Official OWNERS thread for 2014 OLED LG 55ec9300 Part II - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 1227Likes
post #1501 of 5020 Old 02-25-2015, 10:05 PM
OfficialPG's Avatar
Quoted: 26 Post(s)
Liked: 31
After a 2 week wait for weather delay I got my TV back with a new panel and these are the results.
ID:	569169   Click image for larger version
OfficialPG is offline
post #1502 of 5020 Old 02-26-2015, 07:23 AM
Quoted: 20 Post(s)
Liked: 8
So I'm still very interested in this television, but I have some questions for you guys...
1. I would say that I play video games about 95% of the time. I've been content with my current tv (Sammy F8000) for gaming, with the problems only noticeable in games like Dark Souls or The Last of Us where there are a lot of dark scenes. Everything just ends up looking like a grey fog. Is this panels contrast ratio/black level truly that outstanding when playing games?
2. I'm torn between this tv and the 75'' Samsung H7150 because I love a gigantic screen. But I'm wary of buying it because I decided that if I got another TV, I'd get one without the very annoying flashlights in the corners of the screen. Is that something that happens on EVERY backlit set, or just defective ones?
If the chances are high that I'll end up with another tv with bad lighting uniformity, I'll pull the trigger on the EC9300.
Thanks for any input, guys!
Dcoursey82 is offline
post #1503 of 5020 Old 02-26-2015, 07:41 AM
Mattopotamus's Avatar
Quoted: 1784 Post(s)
Liked: 1535
1) the contrast really is that good. Mind blowing to be totally honest.
2) I totally understand the desire for a larger set. I went from a 65" to a 55" OLED, but the PQ perks are well worth the downgrade. Most LED tvs will show some light bleed, possible flashlighting, or various other backlight problems. The larger you go the more noticeable it will be. To be completely honest a 75" LED would scare the hell out of me. The uniformity issues are sure to be amplified
Mattopotamus is offline
post #1504 of 5020 Old 02-26-2015, 08:08 AM
Quoted: 20 Post(s)
Liked: 8
That's exactly what I was thinking, and why I never went ahead and got it. It sucks that, with the demise of plasma, the only two choices are OLED and LED. So you can pay $3000 for just a 55'' tv, or get a backlit LED that 90% of the time will have bad screen uniformity. (>_<)
Wish I'd pulled the trigger on the 64'' Samsung F8500 when I had the chance a year and a half ago.
post #1505 of 5020 Old 02-26-2015, 08:30 AM
Quoted: 104 Post(s)
Liked: 27
Originally Posted by Chad B View Post
Yes, some significant differences in the white balance, 2 and 20 point. Other things are more consistent but everything interacts so choices made with one control can impact another. There are common trends in things like brightness, contrast, color and tint, but often the numbers aren't exactly the same. Brightness interacts with the white balance adjustments significantly. Sharpness is one thing that is consistent from sample to sample; the controls hardly do anything even at extreme settings, so I just leave them at default.
Some trends are:
ISF Expert mode
contrast in the 90s, but this is only best if you are going to calibrate the 20 point adjustment with a meter; otherwise, contrast around 80 seems to give a better gamma
brightness in the mid to upper 50s (highly dependent on white balance adjustments)
color at or just above default
tint at default or slightly toward green
gamma 2.4
warm
CMS all 0 (major artifacts caused by adjustments)
Chad,
Did you try to adjust the CMS using one of the latest firmware versions ?
I believe the CMS has changed in one of those firmware versions, not fixing it totally but is much better.
On my firmware version (latest european version), I adjusted the CMS and I didn't noticed any (visible) artifacts on any content I watched. I could improve some of the colors from a dE94 of around 3 and 4 to around 1 (Red and Blue).
What I really noticed - and that was only after I run a Color Saturation test, was that although 100% Magenta had a 0.6 dE94, the 50% and 75% Magenta saturation CIE coordinates were almost the same as the 25% saturation, making errors for those two greater than >10dE94...
Only way to fix that was to reset the CMS Magenta to 0,0,0.
All remaining colors did not had this behaviour, in fact they seem very accurate. Max dE I have now is 3.2dE94 on 75% Cyan.
Pepelegal is offline
post #1506 of 5020 Old 02-26-2015, 08:44 AM
Tompa's Avatar
Quoted: 32 Post(s)
Liked: 49
That looks very good.
