Samsung 215TW Text so small...? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-05-2007, 06:21 PM - Thread Starter
realdeal1115's Avatar
I just upgraded from a 19" CRT to the Sammy. I used to run my 19" at 1024x768.
The native resolution of the Sammy is 1680x1050 but the text seems soooo small and when I change to a lower resolution, the picture isn't as sharp.
Since I am new to the LCD group, I was wondering is anyone can please help me out. Thanks
realdeal1115 is offline
post #2 of 3 Old 01-05-2007, 07:21 PM
Ozzmatron's Avatar
Have you tried raising you text dpi? If not, right click anywhere on the desktop, goto Properties, Settings, Advanced; then under the General tab at the top of the menu, you'll see a DPI setting, which should be at 96dpi. Change that to the larger size, 120dpi I think. You'll have to restart before the change takes effect, but it should make your text a more suitable size.
Ozzmatron is offline
post #3 of 3 Old 01-05-2007, 07:50 PM - Thread Starter
Yes, I tried that but it made everything look kind of funky. Mayne this is something I just have to get used to. If not, I think I will return this monitor
Reply OLED Technology and Flat Panels General
