LG 55EA9800 55" OLED Owner's thread - Page 241 - AVS Forum | Home Theater Discussions And Reviews
 1157Likes
post #7201 of 7374 Old 02-20-2015, 05:34 PM
kclfoxtrot's Avatar
I have had only 1 reboot, and none since the last update. Not sure why, but the TV's picture seems to be getting better and better
kclfoxtrot is offline
post #7202 of 7374 Old 02-26-2015, 11:22 AM
Quoted: 18 Post(s)
Liked: 8
Is our TV capable of displaying HDR content or is that for 4k only TV's?
Mardon85 is offline
post #7203 of 7374 Old 03-03-2015, 03:38 AM
orange55's Avatar
Hi
I am looking at buying one of the LG OLED tv's but can anyone advise if you can use IR commands to select specific inputs? I use a Philips pronto and need to be able to target individual inputs.
Thanks in advance.
orange55 is offline
post #7204 of 7374 Old 03-03-2015, 02:51 PM
chexi1's Avatar
Quoted: 62 Post(s)
Liked: 115
No.
chexi1 is offline
post #7205 of 7374 Old 03-04-2015, 10:58 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Originally Posted by orange55 View Post
Hi
Thanks in advance.
Yes. But this thread is only for older EA9800. Can't say for sure for newer LG OLED TVs that you can actually purchase in stores. But I don't think any reason they won't be.
Foxbat121 is online now
post #7206 of 7374 Old 03-05-2015, 04:47 AM
Mattopotamus's Avatar
Quoted: 1483 Post(s)
Liked: 1131
I finally got around to watching guardians of the galaxy in 3D last night...amazing! Is this set in fact full resolution 3D? I normally notice the half resolution, and I could swear this looked just as good, if not better, than my xbr900A (which is full resolution passive 3D).
Mattopotamus is online now
post #7207 of 7374 Old 03-05-2015, 04:50 AM
Quoted: 18 Post(s)
Liked: 8
Nope it's half resolution. I've never tried to overclock the framerate with my PC and a driver hack to see if Nvidia 3D vision would work. Doubt it'll make it to 120hz. That would offer full 1080p 3D if it worked.
Mardon85 is offline
post #7208 of 7374 Old 03-05-2015, 11:03 AM
chexi1's Avatar
Quoted: 62 Post(s)
Liked: 115
I definitely notice the half resolution on the little 3D content I have viewed.
vaktmestern likes this.
chexi1 is offline
post #7209 of 7374 Old 03-05-2015, 11:06 AM
Quoted: 18 Post(s)
Liked: 8
If you sit at a distance it's a bit more difficult. Personally I'd take that over the ghosting the active method uses. Also with the OLED being so bright it feels like you loose less detail.
Mardon85 is offline
post #7210 of 7374 Old 03-05-2015, 12:23 PM
jeanrot's Avatar
Hi
Thanks in advance.
Yes, I have a brand new OLED 55EA9850 and IR works fine.
jeanrot is offline
post #7211 of 7374 Old 03-05-2015, 12:51 PM
orange55's Avatar
Are you able to send me the IR codes?
orange55 is offline
post #7212 of 7374 Old 03-05-2015, 12:58 PM
jeanrot's Avatar
Attached file.
BobSalita likes this.
jeanrot is offline
post #7213 of 7374 Old 03-05-2015, 03:17 PM
orange55's Avatar
Attached file.
Brilliant, thanks.
LG 55EC930V, Tag McLaren AV192R, Tag McLaren 100x5R, Linn Akurate 242 MK3, Katan & Trikan Loudspeakers, B&W PV1 Subwoofer, Tag McLaren DVD32R, Oppo BDP-103, Sky+HD RA upgraded, Lumagen Mini3D, Philips Pronto TSU9600, Chord Signature Tuned Array Cables, IsoTek Power, Spectral Stand.
orange55 is offline
post #7214 of 7374 Old 03-06-2015, 04:09 AM
First XBR's Avatar
Originally Posted by Mattopotamus View Post
If anyone is looking check you local Frys. Mine had one for $1999
Where is Fry's electronics you are talking about ?
First XBR is offline
post #7215 of 7374 Old 03-06-2015, 06:33 AM
Liked: 1131
Gwinnett, GA. It was their last one.
post #7216 of 7374 Old 03-08-2015, 10:51 PM
fast159's Avatar
Liked: 2
Hello All!! Just wanted to say that I had my LG EA9800 55inch cablibrated this afternoon by Chad B by HDTV. The set I also bought at Frys last June for $1,999.00 at Fry's when they did a price match from Micro Center in Houston Texas. Chad did a perfect job and now the picture is even better. In any case if you want a great calibration-I highly recommend Chad B. !!!
