will my tv be able to display "deep colors " - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-01-2014, 03:38 PM - Thread Starter
reaper81909's Avatar
Hey, i have a Vizio E601i - A3, and i was just curious if anyone knew if it would display "deep colors". My xbox has the option to turn my color depth up to 36 bits and i dont know if my tv can do it.
reaper81909 is offline
post #2 of 9 Old 02-01-2014, 04:33 PM
Otto Pylot's Avatar
Quoted: 1361 Post(s)
Liked: 853
A lot of devices are capable of displaying deep color. The only problem is that there aren't any sources that are encoded in deep color so my suggestion would be to leave it off or disabled, otherwise you may have video problems because the tv will try to display information that isn't there. This is one of those specs, like HDMI with ethernet, that never really came into play.
Otto Pylot is offline
post #3 of 9 Old 02-01-2014, 05:40 PM
Colm's Avatar
Liked: 94
The specs say the set supports 10-bit color. So, you could set your Xbox to 30 bits.
Colm is offline
post #4 of 9 Old 02-01-2014, 06:50 PM - Thread Starter
My xbox setting fpr color depth doesnt turn on and off. It has the option for 24 bit, 32 bit, and 36 bit. It only says it supports 10 bit? I figured being only 6 months old and a nice brand it would support higher.
post #5 of 9 Old 02-02-2014, 10:31 AM
Otto Pylot's Avatar
Liked: 853
Blu-ray's are encoded in 8 bit RGB/ 24 bit depth. Unless that has changed, there aren't any sources that are encoded in Deep Color. You can certainly upscale to 30 or 36 bit (as most newer blu-ray players can) and quite a few tv's can display Deep Color ( I know my 3 year old LG can) but all you're doing is adding information that isn't there in the first place. What can happen is you either get a very bad looking picture, or depending on the quality of the upscale, banding in the picture in a lot of cases. It's a feature that I wouldn't worry about or even use.
post #6 of 9 Old 02-02-2014, 04:50 PM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2455 Post(s)
Liked: 2231
YCbCr, but who's counting...
Thought #EAA: I wonder how many people know that no one ever says "What we've got here is a failure to communicate." in the movie "Cool Hand Luke" (1967).
tgm1024 is online now
post #7 of 9 Old 02-02-2014, 07:07 PM
Otto Pylot's Avatar
Liked: 853
Thanks for the clarification. Still, Deep Color isn't natively used, correct?
post #8 of 9 Old 02-03-2014, 05:11 AM
8mile13's Avatar
Quoted: 1481 Post(s)
Liked: 827
X.V. Color and Deep Color can be found on some camcorders
here is a thread on that
http://www.avsforum.com/t/1475056/2013-deep-color-camcorders
8mile13 is offline
post #9 of 9 Old 02-03-2014, 09:30 AM
Otto Pylot's Avatar
Liked: 853
Yeah, I know about that. I think the OP was wondering if enabling Deep Color on his XBox would make for a better picture because his Vizio was Deep Color capable (which most tv's are). Other than the above mentioned camcorders, I think it would cause more problems (banding) than anything because of source encoding and isn't really a good idea to enable it. Or has that changed?
Reply OLED Technology and Flat Panels General
