Philips hdmi input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-23-2006, 08:09 PM - Thread Starter
pimpee's Avatar
i switched from a s video output to a dvi/hdmi cable today thinking that all i need to do is switch the input to HDMI to see the pciture. However after the switch, i see nothing but a black screen on the hdmi inputs.
I tried to disconnect all the cables except for the HDMI and still nothing. The video card on the PVR displays fine with S-video and i have a feeling i'm doing something wrong that is not enabling HDMI input.
tx
pimpee is offline
post #2 of 6 Old 08-23-2006, 11:57 PM
elwood58's Avatar
Your issue is most likely with enabling the HDMI output on the source.
elwood58 is offline
post #3 of 6 Old 08-24-2006, 07:51 AM - Thread Starter
pimpee's Avatar
you have to enable the HDMI input?? the cable was snug-ly plugged in on both ends and i selected hdmi as AV source from the menu. (same procedure i use to select s-video for PVR viewing).
pimpee is offline
post #4 of 6 Old 08-24-2006, 10:29 AM
elwood58's Avatar
You must enable HDMI output on the PVR.
elwood58 is offline
post #5 of 6 Old 08-24-2006, 05:10 PM - Thread Starter
pimpee's Avatar
my PVR is windows media center edition. I finally updated the nvidia drivers and everything worked. so it was the video card drivers
new problem tho. the audio only accepts digital audio.. how do i go about getting that?
pimpee is offline
post #6 of 6 Old 08-24-2006, 07:30 PM
joperio's Avatar
Your HTPC does not output audio from the video card. You'll have to connect your pc's SPDIF/Optical out to your display. Make sure you set your display's digital audio input to the corresponding HDMI input.
joperio is offline
Closed Thread OLED Technology and Flat Panels General
