OLED TVs: Technology Advancements Thread - Page 399 - AVS | Home Theater Discussions And Reviews
 537Likes
post #11941 of 11946 Old Yesterday, 10:22 PM
Quoted: 48 Post(s)
Liked: 27
Originally Posted by Rich Peterson View Post
I'm reminded of comments made by LG's Ken Hong at IFA last summer. He said True RGB OLED TV cannot compete with WRGB and the white OLED patents LG bought from Kodak were the key to getting high enough manufacturing yields for success.
http://news.oled-display.net/lg-sams...mpete-wrgb-tv/
That's true of both yield and efficiency. A straight up RGB OLED panel is very inefficient when displaying white, which is the primary color used on computer displays. WRGB is going to be key to expanding out of the TV / smartphone market. Instead of an OLED screen causing a laptop to use more energy in many use-cases than an LED backlit LCD, it would do the opposite and barring costs/reliability, would be the technology of choice.
It's also more practical to implement low-persistence scanning on a WRGB panel. You want pixels that get very bright if you're going to pulse them for a short period of time and then turn them off for the rest of a refresh cycle, but if to produce a white color you have to simultaneously light 3 separate colored sub-pixels that's never going to get particularly bright with any sort of ABL scheme working against you.
Kaldaien is online now
post #11942 of 11946 Old Yesterday, 10:45 PM
Wizziwig's Avatar
Quoted: 317 Post(s)
Liked: 249
It may not be obvious, but WRGB is actually the less efficient tech. It is composed of all white sub-pixels that require filters to generate red, green, and blue. A lot of light output is lost in those filters. The single unfiltered white sub-pixels was only added to help compensate but it's not enough.
This is why the discontinued Samsung 55" RGB OLED was much brighter and offered a low-persistence mode with full motion resolution. I hope Samsung finds a way to make RGB work again.
tgm1024 likes this.
Wizziwig is offline
post #11943 of 11946 Old Yesterday, 11:45 PM
Quoted: 48 Post(s)
Liked: 27
Really? At fullscreen displaying a white image, I've measured power consumption of 180w on my 55EG9600. A solid red image draws the most power, at roughly 250w. The other two colors are slightly more efficient (< ~10w difference). But since most of the screen on a PC is typically white, that bodes very well for using WRGB pixels as a laptop display. It's usually the other way around, where white draws a crazy amount of power on OLED.
post #11944 of 11946 Old Today, 05:26 AM
tgm1024's Avatar
Quoted: 1062 Post(s)
Liked: 1159
I don't think you understand how LG OLED's are designed. And part of the problem stems from the industry which has conflated "WRGB" with this different design, instead of simply signifying an ordering of subs and the addition of white.
The LG OLED colors come from filtering a dichromatic white (or trichromatic white----jury's still out on this one----it depends upon which Kodak patent you read) formed from a stack of OLED materials underneath. For any one of the subs to be active requires that the entire stack be emitting that composite white and a filter remove all but the needed color. In the case of the white sub, it's unclear if there's no filter at all or a carefully tuned one.
If you believe you can win an argument by stating that scientists "often" get things wrong, all you're doing is selectively ignoring the overwhelming legion of things they have gotten right. Viewed as an aggregate, scientists very very rarely get things wrong.
tgm1024 is online now
post #11945 of 11946 Old Today, 05:30 AM
tgm1024's Avatar
Liked: 1159
Yeah, that's what we've been speculating for quite some time. I too believe that the reason to use white was entirely driven by the inherent losses involved in a filtered design. Filters exist solely to throw light (and effectively power) away.
ABSOLUTELY. Besides, their approach to having ever enlarging subs (from red to green to blue) was absolutely the correct approach, and you don't lose the subpixel density you do when you move to 4 subs.
post #11946 of 11946 Old Today, 07:02 AM
Quoted: 48 Post(s)
Liked: 27
No, I understand that there's a filter used for the non-white colors. However, energy efficiency when displaying pure white is phenomenal, which is what you do most of the time on a PC. It sort of turns everything on its head - Samsung has to illuminate the R, G and B sub-pixels in order to produce white.
Reply OLED Technology and Flat Panels General
Led Hdtv , Lcd Hdtv , Plasma Hdtv , Oled Tv , Lg , Samsung
