Master list of LCD/PLASMA with 1:1 pixel mapping - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 179 Old 07-03-2007, 10:27 AM
rvh4's Avatar
Can anyone tell me if the Panasonic TH-58PX60U Plasma display will do 1:1 mapping over HDMI? My purpose is for use with a video processor and I am trying to determine if this plasma will support 1:1 mapping based on the settings I can drive from a DVDO VP20.
Best Regards,
Rob
rvh4 is offline
post #92 of 179 Old 07-03-2007, 02:29 PM
lexx_kun's Avatar
60U won't do 1:1. 600U will.
lexx_kun is offline
post #93 of 179 Old 07-03-2007, 11:49 PM
rvh4's Avatar
I had researched the differences between the 60U and 600U and this one NEVER came up. That is a significant difference. Did you get this confirmed directly from Panasonic? Do you know if it will accept 1:1 mapping over HDMI or is it only with the VGA input?
Rob
rvh4 is offline
post #94 of 179 Old 08-20-2007, 04:42 PM
xr7
xr7's Avatar
Sharp LC-32d50u.
PC hooked up via DVI, running 1360x768 with Dot by Dot Mode.
xr7 is offline
post #95 of 179 Old 08-20-2007, 10:14 PM - Thread Starter
bobn4burton's Avatar
Added to list...
bobn4burton is offline
post #96 of 179 Old 08-21-2007, 05:00 AM
jmallory's Avatar
LG 50" Plasma 50PX1D 1360x768 (Velocity Micro Cinemagix Grand Theatre with Nvidia 8800 Series card, latest drivers) over the HDMI/DVI input
-- Jim
jmallory is offline
post #97 of 179 Old 08-21-2007, 10:03 AM
magnetx's Avatar
hi,
any help would be appreciated on this matter..
thans in advance..
magnetx is offline
post #98 of 179 Old 08-22-2007, 09:44 PM
Nick Burns's Avatar
What? No DLPs?
Not as lean
Not as mean
Still a Marine.
Nick Burns is offline
post #99 of 179 Old 09-06-2007, 07:39 AM
flyck's Avatar
Both Sharp LC-52XD1E and LC-46XD1E support "dot-for-dot" 1080p by manual setting.
In "Wide modes" menu select "Underscan"
(If "Full" is selected, the image is croped)
The default is Full.
I tested on EXT 6 terminal (HDMI)
Extract from the manual:
Full: Display with the Overscan image. Crop all sides of
screen.
Underscan: Display with the underscan image.
(Display with the High-Definition image compressed
optimally. Noise may appear on the edge of the screen
with some programmes.)
flyck is offline
post #100 of 179 Old 09-06-2007, 08:45 AM
flyck's Avatar
This TV is some 3 year old, but I decided to post anyways:
Samsung LTP468W does support "1 for 1" on DVI port only when supplied with 1080p. However, the timing must be "reduced blanking" - 138.63MHz instead of the standard CE format with full blanking - 148.5 MHz
HDMI port supports max 1080i and does overscan (crop all sides) when supplied with 1080i or 720p
The natural resolution of this set is 1920x1080, and when supplied with 720p it overscans (both HDMI and DVI)
When I try to feed 1080p over HDMI port, it is scaled to 1280x1024 and no cropping...
flyck is offline
post #101 of 179 Old 09-17-2007, 03:38 PM - Thread Starter
list updated...
post #102 of 179 Old 09-22-2007, 01:58 PM
Hal900x's Avatar
The entire new Regza line supports it..."Native Mode"
Hal900x is offline
post #103 of 179 Old 09-22-2007, 06:15 PM - Thread Starter
Sorry, I'm not familiar with the 'Regza' line. What brand? LCD/PLASMA?
post #104 of 179 Old 09-24-2007, 02:01 PM
tnynyn's Avatar
regza line is from toshiba. great post btw, im in the market for a tv that'll double up as a decent monitor.
tnynyn is offline
post #105 of 179 Old 09-25-2007, 01:40 PM
AlenK's Avatar
All XXPFL7422D and XXPFL7432D models (1080p LCD) from Philips where XX = 42,47 or 52 do 1:1 pixel mapping, HDMI input, select "Unscaled" in Format menu.
