LG 55EA9800 55" OLED Owner's thread - Page 227 - AVS Forum
post #6781 of 6797 Old 10-27-2014, 08:07 PM
TomHuffman's Avatar
Quoted: 71 Post(s)
Liked: 241
Originally Posted by mo949 View Post
Tom, rather than using brightness to account for the crush, have you tried increasing the OLED light and determining if the detail is still missing?
I tried this and the OLED Light does have an effect on the brightness setting. So with OLED Light set to 50 I was able to set Brightness at 52. The problem is that this doesn't fix anything. Shadow detail is restored but black is now at 0.016 nits, pretty much right back where I started with OLED Light at 25 and Brightness at 56.
As it stands, this display has worse contrast than the last generation of plasmas, assuming blacks are not crushed. I'd love to fix this problem. There is much else about this display that I really like.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #6782 of 6797 Old 10-28-2014, 04:28 AM
Mattopotamus's Avatar
Quoted: 562 Post(s)
Liked: 266
I think I remember Vegas OLED mentioned adjusting a black level setting in the advanced settings to remove crush, but also maintain the deep blacks.
Mattopotamus is online now
post #6783 of 6797 Old 10-28-2014, 07:20 AM
hobbs47's Avatar
Quoted: 68 Post(s)
Liked: 114
Yeah, I believe it was to use the Black Level - High setting then adjust brightness as needed.
hobbs47 is online now
post #6784 of 6797 Old 10-28-2014, 09:16 AM
mo949's Avatar
Liked: 558
Tom that's too bad. I was hoping you would find that the OLED light might not have a linear impact on the low end and BTB section. That way you could find a combination where you set the OLED light very high and reduce brightness to compensate and possibly ending up with a result that mitigates any of the black crush. Of course you'd have a higher peak light output than you were targeting, but ce la vie there's always a trade isn't there?
mo949 is offline
post #6785 of 6797 Old 10-28-2014, 09:59 AM
Foxbat121's Avatar
Quoted: 230 Post(s)
Liked: 245
If I'm not mistaken, Black Level High is for full range RGB. Black Level Low is for limited range. You need to make sure it matches your device's output. You can't calibrate/adjust correctly if you have a mismatch.
For most consumer devices, limited range (e.g. Black Level Low) is the standard output.
hobbs47 likes this.
Foxbat121 is online now
post #6786 of 6797 Old 10-28-2014, 10:32 AM
Rich Peterson's Avatar
Quoted: 65 Post(s)
Liked: 74
So is the MicroCenter closeout deal over? The store in my area has been out of them for over a week now. And I don't see the set when do a search on their website. Are there any left anywhere?
Rich Peterson is online now
post #6787 of 6797 Old 10-28-2014, 11:38 AM
Joseph Clark's Avatar
Quoted: 94 Post(s)
Liked: 178
The Micro Center in St. Louis says it has one left in stock.
Joe Clark
Joseph Clark is online now
post #6788 of 6797 Old 10-28-2014, 12:40 PM
Foxbat121's Avatar
Quoted: 230 Post(s)
Liked: 245
Still 3 left in Northern VA store.
post #6789 of 6797 Old 10-28-2014, 01:39 PM
MGTR420's Avatar
Quoted: 33 Post(s)
Liked: 40
Theres almost 2 dozen left in the New York area...
Vegas oled likes this.
MGTR420 is offline
post #6790 of 6797 Old 10-28-2014, 03:53 PM
Quoted: 562 Post(s)
Liked: 266
7 at my local store; still $1999
post #6791 of 6797 Old 10-29-2014, 11:51 AM
Parrish's Avatar
I am using sound and vision's settings from their review but cannot access the black level setting to change it from auto to low? black level is the only setting disabled in expert 1?
Coton de Tulear-IndyFab-Kuro-XBR8-Sharp Elite-LG OLED - Current Loves of my life.
Parrish is offline
post #6792 of 6797 Old 10-29-2014, 12:07 PM
Foxbat121's Avatar
Quoted: 230 Post(s)
Liked: 245
It is changeable on mine. A lot of items in picture options can be disabled depending on what kind of signal it receives. So, I assume if you connect a device, like PC, who outputs full range signal and it is on Auto, it may disable the black level settings because it already detected the correct signal level for you. Try turn off the video source and change the black level to Low or high instead of Auto. Then power the video source on and see what happens.
post #6793 of 6797 Old Yesterday, 06:57 PM
Vegas oled's Avatar
Quoted: 1009 Post(s)
Liked: 689
This was for the 9300, I do not believe the 9800 has an issue with crushing blacks. I believe LG did this to the 9300 to hide uniformity issues. Uniformity issus that were only an issue if you watch slides all day.
The 9800 is neck and neck with the Samsung oled, both are World Class and amazing. The 9300 would not show a slide at 10 ire (crushed), the 9800 had no problem showing the same slide.
If someone has a 9800 crushing blacks it might be calibrated off from the factory.
Vegas oled is offline
post #6794 of 6797 Old Yesterday, 07:04 PM
Vegas oled's Avatar
Liked: 689
Hopefully they ship those to some other stores giving other buyers a chance.
post #6795 of 6797 Old Yesterday, 07:18 PM
MGTR420's Avatar
Quoted: 33 Post(s)
Liked: 40
I agree. This tv is truly amazing and hope if someone wants one, can get one at a great deal.
MGTR420 is offline
post #6796 of 6797 Old Today, 06:35 AM
Parrish's Avatar
[QUOTE=Parrish;28634026]I am using sound and vision's settings from their review but cannot access the black level setting to change it from auto to low? black level is the only setting disabled in expert 1?[/QUOTT
That makes sense- I have only been viewing ota as source so far- blacks are fantastic- better than the Kuro 141fd- I will try ps3 as source this weekend and try bd and gaming with hdmi.
Parrish is offline
post #6797 of 6797 Old Today, 10:18 AM
5x10's Avatar
Quoted: 519 Post(s)
Liked: 282
710 hours on the set
still the same 5 stuck blue subs
5x10 is online now
Reply OLED Technology and Flat Panels General
Lg 55ea9800 Oled Hdtv , Lg