Tompa is offline
post #1507 of 5020 Old 02-26-2015, 09:05 AM
nowknown's Avatar
Quoted: 194 Post(s)
Liked: 155
It is quite striking the first time you get to a dark room scene illuminated by flashlight in a game like 'The Last of Us'. It takes me back to when I used to game on PC in RGB. Turn off your own lights, crank up the surround, and be ready to bash the 'clickers' with your clicker.
Learn all about me in my profile and take it all very seriously.
nowknown is offline
post #1508 of 5020 Old 02-26-2015, 09:10 AM
mo949's Avatar
Liked: 1184
I couldn't ask for better than that. Is that at 5%?
mo949 is offline
post #1509 of 5020 Old 02-26-2015, 09:18 AM
Quoted: 20 Post(s)
Liked: 8
Then I guess I'll suck it up and try it out. I am pretty excited to see what Bloodborne will look like on this tv. Strolling through the dark, miasmic city streets of Yharnam with these deep blacks should be amazing.
post #1510 of 5020 Old 02-26-2015, 09:41 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Originally Posted by Pepelegal View Post
Chad,
Yes I tried it on an updated 9300 just this past Saturday and it was the same- just like the screenshots in my review.
HDTVbyChadB.com
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is online now
post #1511 of 5020 Old 02-26-2015, 12:08 PM
WLSINWI's Avatar
Any chance that in 2015 the 1080p 55 inch 9300 will be updated to WebOS 2.0? Should I buy a 2014 or wait for a 2015 model?
WLSINWI is offline
post #1512 of 5020 Old 02-26-2015, 12:36 PM
Ken Ross's Avatar
Quoted: 6644 Post(s)
Liked: 7325
As I understand it, it's not just firmware involved in OS2, but also hardware.
So the answer, if this is true, is no.
You have to determine how important OS2 is to you.
You can get a 2015 model that not only has OS2, but more importantly UHD.
Ken Ross is offline
post #1513 of 5020 Old 02-26-2015, 12:57 PM
WLSINWI's Avatar
That was my original intention but I'm not so sure now. The new 4K sets are going to be $5k from what I hear here and in only a 55 inch set I don't know if I am going to see any 4K advantage from my viewing distance of 7 or more feet. I have heard the 1k sets (1080p) would be available through out 2015 at a lot less.
WLSINWI is offline
post #1514 of 5020 Old 02-26-2015, 01:13 PM
Ken Ross's Avatar
Liked: 7325
I assume you mean the 2K sets?
If you're watching a 55" set from 7', yeah, maybe good ol' HD is the way to go.
Lionanimal and MattyPeq like this.
Ken Ross is offline
post #1515 of 5020 Old 02-26-2015, 02:19 PM
WLSINWI's Avatar
Yes is it called 2K then - 1024P. Anyway to put some context in this, I have a 50 inch 720P plasma with 4/3 burn in that I want to upgrade. Going up to 1024P and 55 inches just to watch mostly cable programming and Netflix so perhaps I should just get the current 55 inch 9300 OLED at a $2400 price and be happy.
Lionanimal likes this.
WLSINWI is offline
post #1516 of 5020 Old 02-27-2015, 02:21 AM
Quoted: 104 Post(s)
Liked: 27
Ok Chad, I tried the same test and specially with Red I had exactly the same effects that you had.
With my calibrated settings I don't see any effects but now I don't know if I should be using them. it may create some errors on some part of the color spectrum that I don't see (nor I can test).
post #1517 of 5020 Old 02-27-2015, 04:46 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
I wouldn't recommend using the CMS at all. It has the effect with all colors, though it's far more noticeable on red. The controls seem to effect only a narrow, very sharply defined portion of the color spectrum instead of a more gradual part.
Imagine a huge pile of dirt rising out of the flat ground, say 100 feet wide at the base and narrowing to a gently sloped 10 foot dome at the top, and you want to remove that pile. The LG's CMS is like taking an 8 foot wide bulldozer and running straight down the middle of it. The bulldozer cuts a sharply defined, 8 foot wide path down the middle, but you're left with all the dirt piled up on both sides and a hole in the middle, with huge walls rising up out of the ground on each side of the 8 foot wide path.
Or, imagine the Old Testament story when God used Moses to part the Red Sea to make a path for the children of Isreal to escape the Egyptians. Picture the huge walls of water piled up on each side as the Isrealites walked straight through on dry ground.
