Headphone Jack Question - AVS Forum | Home Theater Discussions And Reviews
Old 01-25-2014, 12:01 PM - Thread Starter
deltadart22's Avatar
Hope this is the correct forum for this question. I currently had a RCA 46" flat screen. Its 7 years old. It has the 3.5mm headphone jack which I use all the time. Also have the Toshiba SBX4250 soundbar. I would like to replace the tv with a new 65" model. Fact is none of the tv's I have looked at have the headphone jack. In the bedrooms I have a 26" Sanyo(6 years old) and a new 32" Emerson and both have the headphone jack.
Not having a headphone jack is almost a deal buster for me. If I can't find a new tv with the jack is there something simple(adapter?) I can install and use the headphones that way? Also if this can be done would I still be able to mute the tv and still control the volume for the headphones? Thank You.
deltadart22 is offline
Old 01-25-2014, 12:25 PM
8mile13's Avatar
Quoted: 1481 Post(s)
Liked: 827
Connect the TV to a receiver that has a headphone jack. The TV needs a L|R audio input for that (L|R audio has no impact on volume/mute TV). Or you can buy a cable that enables you to connect the Headphone directly to L|R audio (no volume control!).
Or stuff like this inbetween the L|R and headphone for volume control..
http://audio-head.com/the-miniwatt-n4/
For the right (cheap) device start a thread
here -.> http://www.avsforum.com/f/173/2-channel-audio
8mile13 is offline
Old 01-25-2014, 12:43 PM - Thread Starter
I'm a little confused about the no volume control. Where do you control the volume for the headphones? One my RCA you go to the menu and you find headphones setting and adjust it there.
Old 01-25-2014, 01:00 PM
8mile13's Avatar
Liked: 827
When the TV has a headphone jack it often has headphone volume control in the menu.
When your TV has no headphone jack it will have no headphone volume control. In that case you can use stereo receiver (connected to L|R audio) or a volume device (in between L|R audio and headphone) for headphone volume control.
8mile13 is offline
Old 01-25-2014, 02:29 PM - Thread Starter
Old 01-25-2014, 02:50 PM
8mile13's Avatar
Liked: 827
Would this be the easiest way to go? Cordless and I can control the headphone volume.
http://www.amazon.com/Sennheiser-IS410-Ultra-lightweight-Assistive-Listening/dp/B000MGH5W8/ref=sr_1_5?s=electronics&ie=UTF8&qid=1390685230&sr=1-5&keywords=cordless+tv+headphones
That might work. Don't buy it yet. If i were you i would start a thread in the 2 Channel Audio Forum, they can help you to find a similar much cheaper device with good sound quality's wink.gif
8mile13 is offline
Old 01-25-2014, 04:02 PM - Thread Starter
Will do 8 mile. Thanks for the info!
Old 01-25-2014, 04:55 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
If i'm not mistaken the Sennheiser IS 410 does not have an Optical Audio Input, and only accepts Analog audio input from the TV (either via L/R RCA or via 3.5mm headphone plug) so the challenge would be to find a TV that has analog audio outputs - but most current TVs now only have digital Optical Audio output, and no way to control the volume.
If you can't find a TV with a headphone jack or even RCA analog audio ouput, maybe look for a headphone setup that has (A) Digital Optical/Toslink input and (B) it's own volume control.
Another option would be a Digital-to-Analog RCA Audio Converter then connect the headphones to it's RCA output, but the headphones still need to have their own volume control. And most of these converters won't decode the signal properly if you're watching TV using the TV's built-in tuner (optical outputs 5.1 using the tuner, but only 2 channel stereo if you're using external sources).
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 01-25-2014, 06:19 PM - Thread Starter
Well i'm in no hurry so it will give me the time to research all of this. I have a Vizio that I like and will get back to you with the specs and run them by you. Thank You Randy.
Old 01-27-2014, 12:35 PM
scorrpio's Avatar
scorrpio is offline
Old 01-27-2014, 06:53 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Originally Posted by scorrpio View Post
Something like this box will be needed
http://www.amazon.com/Conversions-Technology-Digital-Analog-Converter/dp/B003O509PY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1390851169&sr=1-1&keywords=digital+to+analog+converter
Be sure to set TV's audio output to 'PCM downmix'.
Which TVs have such a setting? None of mine have the capability to change the signal that's coming out of their Optical Audio ports.
But if you're using the TV's built-in tuner then some shows are broadcast with 5.1 audio and these inexpensive converters won't decode 5.1 - you'll just get static or silence.
However they should work fine if watching sources like cable or satellite box via HDMI or Component inputs (which are almost always output at 2 channel stereo).
I don't think there are any current TVs that pass 5.1 from external sources through the Optical output - i think it's a copyright thing.
Randy
Old 01-28-2014, 07:28 AM
scorrpio's Avatar
My mother's 60" Sharp Aquos (bought in 2012) passes DD and DTS bitstreams from incoming HDMI out via optical. Not the HD variety, of course. In the audio settings, the 'digital out' can be set to either 'PCM' or 'bitstream'.
My own 60" Vizio, bought early last year, also has the setting - Digital Audio Out can be set to PCM or Bitstream. Applies to both optical and HDMI ARC. I did not, however, test my TV's ability to pass bitstreams from external sources.
If OP's TV does not provide the option to set the optical to PCM, A more expensive solution will be required.
http://www.amazon.com/Orei-DA34-Digital-5-1-Channel-Headphone/dp/B008EPW7O0/ref=pd_cp_e_3
scorrpio is offline
