OLED TVs: Technology Advancements Thread - Page 394 - AVS Forum | Home Theater Discussions And Reviews
 1210Likes
post #11791 of 14098 Old 02-15-2015, 07:57 AM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2482 Post(s)
Liked: 2256
Originally Posted by sarahb75 View Post
Realize that I may not be too bright,
So maybe folks might shed some light,
On why,
Thread on OLED TV being right,
Morphed into one on making light,
Then, I may be at peace, tonight.
You're right. Someday we might even morph this thing into a poetry thread or somesuch.... :-P
stas3098 likes this.
You're the wife. You're the dead wife. Give me my @#$%ing coin, dead wife.
-Mad Sweeney
tgm1024 is offline
post #11792 of 14098 Old 02-15-2015, 12:53 PM
Ken Ross's Avatar
Quoted: 6536 Post(s)
Liked: 7238
Originally Posted by stas3098 View Post
And what that problem might be, I wonder?
P.S. This is a purely rhetorical question because there's no problem with it at all and I have not seen one yet because they haven't simply made one yet, and therein lies the notorious OLED light-bulb paradox...
They haven't made a time machine either, but I hear it's both theoretically possible and there's no problem with it.
Ken Ross is offline
post #11793 of 14098 Old 02-15-2015, 12:54 PM
Ken Ross's Avatar
Liked: 7238
Originally Posted by catonic View Post
Because this is AVS.
It's also why I tend not to visit this thread.
Ken Ross is offline
post #11794 of 14098 Old 02-15-2015, 01:06 PM
rogo's Avatar
Quoted: 1630 Post(s)
Liked: 1841
Gee, I wonder. The world is replacing a billion light bulbs right now... Big opportunity to sell light bulbs. If making an OLED one was problem free, you'd think someone would, you know, make one. Maybe sell 100 million or so. Case closed.
Originally Posted by tgm1024 View Post
Slacker, Ynotgoal, and xrox, absolutely.
Xrox, TGM, many others with regular smart takes too. I was specifically calling out those recent posts by Slacker and Ynot. Not to the exclusion of other smart takes, though perhaps to the exclusion of some not smart ones.
tgm1024 likes this.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
post #11795 of 14098 Old 02-15-2015, 01:16 PM
catonic's Avatar
Quoted: 344 Post(s)
Liked: 324
Very wise Ken, ....unless your looking for a bit of entertainment!
Ken Ross likes this.
catonic is offline
post #11796 of 14098 Old 02-15-2015, 01:29 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
Was there a sentence in that ^^^^ gobbledygook?
Don't go throwing a flurry of words in hopes of staving off a discussion. Stas, while there are absolutely hole-charges in the flow of any current (at any voltage), it's not the electron-hole recombination that produces light with incandescents. It's the raw heating up of the filament. Things heated up (by any means) will often glow, and they glow at differing frequencies depending upon material and temperature.
1. I don't even know any more
2. Not directly, but the electron-hole recombination produces heat (due to resistance) that heats up the filament.
And FYI I was not debating the fact that when things become calid enough they don't turn lambent, of course they do, though, in many cases they irradiate rather subfusc light or in other words things do glow when heated up
My main point was , in a nutshell, that the flow of current makes incandescents produce heat (infrared) which we perceive as light( some of that heat comes in the form of visible light) and that the flow of current (induced by voltage) makes OLEDs work as well( by inducing the flow of holes and electrons through the emitter (via some metal present in the emitter) where when the holes and electrons recombine they release photons of different (usually invisible) frequencies whose frequency then changed to the targeted frequencies by organic compounds present in the emitter).
stas3098 is offline
post #11797 of 14098 Old 02-15-2015, 02:12 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
...false dichotomy...
stas3098 is offline
post #11798 of 14098 Old 02-15-2015, 06:25 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
I hope you understand that all the things in the world have the property of "lucency" when subjected to certain conditions and that there's only one way that said lucency can be induced, to wit, by the process of recombination of holes and electrons and the subsequent release of energy in the form of photons which (the subsequent release of energy),in turn, is caused by a catalytic disturbant event (in the case of OLED it is application of voltage) that thereupon leads to the creation of "holes" and thereafter to the flow of elections in absolute and complete accordance with the Law of Conservation of Energy which enjoys the role of governance over the transfer of energy which has theretofore happened in the same exact vein an uncountable number of times and to say otherwise is to totally misunderstand the basic workings of physics, but however things might be this is not a physics forum, wherefore I shall not proceed to expand on the "all objects have a property of lucency" dictum that was put forth quite sometime ago and which enjoys the privilege of pertaining to every single aspect and facet of our life...
