Out of the box LG OLED55B7P with pixel stain and weird diagonal lines - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-23-2017, 06:35 PM - Thread Starter
TiaoMacaleh's Avatar
Hi there,
I just opened my brand new LG and after a while i started to realize there was some image artifacts on the midle-left side of the pannel.
I looks like a weird type of stain with an horizontal shape roughly the size of a large remote control.
That thing isn't visible in all scenes, it's easier to spot on single colors textures or large gray areas. On a picture is harder to spot than on moving scenes, since the stain is the only thing that isnt going anywhere.
Also there seems to be some very thin diagonal lines going trough that stain area. (WTH)
My TV is completely new, not even a day old.
Does anyone have any idea of what that could be? Should i contact LG?
IMAGE 1 - Horizontal Stain and diagonal lines highlighted
IMAGE 2 - The previous image without the marks.
IMAGE 3 - Lines and Stain visible
IMAGE 4 - Lines and Stain visible
TiaoMacaleh is offline
post #2 of 7 Old 09-23-2017, 06:39 PM
Viking 29's Avatar
Quoted: 243 Post(s)
Liked: 134
Originally Posted by TiaoMacaleh View Post
Hi there,
Take that puppy back!
Viking 29 is offline
post #3 of 7 Old 09-23-2017, 06:40 PM - Thread Starter
Do you mean contact LG for service?
(sorry, kinda lost in translation here)
post #4 of 7 Old 09-23-2017, 08:58 PM
Quoted: 40 Post(s)
If it's a B7P, then it's a Costco model. I'd just take it back to Costco and swap it out for another, they are really good with returns
Iknowaguy is offline
post #5 of 7 Old 09-24-2017, 07:05 PM
Orta's Avatar
I had the same/similar issue on my first unit. Seems as pricing is falling, so to is QC. Or perhaps more likely, they're attempting to get rid of 95% functional B-grade panels in hopes people will not notice, overlook, or ignore. Second unit is good as far as uniformity defects are concerned, but the ABL behavior is radically different than the first.
Orta is offline
post #6 of 7 Old 09-26-2017, 04:53 PM - Thread Starter
What is really weird is that today i tried really hard to spot those errors without any luck. Aparently they are gone.
I'll keep looking closely in the next days... is there any reasonable explanation to this?
post #7 of 7 Old 09-26-2017, 06:01 PM
Cam1977's Avatar
Quoted: 1093 Post(s)
Liked: 890
It could be the comp cycles that took care of it...uniformity is tricky on these...so I would monitor it.
Cam1977 is online now
Reply OLED Technology and Flat Panels General