The LG's CMS cuts a deep, sharply defined path down the middle of each color just like that.
post #1518 of 5020 Old 02-27-2015, 07:00 AM
Ken Ross's Avatar
Liked: 7325
Chad, this definitely has to be the first OLED CMS analogy linked to the Bible. Between the bulldozer and the Bible, I had to chuckle.
Who would have thought that OLED would rise to biblical proportions.
anthonymoody and Chad B like this.
Ken Ross is offline
post #1519 of 5020 Old 02-27-2015, 09:11 AM
Liked: 1535
As someone who owns both a 4K TV and the ea9800. I can tell you the OLED looks better than the 4K set playing the same show. Streaming content is the only way I can really compare the same thing. House of cards season 2 looks better on the OLED than the 4K set even from a few feet away simply b.c the contrast. Maybe down the road HDR will make a difference, but I wouldn't worry about 4k OLED vs 1080p OLED.....especially in a 55" size.
post #1520 of 5020 Old 02-27-2015, 10:49 AM
Liked: 0
Can someone tell me if it's wrong to play 4k videos on this ec930? Can I damage the tv in anyway? I am currently watching 4k from my pc... Thx.
sirmotto is offline
post #1521 of 5020 Old 02-27-2015, 11:01 AM
Liked: 1535
You cannot mess the TV up by playing trying to play it though.
post #1522 of 5020 Old 02-27-2015, 11:11 AM
x3sphere's Avatar
Quoted: 222 Post(s)
Liked: 129
A true 4K source would look fine on this TV, if you're playing from your PC it just downscales it to fit the resolution anyway.
x3sphere is offline
post #1523 of 5020 Old 02-27-2015, 11:25 AM
jesyjames's Avatar
Quoted: 21 Post(s)
If you play 4k PC content on a 1080p TV the content is down-scaled to match the resolution of the TV. No danger at all.
jesyjames is offline
post #1524 of 5020 Old 02-27-2015, 11:51 AM
Liked: 1535
good to know. I thought it would look super zoomed in.
post #1525 of 5020 Old 02-27-2015, 11:57 AM
radamo's Avatar
Quoted: 173 Post(s)
Liked: 38
I have seen conflicting views on how Directv looks on this set. I am looking to upgrade from a 50" Panny Plasma that is about 8 years old. DirectV seems pretty good right now and I was hoping this set would be even better. But local stores don't have the option to view Directv signal on this set.
radamo is offline
post #1526 of 5020 Old 02-27-2015, 02:17 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 3013 Post(s)
Liked: 3208
Standard content thru Directv will look about the same, now 720P and up will blow your mind ! Your plasma will not even be close.......which is pretty hard to say, but a fact is a fact.
Cleveland Plasma is online now
post #1527 of 5020 Old 02-27-2015, 02:59 PM
radamo's Avatar
Quoted: 173 Post(s)
Liked: 38
Thanks for the reply Chris. The more I read, the more I am leaning this way.
radamo is offline
post #1528 of 5020 Old 02-27-2015, 03:47 PM
kinglm's Avatar
Quoted: 197 Post(s)
Liked: 166
Appreciate this comparison. Thanks for sharing your experience.
kinglm is offline
post #1529 of 5020 Old 02-27-2015, 04:08 PM
WLSINWI's Avatar
Appreciate the info. I'm convinced the 1020P 55 OLED is the best choice for my needs and usage. Now I just am waiting to see a $2500 price tag on a 2015 manufactured set. Quality should be at a high uniform standard by then. I see that LG has the OEM price at $3500 for this set now so my trigger price is not so unreasonable.
WLSINWI is offline
post #1530 of 5020 Old 02-27-2015, 04:18 PM
Quoted: 17 Post(s)
Blu-ray UHD is less than a year away though.
It will be very interesting to see a Blu-ray on the 55EC9300 and a Blu-ray UHD (same movie) on the 55EF9500, one close to the other.
Because Blu-ray UHD will be my best reason to own a UDH tv.
I know that they say at 55' you can't even see a difference... but I would love to try!
I'm not hating. I'm actually about to buy a 55EC9300.
MattyPeq is offline
Reply OLED Technology and Flat Panels General
1080p , great television set , hdtv , lg 55ec9300 , oled , yamaha ats-1060
