Sony A1E 4K HDR OLED TV at CES 2017 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1109Likes
post #631 of 1638 Old 03-06-2017, 08:27 AM
TWD
TWD's Avatar
Quoted: 48 Post(s)
Liked: 42
Originally Posted by Grendell View Post
How did you like the Samsung QLED ?
Also, did you look at the Z9D off axis? Word is it's not good in this department.
I liked the QLED a lot running the demo material. It looked as good as anything I saw in the showroom environment.
I have mixed feelings about the WLED. The panel mount on the wall was nice. I think they used magnets. However, the sound bar and connection box was pretty big and sticks out pretty far from the wall. Kind of defeats the purpose of having ultra thin wall mount panel IMO.
TWD
TWD is offline
post #632 of 1638 Old 03-06-2017, 01:59 PM
JJxiv1215's Avatar
Quoted: 266 Post(s)
Liked: 275
Originally Posted by Cleveland Plasma View Post
That setup looks real nice, like the red throw rug
Originally Posted by pkeegan View Post
I'm really impressed with your modified stand(s). Would you mind sharing the man and model number of the new TV mount? One of the reasons I haven't replaced my 12 year old crt TV is how to elegantly incorporate a new TV. Your solution looks great!
Thank you! I just looked it up. It's a Peerless SGL-B01. I bought it 4 years ago - I'm not sure if they still make it. I'd try reaching out to the manufacturer directly, maybe.
I ended up painting the bracket white to match the window mullions behind it (vs the red in the original image) to give the TV a "floating" look when the blinds are open.
The mount is super strong and heavy. It was tough enough to hold my DIY plywood 92" screen for the few months I tried a projector system.
#HozayCinema 9.1
Sonus Faber Venere - Verus Grand Center
Emotiva XPA-3 - Epik Empire - Vizio P75-C1
Denon AVR-X4000 - Sony PS4 - Oppo UDP-203
JJxiv1215 is offline
post #633 of 1638 Old 03-06-2017, 04:31 PM
pkeegan's Avatar
Quoted: 94 Post(s)
Liked: 126
Thanks. The stand is still available on Amazon.
pkeegan is offline
post #634 of 1638 Old 03-07-2017, 08:01 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 3006 Post(s)
Liked: 3208
QLED is nice, but very expensive for an edge lit TV......
Cleveland Plasma is offline
post #635 of 1638 Old 03-07-2017, 12:30 PM
Dhalmo's Avatar
Quoted: 217 Post(s)
Liked: 128
I'm trying to look through the marketing speak and figure out exactly what features the A1E will have in terms of PQ and image processing.
The promotional page states the following: "4K HDR Processor X1 Extreme provides the ultimate 4K HDR viewing experience by incorporating three picture-enhancing technologies: object-based HDR remaster, Super Bit Mapping™ 4K HDR and dual database processing."
I would assume 'object-based HDR remaster' means one of two things, either they are taking SDR images and "upscaling" the range to a simulated HDR or they are taking static HDR10 metadata and converting it to a simulation of Dynamic HDR (a la Dolby Vision). I've hear similar things with the LG 2017 forum and some inklings in this thread. From the Sony product description page, "With Object-based HDR remaster (1), the color in individual objects on screen is analyzed and the contrast adjusted, unlike most TVs where contrast is only adjusted along one black-to-white contrast curve (2). Because objects are remastered individually, this TV can reproduce greater depth, textures, and more real pictures". I'm curious if this algorithm can properly define "objects" wherein one end and another begins a la image recognition on the fly. I know other product lines use this remastering.
Super Bit Mapping (SBM) I take to mean is the proprietary algorithm that will enhance the standard SDR HD to SUHD (4K HDR) in combination with the object-based HDR remaster described earlier. This supposedly allows for better color gradation quality. Again, this is a type of "upscaling" of taking ubiquitous HD content and boosting it's presentation artificially.
Dual database processing I take to mean noise reduction and direct pixel upscaling. From the product page, "One database is used to clean the picture, reducing on-screen noise. The other is used to upscale the resolution, improving clarity. These two powerful image improvement databases work together, dynamically improving pixels in real time. Each database has tens of thousands of references, amassed from our experience creating content for TV and movies over the years."
Given the above, I think the majority of improvement we expect to see from the A1E versus just an LG 2017 OLED is the above applied to non-SUHD sources (i.e. SDR HD) as the image is conditioned and cleaned up for better perceived PQ. I'm just as interested in how the motion handling is done and how that will make a difference compared to LG OLEDs, in combination with the above.
Needless to say, I'm excited at the prospects of purchasing the A1E if the claims are true.
Desk. and JJxiv1215 like this.
Dhalmo is offline
post #636 of 1638 Old 03-07-2017, 10:39 PM
On april 10 there will be a live stream of the a1 on youtube for review, so can we expect the release date to be in april?
kclawrence is offline
post #637 of 1638 Old 03-07-2017, 10:50 PM
ray0414's Avatar
Quoted: 10163 Post(s)
Liked: 9136
Thursday March 9th, the Sony A1 page with value electronics goes live with prices and preorder options.
ray0414 is offline
post #638 of 1638 Old 03-08-2017, 03:46 AM
JJxiv1215's Avatar
Quoted: 266 Post(s)
Liked: 275
Looks like release day is in April.
