LG OLEDs - how to enhance near black detail - AVS Forum | Home Theater Discussions And Reviews
 680Likes
post #1 of 2257 Old 09-13-2016, 12:02 PM - Thread Starter
buzzard767's Avatar
Quoted: 1650 Post(s)
Liked: 2426
One of the biggest LG OLED criticisms is that near black detail is substandard compared to other display technologies. Why is that? "Black" is 0% of 100% White. The OLED can produce perfect, solid, zero luminance black, something the human eye cannot see. Consequently, OLED 0.5% is also very dark and quite difficult to detect. When patterns are displayed in increased luminance (1% 2% 3% etc.) they become more and more visible.
Yeah but my plasma easily shows .5% black blah blah blah
Let's put this into perspective. 0% on my Samsung PN51D8000 plasma is about the same as 3 or 4% on my LG E6P OLED. Of course you can see near black on the plasma because you can see it's version of solid black in the first place.
Perhaps your favorite movie was mastered on a plasma. If you had this same display, calibrated exactly the same, you would be able to see what the director intended. This is image fidelity, and the reason calibration exists. We know there is detail we aren't seeing on the OLED because we see it with other displays. What to do?
My equipment:
Colorimeter - Klein K10A capable of reading down to 0.00006 cd/m2
Software - ChromaPure 3
Display - 2016 LG 55E6P OLED
You CANNOT increase near black detail by raising the Brightness control without raising Black itself. Yes, you can see more detail but the infinite Contrast Ratio would be obliterated and "Contrast is the most import single picture quality" (THX among others).
Decreasing Gamma brings content out of black faster. We are only interested in the bottom .5% and this is how you do it.
1. Set Black level properly with the Brightness control. It is difficult to do with OLEDs when using a visual pattern like the AVSHD or Ted's Disc patterns mainly because video 17 is almost too dark to see. I can set Brightness precisely using my K10-A but non calibrators will have to use their eyes.
2. Lower Gamma at the dark end.
2A) On LG 2016 OLEDs: White Balance > 20 point > 5% > Luminance > increase
2B) On LG Pre 2016 OLEDs: White Balance > 20 point > 5% > Red > increase. Do the same equally for Green and Blue.
On my E6P, if Brightness is one click too high, raising WB 5% Luminance above 18 will elevate the black level so be careful. It's better to start with Brightness 1 click too low than 1 click too high. On my TV I can set WB 5% luma all the way to max (50) without raising the Black level.
Here is what happens to Gamma. Blue is WB 5% Luminance 0, Green is Luminance 20, and Red is Luminance 50. Notice that Gamma from 10 through 95% is exactly the same and that is what we want. Bringing out near black detail is all about the bottom end.
I have found a content scene that is perfect for watching near dark detail come alive as 5% Gamma is lowered. PAUSE "The Dark Knight" at 0:06:33, and watch what happens to the detail around the building's windows as you lower the gamma by increasing the 5% WB luma. On pre 2016 models you need to increase R,G, and B equally to keep 5% color somewhat accurate but you should start by increasing Green as this is the channel where luminance is carried.
On the left is The Dark Knight 0:06:33 with 5% luma set at 0, and on the right is the result of raising 5% luma.
If you don't have the Bat Man movie, pause something else where you know you are losing detail.
Have fun, and good luck.
I know I'm going to get nagged for settings and my response is always the same: "Every display is different."
BUT, here are the basics.
Picture Mode - Expert Night
OLED Light - 28
Contrast - 80
Brightness - 57
Gamma Preset - BT.1886
NEW 15Sep16
Forum member Wizziwig has created an outstanding black pluge pattern video which is downloadable in this post. It clearly shows how lower gamma at 5% increases shadow detail and will enable you to set up Brightness and Gamma properly.
I have discovered that in certain modes, raising the White Balance 5% Luminance or RGB (pre 2016 models) beyond a certain point can elevate the black level. This is extremely undesirable. If you're viewing the entire screen your eyes can play tricks on you and you may not see it. To help detect a black level rise, I suggest you use a "poor man's" meter. Some of us have high performance, all black, dedicated theaters and we use black velvet surrounding the screen for several feet on the walls, ceiling, and floor to increase room/screen contrast and minimize reflections. The best is likely JoAnn Fabrics Royalty 3. In a dark room, hold a piece of the velvet up against the screen (black area containing no above black content). You will not be able to distinguish the edge of the velvet from the screen itself. As you use the technique shown in this thread to lower 5% gamma, if the black level elevates, you will see it immediately. Raise gamma until the screen is once again totally black. Do"
1/25/2017
Interesting new info regarding the dark end while displaying HDR content. I'm not near my E6P to test it but check out this post.
