 AM
Moderator
Barrybud's Avatar
Quoted: 38 Post(s)
Is that the 050614 update? That was also a sizable update which many feel may have been related to the smart content. I ran an update check last night about 2AM and it said I was up to date with the 0506 version.
Barrybud is offline
post #4717 of 6977 Old 06-30-2014, 09:26 AM
Moderator
Barrybud's Avatar
Quoted: 38 Post(s)
Thanks for all the replies on the compression artifacts. Sadly Comcast is my main source for content.
Barrybud is offline
post #4718 of 6977 Old 06-30-2014, 09:31 AM
Masterbrew2's Avatar
Quoted: 49 Post(s)
Liked: 91
I was notified of the update this morning. My current version now says: 05.01.18
My set is the 970V, but I don't suppose that would make a difference. I had the 9800 before and I have seen no signs of differences in the software.
Masterbrew2 is offline
post #4719 of 6977 Old 06-30-2014, 09:45 AM
Foxbat121's Avatar
Quoted: 240 Post(s)
Liked: 250
Just did an update check and there is no new update for this TV. I'm already on 05.06 update the first day I setup the TV.
To be clear, you only saw this update on your 970v TV, not the 8900 OLED? Even though the UI looks the same, the underlying firmware will be quite different due to different hardware. And there should be no direct relationship between when we see updates on one TV and when we see it on another different model.
post #4720 of 6977 Old 06-30-2014, 12:18 PM
vaktmestern's Avatar
Quoted: 243 Post(s)
Liked: 160
Prob just smart tv updates as always. had my update a few days back.
vaktmestern is offline
post #4721 of 6977 Old 06-30-2014, 12:20 PM
Quoted: 49 Post(s)
Liked: 91
Yep.
Well what "different hardware"? They are 95% the same.
post #4722 of 6977 Old 06-30-2014, 12:24 PM
Quoted: 49 Post(s)
Liked: 91
Has anyone managed to set up the Time Machine/DVR functionality with an external hard drive?
post #4723 of 6977 Old 06-30-2014, 01:19 PM
tgm1024's Avatar
Quoted: 631 Post(s)
Liked: 926
Originally Posted by Stereodude View Post
I saw some political comments sparked by references to net neutrality earlier.
I don't like this banning of Vinnie one bit....bugs me a lot.
post #4724 of 6977 Old 06-30-2014, 01:37 PM
5x10's Avatar
Quoted: 533 Post(s)
Liked: 292
Wonder if our resident mod, Barrybud, could help him out
5x10 is offline
post #4725 of 6977 Old 06-30-2014, 05:58 PM
Quoted: 102 Post(s)
Liked: 328
Me too bro. You two guys are my homies.
post #4726 of 6977 Old 06-30-2014, 05:58 PM
tgm1024's Avatar
Quoted: 631 Post(s)
Liked: 926
No, we can't pit one moderator against another.
post #4727 of 6977 Old 06-30-2014, 06:32 PM
Yappadappadu's Avatar
Quoted: 92 Post(s)
Liked: 95
Should at least be possible to get the info how long he'll be gone. I hope it's not a permanent ban.
Yappadappadu is online now
post #4728 of 6977 Old 06-30-2014, 09:19 PM
mo949's Avatar
Liked: 579
I seemed to have missed this one but I have a feeling I know which so called mod it is...
mo949 is offline
post #4729 of 6977 Old 06-30-2014, 10:55 PM
5x10's Avatar
Quoted: 533 Post(s)
Liked: 292
Do you think an optical cable will bypass the arc issues with this set?
I thought netflix looked better on the tv compared to the xbox1
And, this tv continues to impress, I look forward to watching it, easily the best picture I have ever seen
5x10 is offline
post #4730 of 6977 Old 07-01-2014, 12:57 AM
Quoted: 243 Post(s)
Liked: 160
Agree netflix looks better on the Lg app than the x1 even the oppo 103d app looks worse.
post #4731 of 6977 Old 07-01-2014, 03:05 AM
mikeg1's Avatar
Quoted: 25 Post(s)
The LG Netflix application on my OLED is incredible compared to the Sony Google Tv box feeding my Kuro. I waited until I bought the LG to watch House of Cards. I watched Prometheus in 3D this weekend and was amazed how well this tv handles 3D.
5x10 likes this.
mikeg1 is offline
post #4732 of 6977 Old 07-01-2014, 04:57 AM
kinglm's Avatar
Quoted: 58 Post(s)
Liked: 49
Yes, I don't have an ARC compatible AVR. Connecting an optical cable from the TV to the AVR lets me get sound from Netflix etc. Not limited to the TV speakers.
5x10 likes this.
kinglm is online now
post #4733 of 6977 Old 07-01-2014, 05:27 AM
Quoted: 49 Post(s)
Liked: 91
Cosmos is pretty damn good looking on this TV
It is really well graded. Other beautiful 'space odysseys', like 2001 and Star Wars, unfortunately have non-black blacks.
post #4734 of 6977 Old 07-01-2014, 07:03 AM
Quoted: 102 Post(s)
Liked: 328
That's a shame about 2001, I love that movie and wanted to pick up the blu Ray to watch on tmhere, but star wars didn't have non-black blacks for me, at least the old trilogy.
post #4735 of 6977 Old 07-01-2014, 07:35 AM
Foxbat121's Avatar
Quoted: 240 Post(s)
Liked: 250
Optical should work just fine. That's the common recommendation over ARC on almost any TV brands. I just don't want the hassle to run the optical cable and configure my AVR as well as remote to do so.
On my Panasonic Plasma, ARC is only turned on when I go into Netflix app. But it also mysteriously stop working with no way to turn it back on until I unplugged the TV power for extended period of time. So ARC in general is poorly implemented in majority of the TV brands from my own experience and experiences from others.
5x10 likes this.
post #4736 of 6977 Old 07-01-2014, 08:30 AM
5x10's Avatar
Quoted: 533 Post(s)
Liked: 292
Thanks for the responses fellas, I'm going to order a longer optical so I can watch Netflix/YouTube on my oled, the xbox1 is garbage, not only can it not keep up with this tv, the disc drive isn't recognizing disks now
And I don't know if this is against the rules, mods, please delete if so but since Vinnie was so popular here, he is now over at home theatre shack forum, he let me know via amazon comments, lol
tgm1024 likes this.
5x10 is offline
post #4737 of 6977 Old 07-01-2014, 08:40 AM
Quoted: 243 Post(s)
Liked: 160
Just to clear the x1 memory easy and nether the x360 or x1 has super hd from netflix thats why u see a lesser picture btw
post #4738 of 6977 Old 07-01-2014, 08:49 AM
5x10's Avatar
Quoted: 533 Post(s)
Liked: 292
I just cleared the persistent memory, hard reboot, still doesn't recognize the disc
Thanks for the advice though
5x10 is offline
post #4739 of 6977 Old 07-01-2014, 08:53 AM
Quoted: 243 Post(s)
Liked: 160
Worked for me on Nfs as it wouldt read that once.
post #4740 of 6977 Old 07-01-2014, 09:04 AM
5x10's Avatar
Quoted: 533 Post(s)
Liked: 292
My issue is with blu rays, I need to see if games work
I wonder if the blu ray player is sub par on this, in the same way the netflix app is
5x10 is offline
Reply OLED Technology and Flat Panels General
Lg 55ea9800 Oled Hdtv , Lg
Gear in this thread - 55ea9800 by PriceGrabber.com
