LED lcd VS Plasma - which is better? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 07-27-2009, 06:16 AM
aydu's Avatar
Quoted: 136 Post(s)
Liked: 113
People didn't seem to get as defensive when the issue of DLP rainbows was discussed. Some people clearly saw these, others not.
After reading about the issue, I did a quick check at my local retailers and found that neither my wife or I saw any rainbows with any of the DLP sets we viewed.
That didn't mean that the person next to us didn't see them, or that the subject should be banned from discussion based on my personal experience.
Fear that others may not adopt a particular technology because of a display characteristic is pure fanboy paranoia. If you know about the issue, a few minutes looking at a set would tell you if you see anything undesirable in the picture.
The real competition is how a set looks when compared with others. Here is where plasma is having competitive problems in the marketplace. They just don't look as sharp and bright as LCD.
The sharp and bright LCD factor is the less accurate picture, but it does draw attention and has a certain "wow, that's what I want" factor. Kind of like listening to Klipsch speakers and hearing what appears to be more detail in music than anything else you've heard.
With Klipsch, you'll likely have a headache after an hour of listening. Same with LCD in your home, cranked up to torch mode.
Neither plasma nor lcd technology is perfect, but the imperfections in each technology differ enough to attract different types of buyers, who perceive images differently.
aydu is offline
Old 07-27-2009, 11:46 AM
zack8322's Avatar
You make some good points, but there seems to be a rabid group here who will pounce on ANY perceived flaw in plasma and shout it anywhere and everywhere. I have no idea why. Perhaps it's because they are immature and feel the need to validate their buying decision. Whatever the reason it is tiring. Problem is too many people looking for info take their comments as fact, when any of us with a bit of knowledge and a brain know it to be false. In this case, while the issue may affect only a very small portion of the population, close to 1 or 2 %, the LCD fanboys will take it and run with it. The point is to make it known that it exists, but is rare.
My desire is to promote and encourage a technology that I feel is superior. The LCD crowd seems to want to run roughshod over all of us in the attempt to impose their technology on all of us. Plasma needs very vocal supporters to counter this group. While neither technology is perfect in my experience owning both I feel plasma is much superior.
zack8322 is offline
Old 07-27-2009, 11:49 AM
rgb32's Avatar
Quoted: 42 Post(s)
Liked: 32
+1. Wow! You sum up the recent posts so well!
rgb32 is offline
Old 07-27-2009, 11:50 AM
rgb32's Avatar
Quoted: 42 Post(s)
Liked: 32
More of the fanboy paranoia!
rgb32 is offline
Old 07-27-2009, 03:04 PM
aydu's Avatar
Quoted: 136 Post(s)
Liked: 113
Selecting a set should be based on pq, not how that pq was delivered,
If you pick your top three sets and they all use the same technology to deliver the image, your eyes and brain have a preference for a particular type image. That is perfectly fine, regardless of the technology.
If you can only pick a favorite set if you know the technology, you're letting your preconcieved technology bias make the decision for you, not your eyes. This is still ok, if it makes you happy with your purchase.
It does not mean that you have picked a technically superior set, that all others should buy.
aydu is offline
Old 07-27-2009, 06:54 PM
Railfan's Avatar
selecting a set should be based on pq, not how that pq was delivered,
if you pick your top three sets and they all use the same technology to deliver the image, your eyes and brain have a preference for a particular type image. That is perfectly fine, regardless of the technology.
Agreed. Thank you for stating this.
Railfan is offline
Old 07-27-2009, 08:44 PM
Patrick.'s Avatar
It's about time someone started showing reason around here, good posts!
Be a fan of displays, not companies or technologies!
Patrick. is offline
Old 07-27-2009, 10:03 PM
Fanaticalism's Avatar
While we're on the topic of which panel has more issues (as if it were new around here ), I recently had the opportunity to view Sonys' Z panel. My buddy was playing "Bugs Life" on BD, and while he had it in Torch mode with MF cranked to the gills, what I noticed was that the angles seemed to be pretty good. It seemed to be much better than Sonys other offerings.
Can anyone tell me what type of panel Sony is using in their Z series?
Fanaticalism is offline
Old 07-29-2009, 11:27 AM
xenophonite's Avatar
I'm considering a 55" or so panel. Currently have a 52" Vizio LCD and it gives off a lot of ambient light when room is dark. Am considering plasma or led lcd panel. With plasma prices now down to level of LCD, what are advantages of LED LCD over plasma?
xenophonite is offline
Old 07-29-2009, 11:32 AM
gus738's Avatar
Quoted: 59 Post(s)
Liked: 32
xenophonite by the sounds of things you are assuming lcd is better? a plasma is better in Picture Quality then a lcd, just about any entry level panasonic / samsung plasma is better.
whats your budget? im assuming its a reasonable amount if you considerd LED. the G or V series panasonic plasma are nice. plasma is still king of PQ and has less visable flaws then lcd even LED isnt so great (especially for the cost of LED compared to its plasma counterpart.