Now I hope that you guys understand that all things emit light (though, not always visible that light might be) when subjected to certain conditions and that there's only one way that light can be emitted and that is by the recombination of holes and electrons.
stas3098 is offline
post #11799 of 14098 Old 02-15-2015, 08:51 PM
Ken Ross's Avatar
Liked: 7238
Is there a correlation between lucid and lucency?
tgm1024 likes this.
Ken Ross is offline
post #11800 of 14098 Old 02-15-2015, 09:42 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
Certainly, there is for they both originate from the Latin word for "light" (lux) thence "lucency" denotes "light", howbeit "lucidity" is usually taken to mean "perspicuity", "coherency" or "clearness (of mind)" and "lucid" ,in sooth, bespeaks "not of wode or temerarious mind (disposition)", "reasonable" or "bright". FYI also such words as luxurious, luxuriant, luculent, luculence luxury, luminary, illumination, luminance, illuminant, lumen, luminesce, illuminate, pellucid, pellucidity, pellucidate, elucidate, luminous, luminousness etc., come from the same Latin word for "light".
P.S. Mind-bending stuff , I know
stas3098 is offline
post #11801 of 14098 Old 02-15-2015, 10:56 PM
rogo's Avatar
Liked: 1841
You would seem to be the expert on false parallels without question. I would say you might want to stay away from commenting on whether the utter lack of a single production OLED light bulb somehow is evidence for your claim of the ease of producing one, however. It's like arguing that the fact we haven't detected a shred of alien life is certainly proof the universe is teeming with it because, well, it's likely it's out there!
[SIZE=1][SIZE=2][SIZE=3
I hope you understand that the relevance of this to the price of tea in China is low and the relevance of the price of tea in China to the rest of this conversation is very nearly as high as the fact that the "only way light can be emitted is by the recombination of holes and electrons."
rogo is offline
post #11802 of 14098 Old 02-15-2015, 11:41 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
For the record, I never said it was going to be easy to make an OLED light bulb compatible with an Edison socket, all I said was that it was possible to cobble an "OLED-based light bulb" together that would fit into a good old Edison socket(but what would the point of such a contrivance be, what with the current OLED production costs?), but then things somehow got away from me, spiraled out of control and degraded into this...
And in reality the chances of an OLED light bulb coming into existence within this decade are rather slim...
And to be honest, the main reason why there's no OLED light bulb is purely economical. The viability of such a source of light is univocally non-existent, but the viability of an OLED luminaire (a complete lighting unit) is not so murky.
P.S. My own medicine does taste somewhat like Chinese tea.
stas3098 is offline
post #11803 of 14098 Old 02-16-2015, 05:12 AM
tgm1024's Avatar
Liked: 2256
Apparently not.
-Mad Sweeney
tgm1024 is offline
post #11804 of 14098 Old 02-16-2015, 06:53 AM
Stereodude's Avatar
Quoted: 3334 Post(s)
Liked: 2434
So you've been lying previously since you're only being honest now?
Are there real working prototypes being shown somewhere, but nothing on the market? If not, I don't see how you can make the claim you're making. Lots of things that are technically feasible but not commercially viable are shown as prototypes or proofs of concept while the makers attempt to drum up interest and get them commercially viable. If there are no prototypes or proofs of concept the natural conclusion is quite a bit different than the one you're claiming.
Stereodude is online now
post #11805 of 14098 Old 02-16-2015, 10:12 AM
rogo's Avatar
Liked: 1841
In other words, what I said was actually true and you in fact agree.
I shall continue reading your scientific approach to things now that I know you are not choosing to be obstinate just for the sake of it.
And at an interesting price. The chances are zero.
We were in Ikea yesterday where they are hawking 40w-equivalent LED bulbs for $3.50. I suspect in a year 60w equivalents will be the same price.
That seems like the new normal and it's basically upon us.
rogo is offline
post #11806 of 14098 Old 02-16-2015, 03:31 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
Here's an OLED light bulb prototype:
stas3098 is offline
post #11807 of 14098 Old 02-16-2015, 09:54 PM
Weboh's Avatar
Quoted: 93 Post(s)
On a different note, MEMS is now becoming backlit and has response much faster than LCD and OLED. But the prototypes, so far, are small. This pleases me much, since I am not totally impressed by LCD and OLED shutter-based technologies. I highly doubt that OLED is similar to Wildfire which also claims to be purely emissive.
Weboh is offline
post #11808 of 14098 Old 02-17-2015, 12:00 PM
chexi1's Avatar
Quoted: 64 Post(s)
Liked: 115
There are prototype and even commercially available white OLED lights (not Edison socket bulbs) but lights. They are ridiculously expensive, but they exist.