Anybody else planning on being a first adopter of this unit?
dr0z77 likes this.
#HozayCinema 9.1
post #639 of 1638 Old 03-08-2017, 05:43 AM
Sebring5's Avatar
Quoted: 269 Post(s)
Liked: 195
Yes,will order as soon as preorder goes live.
Oppo 203 4k UHD, Meridian Audio Core 200 & M6 Active Speakers, Sony A1E 65" OLED 4k UHD, U-verse
Sebring5 is offline
post #640 of 1638 Old 03-08-2017, 05:54 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
If its priced the same or lower than the Z9D I'm in....But was hoping for full reviews from Steve Withers or the Germans as they seem to get first crack at everything...
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #641 of 1638 Old 03-08-2017, 06:26 AM
ChicagoChris's Avatar
Quoted: 64 Post(s)
Liked: 65
OK Place your bets!
The LG 55" is going for $3k and the 65" going for $4500 on Amazon right now. If we get pricing tomorrow, how much of a premium??
I'll go with 20% as a guess.
ChicagoChris is offline
post #642 of 1638 Old 03-08-2017, 06:31 AM
dancolt's Avatar
Quoted: 223 Post(s)
Liked: 251
Originally Posted by ChicagoChris View Post
OK Place your bets!
My guess, 65" will be $5,500.
dancolt is offline
post #643 of 1638 Old 03-08-2017, 07:12 AM
JJxiv1215's Avatar
Quoted: 266 Post(s)
Liked: 275
I'm inclined to believe that they wouldn't want to go higher than their "flagship" display, as Sony still considers their Z9D their top of the line model.
With this in mind, I believe the A1E will be less (for the same screen size) than the $5,500 MSRP currently being used for the 65" Z9D.
Reviews be damned, lol. LG's amazing panel with that X1 hardware should resolve my ONLY complaint with the LGs, and that's their yucky motion. It's the only reason I returned my B6.
OK Place your bets!
For the reasons above, I want to say lower than 20% and lower than the 5.5 Dancolt says.
I'm putting my wager in at 5.
What's the bet here?
Grendell and Dhalmo like this.
#HozayCinema 9.1
post #644 of 1638 Old 03-08-2017, 07:28 AM
vaktmestern's Avatar
Quoted: 810 Post(s)
Liked: 589
All tv makers claim they have the best set...
More they brag less i belive them like Sony is doing.
Invincible11111 likes this.
Lg G6 Oled tv (isf calibrated) Oppo 203 Uhd player.
vaktmestern is offline
post #645 of 1638 Old 03-08-2017, 07:40 AM
ValkyrieStation's Avatar
Quoted: 40 Post(s)
Liked: 143
I'm definitely in for the 65". Robert @ VE expects his 1st allocation of the 55"/65" in Mid-April. I think whoever can get it early from a brick & mortar will be our first owner. And I will feel very sorry for this person because they are going to get bombarded like crazy with questions and near-black 1-5% slide requests. Such is the AVS way of life.
I'm going to try to not add more discussion into the price talk per forum guidelines, but I will just leave these here...
http://www.neogaf.com/forum/showpost...postcount=3942
And the chart from January...
mikey94025 and tigertim like this.
The tech (r)evolution continues...
2017 - 65" A1E OLED | 2007 - 40" XBR3 LCD | 2002 - 20" FD Trinitron WEGA CRT
ValkyrieStation is offline
post #646 of 1638 Old 03-08-2017, 07:47 AM
Quoted: 64 Post(s)
Liked: 65
Well..there you go
post #647 of 1638 Old 03-08-2017, 08:47 AM
Quebecker's Avatar
Quoted: 1073 Post(s)
Liked: 663
OK Place your bets!
The thing is, the LG will end up at something like 1.5k in November. Sony won't.
Quebecker is offline
post #648 of 1638 Old 03-08-2017, 10:17 AM
Industry Insider
Liked: 3208
post #649 of 1638 Old 03-08-2017, 10:22 AM
gorman42's Avatar
Quoted: 96 Post(s)
Liked: 51
Is there solid info previously on this thread regarding motion processing? From what's just been reported as Sony's "marketing speak", I don't see anything referring motion processing.
ChicagoChris likes this.
Seriously. AVS is a place where you go to learn to be unhappy. - Bear5k
gorman42 is offline
post #650 of 1638 Old 03-08-2017, 11:11 AM
Quoted: 64 Post(s)
Liked: 65
Perhaps but Sony will have to come down and be in the ballpark to be close. They are going to want to sell TV's as well and if the LG is $1500 and the A1 is $3000, the average Joe is not going to bite on that. Furthermore, there will have to be some serious differentiators on the Sony as well.
Its all fun though! Looking forward to reviews and prices incoming very soon.
post #651 of 1638 Old 03-08-2017, 11:16 AM
anthonymoody's Avatar
Quoted: 687 Post(s)
Liked: 526
So true! "He who starts the Official Owners' thread is asking for it!"