LED is the same thing just lcd with leds on the edge its able to produce more contrast but it clips shadow detail and whites. get plasma
Pioneer Elite PRO-111
Samsung 60PnF5300 af
panasonic px75u(r.i.p)Samsung 51f4500
XBL x117x831
PS4 gusx831
gus738 is offline
Old 07-29-2009, 11:42 AM
I'm looking to spend under $2K for >55". Costco has a 58" Panasonic plasma w/in budget. Does plasma (entry level) still have a lower half life or has that been resolved? I guess it doesn't matter since I upgrade fairly often, but still curious. Haven't looked seriously at plasma until the prices started to come down.
Old 07-29-2009, 11:48 AM
gus738's Avatar
Quoted: 59 Post(s)
Liked: 32
xenophonite you will never ever ever reach even HALF brightness. lets say you watch tv 12 hrs a day x 365 = 4,380 hrs a year x 10 yrs = 43,800
you will replace the tv if anything sooner, and thats watching tv 12 hrs a day!.
need i say more?
XBL x117x831
PS4 gusx831
gus738 is offline
zack8322's Avatar
100,000 hours,
zack8322 is offline
Old 07-29-2009, 12:01 PM
Nielo TM's Avatar
The operating hours is one of the most useless specs (along with response time).
IMO, the lifetime should reflect the component, which has the shortest operating hours at room temp
Nielo TM is offline
Old 07-29-2009, 01:18 PM
ertoil's Avatar
My Sony Flat Trinitron Wega CRT has better blacks than any Panasonic plasma
and the Loewe Aconda CRT has better blacks and grey scale than a Kuro
So go for a LED , OLED...cause Plasma is finished !
Remember the Neopdp name is just a name...nothing better than a 3 year old Kuro Pioneer
in fact the G10 has a native 40.000...the Pioneer Kuro krp-500A has 100.000 right now!!
i bet this is the last Panasonic plasma generation...wait for the sales rate !
ertoil is offline
Old 07-29-2009, 02:56 PM
mobius's Avatar
Quoted: 44 Post(s)
Liked: 38
Why would you recommend going with an inferior (to this day IMO) technology? But hey, LCD's sure are bright and flashy on the showroom floor. OLED? When can I buy one without also having robbed Fort Knox? Like you, I still prefer CRT, but for me, LCD is an unacceptable replacement. Plasma is the only suitable alternative.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling that thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a...
mobius is offline
Old 07-29-2009, 03:03 PM
Nielo TM's Avatar
What the heck are you talking about?
If you believe CRT is better than current LCD/PDP, more power to you. But don't wrap it up as facts.
PS: CRT has way more issues than LCD and PDP combined. Also, the G10 doesn't have 40,000:1 DR
Nielo TM is offline
Old 07-29-2009, 05:36 PM
joeyipsc's Avatar
Well, people blast technologies in different ways - some subtile some overt.
Those who blindly support plasma blatently ignore the heat, weight, reliability and burn in issues inherent in that technology.
Those in the LCD camp overlook motion blur, off angle viewing, and crushed blacks.
In the end, like with most things, different people put different priorities on these things and tend to go for the one whose limitations bother them (or are not even noticed by them) the least.
One key difference in the technologies is that they excel at opposite ends of the visual spectrum. Plasma excels at deriving detail in dark and shadow. LCD excels at bringing white whites to the viewer in dynamic fashion.
If you are a shadow guy, plasma is your king. If you're more interested in bright colors that pop, LCD is hard to ignore.
The mass market appears to really like bright colors that pop.
well, to me that sums it pretty much. I for one came from an XBr CRT of yester years and was pretty much reading every post I can read here.
purchasing both Plasma and LCD, the final decision was my very own set of eyes and the current conditions of my humble home theater. at a viewing distance of 8 feet max, i settled for a 42 inch.
after everything said and done, my eyes settled for a G10 as the Kuro was pretty much out of my budget. I also tried to see if the LED_Lcd was a possibilty BUT, after watching a movie (say 2 hours maybe) our eyes would hurt a bit. lowering the brightness / contrast makes the overall picture really bad. and yes, i got most of the settings posted here in forum from respected members but as I said, your eyes are the final say
joeyipsc is offline
Old 07-29-2009, 07:28 PM
An old member with a new name, what else is new?
Also, if you are going to troll, at least be good at it. Even the information that you provide in an attempt of being objective is completely false.
You may as well pick up a "Glimpse" magazine from your local BB, as it has more information that you have to share, so it'll be a nice starting point for you.
