Need recommendations for flat panel under $1400. Please help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-12-2006, 08:02 AM - Thread Starter
dealeo's Avatar
My office has a budget of $1400 for a flat panel TV for the weight room. We would like a 42", but the usual suspects, Panny 60U and Samsung 4253, are about $150 more than that.
We really don't need any special features since it is for a weight room and there want be much interaction with the TV other than channel changing. I think they are not even going to have high def programming in there, so maybe EDTV would be better? Would we better off dropping down to a 37" or buying a budget 42"? Recommendations for either are GREATLY appreciated.
I just wanted to hear what the experts thought. ; )
Rob
dealeo is offline
post #2 of 5 Old 10-12-2006, 12:58 PM
Brian_M's Avatar
Sounds like an ED panel would be pefect for your situation since it's for a weightroom and there is no HD programming. I would suggest taking a look at the Samsung SP-S4243 or Panasonic 42pd60u.
Brian_M is offline
post #3 of 5 Old 10-12-2006, 02:47 PM - Thread Starter
dealeo's Avatar
Thanks! Those were the two I had narrowed it down to. I think we're going with the ED Samsung you mentioned.
dealeo is offline
post #4 of 5 Old 10-12-2006, 03:17 PM
jimreeves's Avatar
[EDIT] IMHO you'll se better black levels and ntsc processing with the Panny than the Sammy, that's why I bought one.
Jim
My system 2013-14
Panasonic TC-P65ST60, TH-50PX75U, Pioneer VSX-33, BDP-150, Fios, Yamaha RXV2500-P2200x2, Infinity QLS, M&K V-75x2
jimreeves is offline
post #5 of 5 Old 10-12-2006, 03:49 PM
FEAR's Avatar
Sammy 4243 [EDIT], I Got One In My Kitchen
FEAR is offline
Closed Thread OLED Technology and Flat Panels General
