How can I see if the B6 is at 4K? When viewing Netflix 4k shows, it doesn't display any info on the screen.
When viewing FIOS tv programming, I can point the cursor to the top left corner and get the info.
But not for any apps. I also tried using my Harmony 650 info button, but nothing shows up.
Unfortunately, there is no way to really tell for those apps. They did away with the detailed spec option. Depending on your visual acuity, you would be able to tell right off the bat.
I purchased from Amazon Better Call Saul Season 2 which is real 4k. when i played it it only shows 1080P and not UD. Anyone else have this problem with Amazon?
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