"Not sure if my finding should be posted in this thread, but I found out that in HDR settings, lowering Blue to -1 at the lowest IRE point truly improves dark areas. It might be panel- dependent but I encourage any of you with uhd players to try this out on Any of your titles in HDR. Here is Suicide Squad before/after"
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #2 of 2257 Old 09-13-2016, 12:07 PM
chunon's Avatar
Quoted: 2444 Post(s)
Liked: 2194
Good stuff Buzz !
prongs44 likes this.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 2257 Old 09-13-2016, 12:13 PM
wxman's Avatar
Quoted: 3980 Post(s)
Liked: 2804
Curious if you had the chance to measure what gamma was at 5% after the change. Did you make adjustments to 2 point to have such a high starting point for brightness with 1886? For me I can start with a brightness of 50 and raise 5% Luminance 15 points, or use a brightness of 51 and raise around 8 or 9 points. 52 with no changes to luminance produces a glow at 0%.
LG 65EF9500
LG 65E6P
wxman is online now
post #4 of 2257 Old 09-13-2016, 12:29 PM
Quoted: 92 Post(s)
Liked: 49
On my set, anything above 52 brightness loses the pure blacks of these sets - i.e black bars look grey.
Garry Allen is offline
post #5 of 2257 Old 09-13-2016, 12:31 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
Ya see? Already questions about my settings. lolololol
5% Gamma is not written on the chart but it IS the far left measurement.
As to my settings, they are what they are and when I say that in this particular configuration Black is Black and remains Black it means exactly that.
You'll just have to experiment with your LG. Remember what I said? "Every display is different."
Buzz
post #6 of 2257 Old 09-13-2016, 12:36 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
C'mon guys.
My settings have nothing to do with your TV. Do 1 & 2 above, watch what happens with paused dark content, and report what you see.
I'm especially interested to hear from the pre 2016 owners. My daughter has my old EF9500 but she's 200 miles away and I'm not going there just to see what happens on her OLED.
Buzz
post #7 of 2257 Old 09-13-2016, 12:42 PM
wxman's Avatar
Liked: 2804
As to my settings, they are what they are and when I say that in this particular confiuration Black is Black and remains Black it means exactly that.
Thanks. I noticed that your blue was near 2.3, green 2.0 and red 1.7. Since 1886 starts out with a flat 2.4 gamma, wouldn't raising the 5% luminance affect them all equally? IOW, would they all be closer to 2.0?
LG 65EF9500
LG 65E6P
wxman is online now
post #8 of 2257 Old 09-13-2016, 12:52 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
No. The luminance control directly affects gamma, same as the gamma 10 point controls on the last three years Panasonic plasmas.
OHHHHHH. Do you mean the colors on the graph? They are the different Luminance settings. 10% on up is all Blue because that was the last setting measured (Luminance - 0). It fell directly on top of the red and green colored dots.
Buzz
post #9 of 2257 Old 09-13-2016, 12:54 PM
Quoted: 92 Post(s)
Liked: 49
C'mon guys.
I'm not trying to be awkward. I appreciate your guidance. It worries me that if panels are that different, then altering the dark end might introduce problems.
For example, I increased 5 IRE by 15, and on my set, you get a 'waxy' outline to shadows. I have read elsewhere that the luminosity setting on these sets (2016) should not be touched, as they introduce artefacts. So just sticking to adjusting the RGB individually, and yes, gamma is improved, but there is still a detriment to the shadow detail, so it might be best to increase sparingly.
Thanks again for your guide.
post #10 of 2257 Old 09-13-2016, 12:56 PM
Wizziwig's Avatar
Quoted: 1212 Post(s)
Liked: 856
So what was the measured gamma below 5%? You can increase shadow detail on any TV by lowering low-end gamma. That doesn't mean it's correct or what the director intended. You may very well end up with the opposite problem of revealing things in shadows you're not supposed to see (such as excessive noise). Ideally we want every TV to track BT.1886 gamma (or equivalent 2.4 with OLED) across the entire range. If you're watching a low APL scene in a dark room with dark-adapted eyes, you should have no trouble seeing the intended shadow detail.
