Download Break In DVD (SVCD) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #451 of 1289 Old 05-14-2007, 07:48 PM
d0ofy's Avatar
Originally Posted by Pete7874 View Post
I tried to download the CDR version, but I get "page not found" when I click on this link:
Is the link dead for others, too, or is it just me?
Take the underscore out of the file name.
d0ofy is offline
post #452 of 1289 Old 05-14-2007, 07:50 PM
Pete7874's Avatar
Yup. Thanks. Just figured it out.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Pete7874 is offline
post #453 of 1289 Old 05-14-2007, 07:50 PM
Kr8z1's Avatar
Not working for me either. Looks like Evangelo2 has been doing some work on his site, maybe it will be back up later.
Kr8z1 is offline
post #454 of 1289 Old 05-14-2007, 07:52 PM
Kr8z1's Avatar
Kr8z1 is offline
post #455 of 1289 Old 05-17-2007, 03:36 PM
sblasl's Avatar
Any chance that someone could put this in a QuickTime/.mp4 format so that I could put this on my Apple TV?
sblasl is offline
post #456 of 1289 Old 05-17-2007, 07:56 PM - Thread Starter
Evangelo2's Avatar
can't the apple tv play a dvd?
Evangelo2 is offline
post #457 of 1289 Old 05-18-2007, 07:14 AM
sblasl's Avatar
You have to rip & then transcode a DVD then stream or sync it to the Apple TV. Stuff that is all new to me...
Video formats supported:
H.264 and protected H.264 (from iTunes Store): Up to 5 Mbps, Progressive Main Profile (CAVLC) with AAC-LC audio up to 160 Kbps (maximum resolution: 1280 by 720 pixels at 24 fps, 960 by 540 pixels at 30 fps)
MPEG-4: Up to 3 Mbps, Simple Profile with AAC-LC audio up to 160 Kbps (maximum resolution: 720 by 432 pixels at 30 fps)
Audio formats supported: AAC (16 to 320 Kbps); protected AAC (from iTunes Store); MP3 (16 to 320 Kbps); MP3 VBR; Apple Lossless; AIFF; WAV
TV compatibility
Enhanced-definition or high-definition widescreen TVs capable of 1080i 60/50Hz, 720p 60/50Hz, 576p 50Hz (PAL format), or 480p 60Hz
sblasl is offline
post #458 of 1289 Old 05-21-2007, 07:17 AM
davemcs's Avatar
since red/green/blue combined make for a white screen...would it be safe to display a pure white screen during times when the TV isnt being watched to safely "age" the screen?
davemcs is offline
post #459 of 1289 Old 05-21-2007, 07:27 AM - Thread Starter
Evangelo2's Avatar
It should be safe.
The only possible drawback is that a pure white screen pulls the most power and pushes the plasma hardest (same with CRTs). The changing colors can be a little easier on the power supply and some other parts of the plasma.
-Evangelo2
post #460 of 1289 Old 05-21-2007, 07:38 AM
davemcs's Avatar
Originally Posted by Evangelo2 View Post
It should be safe.
-Evangelo2
Thanks E
Once your dsic gets here I'll start running in during "off hours" via the HD-A1 that arrived witht he 4270HD!
Dave
***Update...DVD arrived and works perfectly. Many Thanks Evangelo!
davemcs is offline
post #461 of 1289 Old 05-24-2007, 08:41 PM
foofighters's Avatar
SO i play the break in dvd every night after i use the scrolling white screen option for at least two hours a night until i reach 250 hours of 'breaking in' Then i change my settings to what? Am i close here im getting my 5054 monday morning!
foofighters is offline
post #462 of 1289 Old 05-29-2007, 07:59 AM
jn2006's Avatar
so i just got samsung 50" plasma (5054). I should just download this dvd and play it for 100 hours continously before I start watching tv? Or does the total number of hours = 100, with time for tv? Is it ok just to watch non-hd tv for a hundred hours? thanks.
jn2006 is offline
post #463 of 1289 Old 05-29-2007, 08:04 AM - Thread Starter
Evangelo2's Avatar
Hi jn2006,
It is fine to just watch sd-tv stretched or zoomed or regular HD TV for 100 hours. Just try and not watch things that have black bars or fixed high contrast station logos. Also turn down your contrast and brightness settings.
This disc is made to supplement that normal watching time to get you to 100 hours faster that way you can really start enjoying your plasma the way you want to watch it (I know I am lucky if I get 60 hours of use on my plasma a month). With the disc I went to 200 hours of total viewing in about 1 and a half weeks.