The real market for OLED lighting is in accent lighting or on planes of glass or on curved surfaces with FOLED. As a shareholder of Universal Display, I wish that the world's replacement of incandescent lighting would have skipped LED and gone to OLED, but alas, that is not going to happen.
jacko15 likes this.
chexi1 is offline
post #11809 of 14098 Old 02-17-2015, 01:23 PM
NintendoManiac64's Avatar
Quoted: 929 Post(s)
Liked: 386
Originally Posted by Weboh View Post
On a different not, MEMS is now becoming backlit and has response much faster than LCD and OLED.
Uhh, OLED has ridiculously fast response times...
Remember, response time does not equal refresh rate, input lag, nor low motion blur.
wicklow likes this.
NintendoManiac64 is offline
post #11810 of 14098 Old 02-17-2015, 04:35 PM
tgm1024's Avatar
Liked: 2256
I'm fairly certain he knows this. And FWIW, MEMS cells can actually shutter in a 1/10th of a millisecond. And the jury is still out on the role GtG plays with motion blur.
-Mad Sweeney
tgm1024 is offline
post #11811 of 14098 Old 02-17-2015, 06:31 PM
Quoted: 929 Post(s)
Liked: 386
And OLED is stated to have a response time a of less 0.01 ms, aka 1/100th of a millisecond - and that's apparently a conservative measurement.
post #11812 of 14098 Old 02-17-2015, 06:35 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
There are prototypes out there (as I have shown), but whether or not there are prototypes has very little bearing on my original argument. My main point was that there were nothing out there precluding an OLED light bulb from springing to existence on the physics' side of the street
And on a loosely related note, my "swevens of the futurity" might not well be yours "swevens of the futurity" and sweb I might of the bright future for OLED lighting, but you might not, and it's okay and it's alright. There's nothing wrong with that. Everybody's entitled to their own opinion.
stas3098 is offline
post #11813 of 14098 Old 02-17-2015, 07:36 PM
tgm1024's Avatar
Liked: 2256
Where did you read that? LG has listed their tech at .1 ms, not 0.01. And where did you get that as a conservative measurement?
EDIT: I think I found where you likely got that measurement from. The wikipedia page. Sigh. Yet again this thing shows up. The problem with misinformationpedia is how the authors completely misinterpret what the originating statements are saying. The quote from oled-info was "1000 times faster than LCD". That doesn't put it at 1/100th of a millisecond without lab results, because LCD times vary tremendously from level to level (hence the absurdly differing values in the GtG charts for LCD).
-Mad Sweeney
tgm1024 is offline
post #11814 of 14098 Old 02-17-2015, 08:42 PM
wco81's Avatar
Quoted: 1398 Post(s)
Liked: 531
From that link, it doesn't sound like MEMS is being envisioned for large displays any time soon.
They're targeting 7-inch tablets at a time when phablets are pushing them to extinction.
wco81 is online now
post #11815 of 14098 Old 02-17-2015, 08:43 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
OLED has ,in theory, a near instantaneous response time... and ,in theory, the 0.01 ms estimate is very conservative in my opinion... but to know that you first have to understand the physics behind OLED. But however things might stand in the Theory Land, 0.1 ms is what the response time usually comes down to, in reality, for current OLEDs...
stas3098 is offline
post #11816 of 14098 Old 02-17-2015, 09:19 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
Here's a whitepaper that put it at 0,01 ms and lower
http://www.journalofvision.org/content/14/9/2.full
NintendoManiac64 likes this.
stas3098 is offline
post #11817 of 14098 Old 02-17-2015, 09:20 PM
Quoted: 929 Post(s)
Liked: 386
Here's the lab results that put it at 0,01 ms and lower
Thank you! I knew it was somewhere but I didn't have time to find it.
Besides, even if OLED "only" has a 0.1ms response time, that's still on par with MEMS...
post #11818 of 14098 Old 02-17-2015, 09:37 PM
stas3098's Avatar
Quoted: 156 Post(s)
Liked: 88
Here's the response time quote from a Samsung patent:
Furthermore, OLEDs have very small response times, 0.01 ms and less, compared with LCDs (about 2 ms)
http://www.google.co.ug/patents/US20120146489
stas3098 is offline
post #11819 of 14098 Old 02-18-2015, 05:55 AM
Weboh's Avatar
Quoted: 93 Post(s)
It hasn't shown in real world tests of OLED.
Weboh is offline
post #11820 of 14098 Old 02-18-2015, 10:36 AM
Rich Peterson's Avatar
Quoted: 145 Post(s)
Liked: 167
Sony is still in the professional OLED Monitor market. They just announced a 4K model: http://www.tvnewscheck.com/playout/2...aster-monitor/
Rich Peterson is offline
Reply OLED Technology and Flat Panels General
Lcd Hdtv , Led Hdtv , Lg , Oled Tv , oled wireless speakers , Plasma Hdtv , Samsung