Wizziwig is offline
post #11 of 2257 Old 09-13-2016, 12:58 PM
wxman's Avatar
Liked: 2804
Yes, I was curious how you got 5% to read 2.3 for blue, 2.0 for green and 1.7 for red if you only raised luminance. I would think they would all be the same at 5% after raising luminance if it starts out at a flat 2.4.
LG 65EF9500
LG 65E6P
wxman is online now
post #12 of 2257 Old 09-13-2016, 01:18 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
I understand but the meter doesn't lie. I can set Black MUCH more accurately than non calibrators. On other modes my Brightness is usually around 52 - 53.
The wax you refer to is probably the "glow" that some owners have seen. I don't have that but suspect it might have something to do with luminance uniformity across the entire screen.
Yes, you are half correct about the artefacts. They are not so much introduced as enhancing that which is already there. 1080 upscaled on the LGs always produces artefacts. Do the paused content test with dark content I talked about. You'll see artefacts no matter where the Luminance is set. Now go back to your normal viewing distance and see if it's offensive.
More: the 4k content I've seen via USB has zero artefacts, and increasing Luminance to 50 induces nothing.
People with 4k Blu-Ray players will have to test my ideas on 4k content and I hope to hear from those peeps before long.
I won't be buying a 4k BD player until one has H.235, Dolby HDR, AND Darbee technology - hopefully the upcoming Oppo.
Garry Allen likes this.
Buzz
post #13 of 2257 Old 09-13-2016, 01:29 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
Ummm, I know a lot about everything you're referring to. Doing what I'm doing DOES NOT bring out below black content. And no, 0.5% on an OLED is extremely difficult to see whereas 0.1% is easy to see on my plasmas.
"Blue" is 5% luminance set at 0.
Green is 5% luminance set at 20
Red is 5% luminance set at 50
wxman likes this.
Buzz
post #14 of 2257 Old 09-13-2016, 01:39 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
I used the standard ChromaPure Gamma page and it only goes down to 5%.
Buzz
post #15 of 2257 Old 09-13-2016, 01:44 PM
wxman's Avatar
Liked: 2804
Thanks, that's where I got confused. I have the E6 and only raised the luminance control, and did not adjust r,g and b separately.
LG 65EF9500
LG 65E6P
wxman is online now
post #16 of 2257 Old 09-13-2016, 01:46 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
Yes! On 2016s use the luminance control because it's the easiest, fastest way. The result is the same as raising R, G, & B and that is what needs doing on pre 2016s because they don't have a luminance control.
Buzz
post #17 of 2257 Old 09-13-2016, 01:52 PM
Quoted: 92 Post(s)
Liked: 49
You are likely spot-on with this. I have only been adjusting while watching Netflix standard source material. I do prefer though, to calibrate to a 'middle ground', in that 75% of my viewing is streaming video up to 4K, so it is a delicate balancing act between artefacts and crushing shadow detail.
To try and illustrate the side-effect of increasing luminosity too far on poorly compressed material - it gives people in the shadows a kind of 'Lego hair' effect, in that there is no shadow detail, but it stands out prominently.
Either way, adjusting as in your OP, increases shadow detail so thanks again. Just adjust it to what you will be predominantly watching though.
post #18 of 2257 Old 09-13-2016, 02:10 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
To add: "If", on 2016s, I were calibrating for pay, I would use The R, G, & B controls for proper White Balance.
For non calibrators, if you display a 5% White pattern and see discoloration I recommend not using the Luminance control. Instead, increase R, G, & B 10 or 15 points and then readjust according to what you see. For example, it 5% looks reddish, reduce Red a bit OR increase Green and Blue OR both.
Buzz
post #19 of 2257 Old 09-13-2016, 03:35 PM
wxman's Avatar
Liked: 2804
When it comes to lowering gamma at 5% it all comes down to choice. In reality, true 0% is completely black, and 0.5% should be virtually impossible to see with the human eye with 1% a little better. As buzzard767 said, on plasma and LED tv's, their 0% looks like a 3% slide on OLED, and 1% would look closer to 4%. So that detail at 0.5% is much easier to see since it would look like 3.5% on OLED. However, IMO, 0.5% should really look like 0.5%, not 3.5%. So very little if any detail should be seen. For all these years prior to OLED, we were use to seeing that detail at 0.5%, when in reality, what we were seeing was wrong due to the limitations of that technology. So in reality, detail at less than 1% (if it is truly 1%) should be extremely hard to see with the eye. We really aren't losing detail at all. We finally have a technology that shows us near black correctly.