-Evangelo2
post #464 of 1289 Old 05-29-2007, 09:15 PM
offdee's Avatar
I apologize if I'm an idiot, but new to all of this and really don't want to screw anything up.
I'm getting a Panasanoic 77U later this week...can you give me a "breaking in for dummies" version for this specific set?
From what I gather..
If I don't have a break in DVD:
- Watch non HD shows for 100 hours
- Don't watch anything with black bars or fixed logos
- Turn down contrast and brightness settings.
After 100 hours of this I'm safe to turn all levels to desired and watch whatever programming I want for however long I want?
offdee is offline
post #465 of 1289 Old 05-29-2007, 10:52 PM
BasementBob's Avatar
Quoted: 136 Post(s)
Liked: 135
offdee:
Actually watching HD shows is fine. For example Discovery HD.
Yes. Yes.
You can also watch, at low contrast, any true 16:9 DVDs that you have. (no 2.35:1 stuff). If you're watching 4:3 cable television, use the screen's stretch mode to fill the screen. Drive every pixel.
Beware of bright static images forever:
a) most games
b) non-transparent station identification logos
c) some screen savers like the Motorola DCT-6416's screen saver -- it's a pure full brightness white logo moving around the screen, and is unexpectidly enough to cause light burn in.
What I do is run at perfect/calibrated settings for BluRay and HDDVD disks, and low contrast settings for cable television (CSI, Star Trek Voyager, Mad About You).
I did the Evangelo2's DVD thing for about 200 hours, with a couple of hours of 16:9 HDDVDs in there, all at low contrast -- I'd just bought this expensive toy and I had to watch something on it the first two days.
An amateur built the Ark. Titanic was built by professionals. Of course Noah took a little advice.
BasementBob is offline
post #466 of 1289 Old 05-30-2007, 10:08 AM
offdee's Avatar
I'd really like to use this burn in DVD, but am having troubles finding someone to burn it for me.
Also not sure if my DVD player plays SVCD...anybody know with this model:
Sony DVD-NC665P (Precision Cinema Progressive, Precision Drive 2/MP3 Playback)
Would anybody out there be willing to burn this for me and mail to me? I could pay for the services or return it when I'm finished.
Appreciate the help
offdee is offline
post #467 of 1289 Old 05-30-2007, 10:15 AM
offdee's Avatar
Some other idiotic questions...feel free to flame me!
1) What means this...explain to me like I'm 10 yrs old: can watch any true 16:9 DVDs that you have. (no 2.35:1 stuff).
2) I see on my Panny U77 settings it has a specific "Brightness" level I can reduce, but what labeled level would I change to lower the Contrast? (Picture, Color, Tint, Sharpness, etc.)
thanks!
offdee is offline
post #468 of 1289 Old 05-30-2007, 10:59 AM - Thread Starter
Evangelo2's Avatar
thanks!
1) you can watch any DVD you want as long as there are no black bars anywhere. If there are black bars, zoom the picture.
2) Not sure of the level to use for panny's as I ahve a Pioneer. Look around this forum and Im sure you'll find settings posted for your panny.
If you need a disc burned you can order one from the site. All disc are tested before they are sent out and are mailed USPS First Class.
-Evangelo2
post #469 of 1289 Old 05-30-2007, 11:11 AM
Quoted: 136 Post(s)
Liked: 135
offdee:
Please update your "User CP > Edit Profile > Location".
I don't know the Panny U77 .
On most TVs/Plasmas there are two settings:
- Brightness - this controls where the black vs blacker-than-black setting is. In otherwords the setting of the dimmest part of the image. When your DVD sends "show this pixel as black", this determines how bright that will be. On a scale of 0-255, you should just be able to see 16, anything from 0-15 should be 'blacker-thank-black' and invisible.
- Contrast - this controls the brightest part of the image your tv/plasma will display. When your DVD sends "show this pixel as white", this determines how bright that will be. On a scale of 0-255, 235 should be as bright as you can get, anything from 236-255 should be 'whiter-than-white' and indecernable from white.
Don't worry about the 0-255 settings. You don't really need to know those.
Just remember 'brightness' is dark, and 'contrast' is white.
The problem with 100hour burn in, is that pixels age/decay more in their first 100 hours. So the trick is to get them to decay evenly. Lowering contrast, combined with filing the screen with random (Discovery HD) or predictably even (Evangelo2's dvd) makes that more likely.