Chad B and Crohny like this.
fast159 is offline
post #7217 of 7374 Old 03-09-2015, 06:32 AM
Liked: 1131
What did chad think of the set? I know he has calibrated 9300's, but I wonder if this is his first 9800??
post #7218 of 7374 Old 03-09-2015, 08:17 AM
fast159's Avatar
Liked: 2
Chad really liked the set. He has calibrated a couple of these before. The 9300 and 9800 are very similar. Have a great day!!
fast159 is offline
post #7219 of 7374 Old 03-12-2015, 04:11 AM
BobSalita's Avatar
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
I programmed discrete HDMI input codes into a URC 6440 remote. The URC 6440 is an One For All brand European remote with auto backlighting for $25. I used Remote Master (JP1) software to build up the IR commands.
A JP1 forum member posted the attached file which contains HDMI discrete codes.
Former Top 1000 Amazon reviewer bemoaning the loss of objective user reviews. Amazon, stop your complacency!
BobSalita is offline
post #7220 of 7374 Old 03-17-2015, 06:56 PM
Liked: 0
Hi all...I purchased an LG OLED-now has a yellow line. Any advice? I'm 3 months out of the one year warranty.
ID:	609409   Click image for larger version
Alterego2002 is offline
post #7221 of 7374 Old 03-17-2015, 08:20 PM
chexi1's Avatar
Quoted: 62 Post(s)
Liked: 115
I would contact LG and see if they will hook you up anyway. At the price I expect you paid for that TV, they would be fools not to.
chexi1 is offline
post #7222 of 7374 Old 03-17-2015, 11:26 PM
i_max2k2's Avatar
Quoted: 14 Post(s)
Mine had its first reboot the day before yesterday, I have never seen one before. I wonder if its the new firmware.
Btw I might have to move in the next few weeks, and unfortunately I threw away the packaging when I got my set, do you think if I called LG they could send some packaging, anyone else had something like this come up?
i_max2k2 is online now
post #7223 of 7374 Old 03-18-2015, 04:40 AM
Callsign_Vega's Avatar
Quoted: 290 Post(s)
Liked: 127
Hey guys thinking about OLED for a computer gaming monitor (4K).
Any horror stories about image retention for these sets that have been out for a while?
Do these sets have the build in voltage stabilizer to help prevent image retention? Anyone game for many many hours on OLED and have no IR issues?
Callsign_Vega is offline
post #7224 of 7374 Old 03-18-2015, 05:32 AM
Liked: 1131
bubble wrap. I bought an open box, and that is how I got it home w/ no problems at all.
i_max2k2 likes this.
post #7225 of 7374 Old 03-18-2015, 06:39 AM
MGTR420's Avatar
Quoted: 34 Post(s)
Liked: 40
Let us know how this plays out from LG if you decide to call...
MGTR420 is offline
post #7226 of 7374 Old 03-19-2015, 05:34 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
YouTube cast
Just found out that you can cast youtube video from your Android YouTube app directly to the TV the same way as Chromecast. Quite Amazing. From what I can tell, it is using the YouTube Remote connection feature of the TV's YouTube app. You don't have to launch the TV app at all.
post #7227 of 7374 Old 03-19-2015, 11:44 AM
reverendo's Avatar
Quoted: 26 Post(s)
Liked: 2
I can't talk about gaming, but I bought a demo model from bestbuy. It had major IR problems and even after about 3-4 weeks of use these didn't go away. I eventually returned it. There seems to be some kind of type of IR preventer, but it won't be effective if you have certain static images for a very long period. I'd be weary of heavily gaming on this TV if I were you.
OTOH, the image quality, especially blacks, have ruined me for life. I don't enjoy my Plasma half as much at the moment. There's nothing like blissful ignorance.
SB Touch>Resolution Audio Cantata>Gryphon Diablo>Evolution Acoustics MicroOne
reverendo is offline
post #7228 of 7374 Old 03-19-2015, 06:50 PM
Quoted: 290 Post(s)
Liked: 127
Yup, once you see true blacks and infinite contrast, it's hard to use anything else.
wrxlvr likes this.
post #7229 of 7374 Old 03-21-2015, 06:27 AM
Liked: 1131
was it that "PC rated" burn in? The display I got must have never had that demo loop on it b.c pretty much all of the display's I have seen had that burn in.
The one I got had 4500 hours on it and no burn in/IR. It also had a newer demo loop playing. They left the USB in the TV, which is really nice
I would still try to find a 9800 if you can. I had the 9800 and the 9300 side by side for a few weeks and chose the 9800, mainly due to the ABL on the 9300. It is pretty distracting.
post #7230 of 7374 Old 03-21-2015, 07:28 AM
MGTR420's Avatar
Quoted: 34 Post(s)
Liked: 40
I know a Best Buy that had a 9800 with bad burn in, replaced the panel on it, and sold it for 1300...I wonder if other stores have had to do that.
MGTR420 is offline
Reply OLED Technology and Flat Panels General
Lg 55ea9800 Oled Hdtv , Lg