AlenK is offline
post #106 of 179 Old 09-25-2007, 10:52 PM - Thread Starter
Added to the list, thanks!
post #107 of 179 Old 10-04-2007, 12:44 PM
poraxan's Avatar
Looking at the Toshiba Regza manual for the 177 model, it only supports it through HDMI. Using the PC input maxes you out at 1024 x 768, well short of the 1920 x 1080.
poraxan is offline
post #108 of 179 Old 10-04-2007, 01:58 PM
tower101's Avatar
You can add a Panasonic 50PZ77U, 1080 over HDMI, setting HD size2. That would go for the 42PZ77u, 50pz700u and the 42pz700u as well.
tower101 is offline
post #109 of 179 Old 10-05-2007, 10:02 AM
HailTheHD's Avatar
For me when I use full pixel for my XBOX 360 Elite hooked up to my KDL-52XBR2 via HDMI, the edges look a look a little rough. Like the picture is under scanned.
HailTheHD is offline
post #110 of 179 Old 10-08-2007, 09:19 AM
joewagner501's Avatar
Just a quick thought. Do these TVs offer the ability to enter the BIOS as well? Or do you not see the post screen of the HTPCs?
joewagner501 is offline
post #111 of 179 Old 10-08-2007, 12:49 PM
lexx_kun's Avatar
Typically a PC's behavior will be to output video (lower than VGA res i think) to all outputs at boot time. The vast majority of current-day TVs will be able to handle displaying such a signal. So yes, you should be able to use an HDTV as a display to muck around in your PC's BIOS.
lexx_kun is offline
post #112 of 179 Old 10-08-2007, 03:20 PM
You would think that is the case but sadly it isn't. Which is why I asked. My old DLP didn't show the post and my new TV will show it on the DVI input but not the HDMI.
post #113 of 179 Old 10-08-2007, 10:56 PM - Thread Starter
List update...
post #114 of 179 Old 10-09-2007, 07:55 PM
michael1996's Avatar
Does Westinghouse TX Series ( TX-42F430S, TX-47F430S ) support it?
thanks
michael1996 is offline
post #115 of 179 Old 10-10-2007, 10:12 AM
dizzy0113's Avatar
Sharp Aquos 46D92U DVI connection - Dot by Dot mode 1920 x 1080p
I also have read in other forums that the Sharp Aquos 46D64U works in dot by dot over HDMI, but I went with the 92U instead which Im using right now to type on the forum
dizzy0113 is offline
post #116 of 179 Old 10-10-2007, 02:03 PM
lexx_kun's Avatar
In answer to a previous question asking about DLPs:
DLP, SXRD, D-ILA, and RP-LCD:
Rear projection technologies generally cannot do "dot for dot". They typically don't use software overscanning, but the image they throw is typically 2-5% larger than the boundaries of the glass frame it hits. So they DO "dot for dot" but those dots are hidden behind the edges of the frame.
Note: this limitation does not exist with front projectors, only RPTV sets.
lexx_kun is offline
post #117 of 179 Old 10-15-2007, 10:46 AM - Thread Starter
small list update...
post #118 of 179 Old 10-15-2007, 01:37 PM
Hal900x's Avatar
Panasonic TH-50PZ750U
Currently using Component, although should work for HDMI as well
Picture settings/other settings/Size 2
Note: 1:1 on this set only applies to it's native rez (1080p). You cannot get it to display, say, a 1280x720 window in the middle of your screen. You can only remove the 5% overscan of a 1080p signal. So I would put this and most other Panny sets in the "sort of" category.
Hal900x is offline
post #119 of 179 Old 10-20-2007, 11:15 PM - Thread Starter
I think we have pretty much assumed this with the current list. Added your set to the list...thanks!
post #120 of 179 Old 10-21-2007, 10:48 AM
TommyV's Avatar
I am able to get 1:1 for 1360x768 on VGA and HDMI with my Pioneer PDP-5080HD with a small black line down the side of the screen. I do wish there was a way to input a custom resolution though of 1365x768 or 1368x768 but it does not seem like the Pioneer will accept it. Any other plasma owners using this resolution? Should I be worried about that black line? You can not see it unless your face is literally inches from the screen.
TommyV is offline
Reply OLED Technology and Flat Panels General