In the longer term, your plasma in a year will be less bright than it is the day you get it. Because the pixels continue to decay over time. The rate of decay is inverse exponential, meaning it decays a lot the first 100 hours, and very little on day 365.
post #470 of 1289 Old 05-30-2007, 11:39 AM
offdee's Avatar
How do you know when you've logged 100-200 hours?
Is there an area on the TV that shows viewing time or is this just something I'll need to keep track of myself?
offdee is offline
post #471 of 1289 Old 05-30-2007, 10:16 PM
Klips's Avatar
Originally Posted by Kr8z1 View Post
For the Pio's the recommendation is to run the tv at normal viewing settings or just a bit higher while using the dvd..
I have a *new* PDP5071hd. So to be clear, you are saying I should run the DVD with the mode set to "NORMAL" (i.e., not DYNAMIC, MOVIE, GAME, or USER) during the burn-in period. Is this correct? I take it this is the exception to the rule of turning down the contrast and brightness.
Does it matter that the current DVD player doing the burn-in only outputs in 480i? I have another DVD player that I can move into position that I believe can do 480p and possibly 780p. Would this be any better for the burn-in? I have an HD DVD player coming, but it's not expected to ship for a couple of weeks yet.
Thx
Klips is offline
post #472 of 1289 Old 05-31-2007, 05:16 AM - Thread Starter
Evangelo2's Avatar
Thx
I have a Pio 5050 and I had the settings turned extremely low when I wasn't home to keep an eye on what was going on. Im talking contrast at 15 and brightness at -5 to -8. When I was watching a show or something on the tv I had more normal settings but still avoided black bars and static logos for long periods of time.
-Evangelo2
post #473 of 1289 Old 05-31-2007, 09:47 AM
samuel_adam's Avatar
when i play this disc, does it matter if its running through HDMI or Component through my DVD player?
also, do i need to set anything when playing or does this disc loop itself?
i plan on using the DVD version of this
samuel_adam is offline
post #474 of 1289 Old 05-31-2007, 11:04 AM - Thread Starter
Evangelo2's Avatar
HDMI or Component should not make a difference.
The disc should play straight through for almost 24 hours without any player forced looping.
-Evangelo2
post #475 of 1289 Old 05-31-2007, 12:34 PM
cromag's Avatar
I'm new here but thought I'd contribute.
I was looking at this thread and downloaded the nero disk image. Seeing as my PC laptop cannot burn DVD I thought I'd try burning the image to DVD using my Macintosh. Macs use DVD -R discs by the way so your DVD player will have to be able to play that format.
First I tried using Toast but no go. Toast couldn't see the image. Then I tried using the macs disc utility and it worked perfect the very first time.
I thought maybe someone else out there could use the info.
cromag is offline
post #476 of 1289 Old 05-31-2007, 09:16 PM
nikonjava's Avatar
I am waiting for the delivery of my new plasma Pio 5070 and wanted to be ready when it comes in. I saw that Evangelos says DVD-R version of break dvd is here. Is it ok if I burn the .iso file onto DVD+R and use it?
cheers
No electrons were harmed during the creation, transmission or reading of this posting. However, many were excited and some may have enjoyed the experience.
nikonjava is offline
post #477 of 1289 Old 06-01-2007, 08:33 PM
joebar's Avatar
cheers
Either are fine -- it would work on a dvd rw disk also if your player supports them.
joebar is offline
post #478 of 1289 Old 06-02-2007, 05:28 PM
nikonjava's Avatar
Thanks joebar.
post #479 of 1289 Old 06-04-2007, 09:21 PM
john leavold's Avatar
Hi all,well i just downloaded and fired up the dvd break in disc (thanks Evangelo2) and now have had playing on my new Panny 58PX60U for the last 1 hour, i haven't even watched a dvd or tv show on it yet.my settings are
Standard
-10 picture
-5 brightness
-6 color
-4 tint
-20 sharpness
normal color temp
Is this acceptable to start the break in process and gradually crank them up after 50 hrs,or should i follow the other method of turning up the settings first hand ( and if thats the case recommend Panasonic settings).thanks sorry for a noob question,just trying to maximize the break in,and minimize ir..and have read to different methods.
john leavold is offline
post #480 of 1289 Old 06-05-2007, 10:59 AM
offdee's Avatar
Standard
-10 picture
-5 brightness
-6 color
-4 tint
-20 sharpness
normal color temp
From everything I've read thru this thread I'm doing the break in as
Picture: -10
Brightness: -10
all other settings: 0
No black bars or standing logos on the screen. All else should be fine to watch for the first 100-200 hours.
offdee is offline
Reply OLED Technology and Flat Panels General
Pioneer , Pioneer Elite