LG 65EF9500
LG 65E6P
wxman is online now
post #20 of 2257 Old 09-13-2016, 04:04 PM
Wizziwig's Avatar
Liked: 856
Calibrating for correct shadow detail is heavily dependent on environment and no single setting will work best for everyone.
In a room with zero ambient lighting and a low-apl scene without bright objects that force your eye iris to close, even 0.5% should still be visible on a calibrated display with zero blacks.
I once watched a front projector under such conditions and had no trouble seeing that black fields were still glowing visibly even at 0.0001 nits. This was after sitting in the dark room for a few minutes to let my eyes adjust. That projector used a dynamic iris to reach that low but even without it the black floor was at ~0.0005 nits (whites ~75).
Assuming your white level is set at some common value like 100 nits, 0.5% level with BT.1886 would correspond to:
100 * (0.5/100.0)^2.4 = 0.0003 nits with OLED blacks at zero.
For other values, you can use the formula yourself:
L=a*((V+b)^2.4).
V is the input video input signal, normalized to [0,1]. a is a constant chosen so L takes the monitor's white value when V=1. And b is another constant chosen so L takes the monitor's black value when V=0. Source.
For OLED, b is zero.
No doubt a plasma or LCD would be brighter at 0.5% because of the raised black level but 0.0003 nits is still within human (or Klein K10A) visible range. If you're in a room with ambient lighting, then obviously your black and white levels will appear higher regardless of display and you need to adjust the calibration.
Assuming the LG OLEDs are tracking gamma correctly near black (unknown since nobody I'm aware of has measured it precisely) then the black crush people are complaining about is mostly the result of incorrect calibration for their environment. Buzzard's recommendations would address that but you're doing this blind without a meter. Whatever black crush still remains after calibration is caused by limitations of human vision and I would not try to correct for it. We can't see black detail when it's close to a brighter object even in real life.
soren and Pheux like this.
Wizziwig is offline
post #21 of 2257 Old 09-13-2016, 04:20 PM
ll Viper ll's Avatar
Quoted: 140 Post(s)
Liked: 106
Here's a message I sent to Buzzard with an edit or two (since 2015 owners should contribute too!)
"Everything you said was spot on. Green boosted shadow detail the most but I didn't want to change the white balance too much down there at 5% so I brought r and b up to +15 too. Much farther and I did start getting color artifacts in the shadows edit: shadows around objects. I will have to double check to see if the 'waxy' outlines around objects another user mentioned are there as a result of the ire 5% specific raising. I did not notice them if they were.
pretty satisfied with it so far. I even made a post on the 9100 owners thread when someone asked about how to keep the shadow detail/less vignetting of 1.9 gamma in darker scenes while getting the better saturation of 2.2/2.4 in mid tones.
I told them about your approach. I settled on 2.4, brightness 53 (any higher and floating blacks can occur, on MY set) and the aforementioned white balance settings. Oled light is typically set between 25-50 for dark room viewing, and not usually higher than 65 at all.
DrJayDub likes this.
ll Viper ll is offline
post #22 of 2257 Old 09-13-2016, 04:34 PM
Wizziwig's Avatar
Liked: 856
Don't need any fancy charts or pictures. Just a list of light readings for 100% and 0.5% to 5% at 0.5% intervals. 11 total readings. Thanks.
If comments from Panasonic are accurate, I suspect they are using a 3D LUT to improve near-black tracking. Not much else they could be doing since they are buying the panels from LG.
Wizziwig is offline
post #23 of 2257 Old 09-13-2016, 05:41 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
The director intends the viewer to see what he sees, and if he's mastering on an LCD or PDP with inferior black level you'll not see it on an OLED. Thus my method to increase visibility of near black.
"Things in shadows you're not supposed to see" -- "Excessive noise" has nothing to do with it. If it's there, it's there. Period. If you're referring to seeing below black content, that is impossible because black level is set to 0.000. You cannot bring out something below it like little genies...... The only way to see below black is to elevate the black level itself with the Brightness control. I know you understand this but others may not.
