TH-50PHD8UK and TU-PT700U - AVS Forum | Home Theater Discussions And Reviews
Old 10-20-2005, 10:26 PM - Thread Starter
ttinLV's Avatar
Has anyone been able to hook up and successfully use the Panasonic TU-PT700U Media Receiver with Panasonic's commercial plasmas such as the TH-50PHD8UK?
The TU-PT700U normally comes with the 65" Onyx.
It looks like an almost complete media switcher/tuner.
2 RF Inputs
CableCard
2 Component
2 Composite/2 S-Video
1 HDMI
JPEG photo viewer with multcard reader
ATSC/QAM/NTSC tuners
PIP
There are two connectors that hook up to the 65", one DVI and one 26pin D connector. The DVI is most likely for the video input, the 26pin D is probably for setting control of the 65" (color, size/alignment, etc)
ttinLV is offline
Old 10-21-2005, 07:29 PM - Thread Starter
ttinLV's Avatar
No one has tried this?
ttinLV is offline
Old 10-23-2005, 04:14 AM - Thread Starter
ttinLV's Avatar
Any other media centers?
ttinLV is offline
Old 10-23-2005, 08:35 AM
manufanatic's Avatar
2 RF Inputs
CableCard
2 Component
1 HDMI
PIP
i havent tried it but i would assume that if the output of the media reciever allows input to the panny plasma then it should work. the receiver is just being used as the switching source.
manufanatic is offline
Old 10-25-2005, 05:41 PM - Thread Starter
ttinLV's Avatar
The PT700U plugs into the Onyx series with a 26pin D connector and a DVI. The 7UY/8UK and the 50U/500U do not have that connector. On the surface it seems that that connector is the control signals that might be sent from the box for controlling color/bright/contr/other picture controls.
Does anyone know if just the video output from the DVI connector will work or does the box sense that the "control" connector is not connected at complain that the PDP is not there? Is that connector just a control thing?
ttinLV is offline