Old 07-30-2009, 03:46 AM
ertoil's Avatar
hey! im not an old member with new name! im a real new one
No , im not recomending inferior technology, do you think a Sony Edge Led is inferior
to a LG plasma?? well...if i would have the money i ll go for the Sony
if you talk about money..yes the G10 is a good one...but we re not talking about money
but technologies...and the krp-500A is the top; the red,blue,green LEDS of Sony
are already above the G10 imho.
if you have only 200 bucks buy a Sony Wega CRT with component input
Sony is returning to the "organic panels" (CRT) with OLED.
ertoil is offline
Old 07-30-2009, 06:14 AM
Patrick.'s Avatar
Don't worry this is a war.. there are spies everywhere.. don't leave the house without your tin hat
Patrick. is offline
Old 07-30-2009, 08:02 AM
ertoil's Avatar
Hehehe..
¿ Plasma is better than Led ? ¿ in visuals ?
yes it is....but remember that anything behind the 3000 euro Pioneer Kuro Plasma is a cheap thing in plasma ....so what will you do ???
i think is a fact that the Pioneer LCD krl-32v (680) has better blacks than any
LG plasma!!
720p plasmas are much better for mpeg2 TDT and Divx than lcd
SD process of the Panasonic plasmas is worst than LG
for movies you can buy a G10 or a Samsung Led
It has more value a DVD-9 in your hands than hundreds of mkv's downloading
ertoil is offline
Old 07-30-2009, 07:47 PM
gus738's Avatar
Quoted: 59 Post(s)
Liked: 32
I agree lcd is unacceptable i would take plasma.
XBL x117x831
PS4 gusx831
gus738 is offline
Old 07-31-2009, 04:19 AM
ertoil's Avatar
! Depends ! my LG32PG6000 Plasma "solarisation" problem is unacceptable for me
Do you think the last Leds are unacceptable ?
ertoil is offline
Old 07-31-2009, 06:26 AM
Patrick.'s Avatar
LG plasma!!
OO you've got one of the Pioneer LCDs How are those anyways? We've never seen them over here.
Patrick. is offline
Old 07-31-2009, 07:41 AM
ertoil's Avatar
take a look ; http://www.youtube.com/watch?v=SD668olTerY
its basics are a Sharp panel and box with a Pioneer Black contrast filter and improved
circuitry, some say vivid colors look plasma-like...not the level of a Kuro plasma
of course (0.0031 cd blacks vs 0.04 cd/m2) but this is one of the best if not the best lcd
in its day..now is surpassed by Samsung Leds !
not that good for SD !! some reported Banding and clouding problems!!
ertoil is offline
Old 07-31-2009, 07:45 AM
Patrick.'s Avatar
If it's a Sharp banding is always included it seems .004 cd/m2 is a very impressive black level, from what I've seen from reviews that pretty much actually matches the LED sets and the B750 when it comes to black levels (without autodimming)
Patrick. is offline
Old 07-31-2009, 11:40 AM
rgb32's Avatar
Quoted: 42 Post(s)
Liked: 32
Kinda off topic, but...
For those interested in picking up a small LED LCD monitor, Samsung will be shipping their new XL2370 monitor next month! I believe the XL2370 will replace the announced, but not released P2370L. The Syncmaster XL2370 is a 23" monitor with a native resolution of 1920x1080, DVI-I and HDMI inputs, and analog and optical audio outputs (for HDMI audio data). It should be under 4 bills!
http://www.crunchgear.com/2009/07/06...ed-hd-monitor/
rgb32 is offline
Old 07-31-2009, 11:55 AM
Nielo TM's Avatar
I bet my life that 0.04 was achieved with the help of dynamic backlight.
Nielo TM is offline
Old 07-31-2009, 02:06 PM
ertoil's Avatar
rgb32 thanks for the info man ! that Samsung monitor looks terrific !
Nielo TM...yeah for sure....but it is not bad
The new Samsung LE32B450 (no LED) calibrated reachs the same 0.04
for sure with auto dimming or something like that..
Samsung was a cheap low quality brand for me...but..something is changing
For the comparison freaks (like me) ; (Pioneer euro model names)
Panasonic TX-P42V10 Plasma : 0.03 out of the box
Panasonic TX-P42G10 Plasma : 0.03 calibrated
Pioneer PDP-4280XD 8G Kuro plasma : 0.03 calibrated
Samsung Leds : 0.03 to 0.01 auto dimming
Pioneer PDP-LX5090 9G Kuro plasma : 0.0031 amazing
Pioneer PDP-KRP-500A Kuro plasma : 0.0025 reference (more than 7 billion colors)
with the biggest grey scale in the market too !
ertoil is offline