In a room with zero ambient lighting and a low-apl scene without bright objects that force your eye iris to close, even 0.5% should still be visible on a calibrated display with zero blacks. It is, but just barely and totally unlike non OLED displays.
I once watched a front projector under such conditions and had no trouble seeing that black fields were still glowing visibly even at 0.0001 nits. Was this a laser PJ? This was after sitting in the dark room for a few minutes to let my eyes adjust. That projector used a dynamic iris to reach that low but even without it the black floor was at ~0.0005 nits (whites ~75).
L=a*((V+b)^2.4).
No doubt a plasma or LCD would be brighter at 0.5% because of the raised black level but 0.0003 nits is still within human (or Klein K10A) visible range. If you're in a room with ambient lighting, then obviously your black and white levels will appear higher regardless of display and you need to adjust the calibration. Other than increasing overall luminance, adjust it how?
Assuming the LG OLEDs are tracking gamma correctly near black (unknown since nobody I'm aware of has measured it precisely) then the black crush people are complaining about is mostly the result of incorrect calibration for their environment. Buzzard's recommendations would address that but you're doing this blind without a meter. Whatever black crush still remains after calibration is caused by limitations of human vision and I would not try to correct for it. If the director wants me to see what he sees on his LCD when watching my OLED, lower dark end gamma. I don't see any other way. We can't see black detail when it's close to a brighter object even in real life.
Don't need any fancy charts or pictures. Just a list of light readings for 100% and 0.5% to 5% at 0.5% intervals. 11 total readings. Thanks..
I don't have a source for such patterns. PM me the RGB triplets and I'll see what I can do.
wxman likes this.
Buzz
post #24 of 2257 Old 09-13-2016, 05:58 PM
Quoted: 150 Post(s)
Liked: 66
One of the biggest LG OLED criticisms is that near black detail is substandard compared to other display technologies. Why is that? "Black" is 0% of 100% White. The OLED can produce perfect, sold, zero luminance black, something the human eye cannot see. Consequently, OLED 0.5% is also very dark and quite difficult to detect. When patterns are displayed in increased luminance (1% 2% 3% etc.) they become more and more visible.
My equipment:
OLED Light - 28
Contrast - 80
Brightness - 57
my panel glows at anything above 51 brightness in a black room .but i did do the batman test and have my luminance at 5
Dave Scurrah is offline
post #25 of 2257 Old 09-13-2016, 06:07 PM
wxman's Avatar
Liked: 2804
If we only knew which ones were being mastered on OLED! Of course then I would have to create separate isf mode just for OLED mastered movies.
LG 65EF9500
LG 65E6P
wxman is online now
post #26 of 2257 Old 09-13-2016, 06:12 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
Yeah. That sh$t can drive you crazy. I'm a set it and forget it guy myself, including motion controls for differing content.
Buzz
post #27 of 2257 Old 09-13-2016, 06:15 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
Your Brightness setting is YOUR Brightness setting and that is the only way to do it. What display do you have and what was the quality of near black performance when you raised 5% luminance?
Buzz
post #28 of 2257 Old 09-13-2016, 06:51 PM
Quoted: 150 Post(s)
Liked: 66
65 e6p ,my settings are mind u by eye till i get pro calibration ,25 oled light ,80 contrast 51 brightness set in pitch black room eyes adjusted via disney wow disc all black screen started at 60 lowered 1 click every min till lowering it anymore did nothing to screen luminance ending up at 51 ,2.4 gamma ,the 5 was a conservative adjustment via know content ,plus i have my zt60 in the same room and to my untrained eyes the oled has better shadow detail .the zt is pro calibrated fyi
post #29 of 2257 Old 09-13-2016, 06:53 PM
Quoted: 150 Post(s)
Liked: 66
I'm very green at this btw
post #30 of 2257 Old 09-13-2016, 06:59 PM - Thread Starter
buzzard767's Avatar
Liked: 2426
Without a very good meter (iD3 variants the bare minimum) setting by eye is all you have and that's fine.
I've had both my EF9500 and my E6P side by side with my VT60 (also pro calibrated by some little known THX certified guy) and when I do a simultaneous display of the Disney WOW disc flashing stars pattern my eyes hurt from bugging out and my brain says "I ain't never buying a display without 0.000000000 black level again." lol
TimWelborn likes this.
Buzz
Reply OLED Technology and Flat Panels General
