Plasma and 4:3 size material questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-09-2004, 04:50 PM - Thread Starter
Flavius's Avatar
Liked: 46
I'm thinking about buying an EDTV Plasma. I see there are some that can display 4:3 material in its original aspect ratio, like the Zenith models. Well, what does that look like? Are the left and right sides gray or black? Is this a surefire recipe for burn-in? Thanks!
Flavius is offline
post #2 of 4 Old 01-09-2004, 05:09 PM
bowser's Avatar
"I see there are some that can display 4:3 material in its original aspect ratio, like the Zenith models."
I believe they all can
"Well, what does that look like? Are the left and right sides gray or black?"
Depends on the model's particular options, on my version, you have a choice of white, gray, and black. The exception is if its an HD feed then you can't control either the aspect ratio or the side bar color. On some manufacturers' models you can control these parameters on HD feeds too.
"Is this a surefire recipe for burn-in?"
Yeah if thats all you watch for months and months. I normally watch in Just mode which just expands the ends to fit in the 16:9 format and IMHO is very acceptable.
bowser is offline
post #3 of 4 Old 02-08-2004, 10:03 PM
rwhaugan's Avatar
Flavius
Did you ever purchase a 4:3? I am also considering purchasing a 4:3 and would ne interested in knowing the results of your research and/or purchase.
rwhaugan is offline
post #4 of 4 Old 02-09-2004, 07:05 AM - Thread Starter
Flavius's Avatar
Liked: 46
No, I dumped the 4:3 idea and went with a $2700 Panasonic 16:9 42" EDTV plasma. As should you. :D
Flavius is offline
Closed Thread OLED Technology and Flat Panels General
