HELP with a quick question...Sharp LC-32d40u redness on blacks??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-02-2007, 01:56 AM - Thread Starter
The_Madness's Avatar
Is there something wrong with my tv or is it on all sharp lc-32d40u's?? Lets say I have the brightness a little lower or at the lowest it will go the black seems a bit red. Also if i view the tv from any sort of angle (up,down,left,right) it also has some sort of redness to the screen. Being that this is my first LCD flat panel tv ever is it like this on all tv's or just mine or my model? Its just that the full black of the tv seems a bit red for some reason.
The_Madness is offline
post #2 of 2 Old 01-06-2007, 08:48 PM
lenjack's Avatar
I have virtually the same same set, the 41 not the 40. Sharps are noted for emphasizing red. I cannot get the color turned down far enough to get the red out. I've got a calibrator coming out next week. Your problem sounds worse.
lenjack is offline
Reply OLED Technology and Flat Panels General
