Vizio LED screen issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-19-2014, 06:51 PM - Thread Starter
Liked: 0
Hello,
I recently acquired a VIZIO LED M420SL from a friend since it had some issues and i thought i would try and fix it. As seen in the pictures there are a couple things that happen. First, upon startup there are several vertical yellow lines on the left side of the screen. Those go away quickly, but then the left side of the screen is dark and shows trails of everything. I ordered a TCON board of EBAY and put it in today with no luck. Perhaps it was another bad TCON board ($18.00)? or perhaps there is something else going on?
Thanks for any help on this one.
ID:	127202   Click image for larger version
ID:	127210   Click image for larger version
scottwold87 is offline
post #2 of 6 Old 06-19-2014, 09:08 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
if exact same symptom after replacing tcon = defective lcd display panel = not worth your time or money
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is online now
post #3 of 6 Old 06-20-2014, 05:45 PM - Thread Starter
Liked: 0
Could it be a bad capacitor or a bonding issue?
post #4 of 6 Old 06-20-2014, 05:55 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Sorry, don't have any information or suggestions on attempting any DIY repair on the panel itself (ie bonding) except search youtube.
post #5 of 6 Old 06-20-2014, 06:00 PM - Thread Starter
Liked: 0
Thank you for the response. I have been looking at videos on bonding issues. Do you think this is something it might be. I guess I am wondering what defective lcd means...does that mean bonding?
post #6 of 6 Old 06-20-2014, 06:27 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
For Tv repair shops, defective panel = replace the Tv unless it's under factory warranty. Tv repair shops do not attempt any repairs on display panels. You know as much as I do if you have seen youtube.
Reply OLED Technology and Flat Panels General