First of all, how dare someone post on Neogaf and not here!
Second, poor N8. He was rather pilloried by some for that chart iirc. I have my doubts that the 77" will be $15k but we'll find out shortly.
Finally, I'm surprised the official pricing didn't leak by now. Pretty good job by Sony keeping things under wrap until pre-orders go live tomorrow.
ValkyrieStation likes this.
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is offline
post #652 of 1638 Old 03-08-2017, 11:35 AM
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 3037
The difference is that LG will sell well over 1M OLED TVs this year while Sony is only rumored to be selling 100,000.
If there is any truth to that rumor, the A1E is competing against the LG W or at least G-Series and not the E/C/B-Series TVs aimed at the 'average Joe' .
I expect the A1E prices to track within the range between W and G-Series and to never get anywhere close to where LG prices the B/C-Series when things get serious this Holiday Season...
fafrd is offline
post #653 of 1638 Old 03-08-2017, 12:07 PM
robert9674's Avatar
Quoted: 1080 Post(s)
Liked: 690
I think 5999 for the 65 inch A1E. There is a video of the 55 inch A1E and its price of 3999. No where near the w7 price.
Sony A1E
Triton one
robert9674 is offline
post #654 of 1638 Old 03-08-2017, 12:32 PM
JJxiv1215's Avatar
Quoted: 266 Post(s)
Liked: 275
It's all speculative, based on the way that the Sony Z9D handles motion (albeit, a different display tech), and how Sony as a whole in its processing has handled motion processing. Since the Sony Z9D has the same chip the A1E will have, this led to the whole "Sony must handle motion better than LG".
That's the primary issue I see people having with the LG OLEDs anyway, the motion is jarring to those who notice it/are affected by it. TruMotion is a waste of time, and you can see the threads/posts made by people trying to finagle a way around it by trying RealCinema settings, even using PC mode, etc, etc.
For some, that final tweak to an amazing panel otherwise is worth the price difference.
Heck, it is for me. I swore I'd never pay over 3K for a TV since I got a 5020, ZT60, JS8500, B6 for less than that number, but here I am. At this point I'm willing to pay 5K to have the display I want, even if it means $2,000 just for better motion.
I am tired of compromising. And I am hopeful that Sony, as they are wont to do, has resolved the motion problem.
But for most people, the LG OLEDs are sufficient, as they do not see the motion issues, or are not bothered by it, or are not bothered by it enough to care to upgrade.
It is all fun!
Although with only 100k panels from LG, I don't think this TV is meant for the average Joe - as is the Z9D. Sony has plenty of other models meant for the average Joe.
I dont think there will be too many differences besides motion on the Sony. Maybe alleviating banding and better near-black? It's all guesswork from me at this point.
Once I put my preorder in you better believe I'm starting that thread! The pricing has us all antsy for sure.
But to those of us considering it, I bet a good chunk is people who had the LG OLED, weren't satisfied due to motion (from what I read here anyway), and are wondering what Sony can do with the same panel.
Desk. and robert9674 like this.
#HozayCinema 9.1
post #655 of 1638 Old 03-08-2017, 12:38 PM
losservatore's Avatar
Quoted: 2670 Post(s)
Liked: 2443
We will have our pre-orders up as well......its just about that time guys
But you thought that this Oled probably wouldn't make it to a product.
video_analysis likes this.
losservatore is offline
post #656 of 1638 Old 03-08-2017, 01:40 PM
tanman's Avatar
Quoted: 175 Post(s)
Liked: 134
^^ Lots of people here thought that!
tanman is offline
post #657 of 1638 Old 03-08-2017, 04:51 PM
Viper32's Avatar
Quoted: 1266 Post(s)
Liked: 945
It is all fun!
So you are going to start a owners thread with just a pre order. Wow
Sent from my SM-G925V using Tapatalk
Current Sets: Sony XBR75X940C, Sony XBR75X940D, Samsung UN65KS9800, UN55KS8500, UN49JS8500, TCL P-Series (55P607)
Previous Sets: Sony XBR65X930D, XBR65X900B, XBR49X830C, Samsung KS8000, KU6500, JS9000, JU7090, JU6500, JU6400, HU9000, HU7250, PN64F8500, Vizio P65, LG 65EF9500, LG 55EC9300, Hisense 55H8C
Viper32 is offline
post #658 of 1638 Old 03-08-2017, 05:17 PM
JJxiv1215's Avatar
Quoted: 266 Post(s)
Liked: 275
You had to quote EVERYTHING just to say that?!
What do you want, proof of a deposit paid?
Who makes the rules around here? I request an audience.
#HozayCinema 9.1
post #659 of 1638 Old 03-08-2017, 05:23 PM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
Is Robert Tax free (I'm in FL) and free shipping? if not I will wait for the Amazon folks (videoaudiocenter).
post #660 of 1638 Old 03-08-2017, 05:42 PM
robert9674's Avatar
Liked: 690
Lolololololololol
Sony A1E
Triton one
Reply OLED Technology and Flat Panels General
a1e , acoustic surface , hdr , oled , Sony
