Need some advice on LCD vs Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 12-14-2007, 08:31 AM - Thread Starter
final_thrill's Avatar
Hi everyone!
I've decided to get back into the market for a new tv. I currently have a 30" LG super slim that I am happy with in terms of performance, but I want a bigger tv. I'm thinking I have to go either LCD or Plasma because I have some extreme viewing angles in my living room, so I don't think DLP will work well for me. I'm targeting something in the 40-50" range. My main focus is to minimize motion blur because I watch alot of sports and play many videogames. I know that nothing will perform like a CRT, but I want to minimize any motion blur that I will have to deal with. I'm leaning towards plasma because of the LCD motion blur, unless the new 120hz LCDs have eliminated the motion blur.
Any advice would be welcome.
final_thrill is offline
post #2 of 24 Old 12-14-2007, 08:39 AM
flood222's Avatar
I went from a 32" sony XBR450(1080i) CRT to a 42" panny 1080p plasma. The plasma looks everybit as good as the CRT. I've had no issues with ghosting/blur/IR.
The 360 isn't good enough for the display and is the limiting factor.
I've got a 700U
flood222 is offline
post #3 of 24 Old 12-14-2007, 08:46 AM
cjm7c's Avatar
It sounds like you've done your research and you know exactly what you want. In general, plasmas are superior to LCDs (even those of the 120 Hz variety) when it comes to viewing angle and displaying fast motion scenes.
The typical short list for 50 inch plasmas:
* Pioneer PDP-5080HD
* Panasonic TH-50PZ700U
* Samsung FPT5084
Check this stuff out first. There is pricer stuff out there, but these seem to be the most accessible.
cjm7c is offline
post #4 of 24 Old 12-14-2007, 09:21 AM - Thread Starter
Is there a glare factor at play? Or does that vary from tv to tv? For example my 30" LG CRT has an anti-glare finish which works amazingly well. Am I going to sacrifice some glare issues moving to plasma?
post #5 of 24 Old 12-14-2007, 09:29 AM
dlconner's Avatar
In all honesty, it is going to depend on where you put the TV...do you have a lot of outdoor light coming in? Can you control the lighting, (indoor and outdoor)? If it can be controled, who cares about glare? I have my 50" plasma sitting on a west wall facing 2 huge east windows....in the morning the glare is MASSIVE, but if I just drop the blinds it is easily watchable...and during the afternoon/night, which is when I use it 95% of the time, lighting is a non-issue, (sun is on the other side of the house). Older plasmas were much worst for glare/reflection due to two layers of glass, but companies like Pioneer are going to 1 layer glass + 1 plastic filter, which significantly reduces glare.
As for some of your original questions....blur/ghosting is a concern with many LCD's, but you are not going to have that issue with plasmas. Be gentle with a plasma for the breakin period if it makes you feel better, and just vary your content, and you will have a far superior picture IMO...and wait until you see a xbox360 or ps3 on it .... OOOOooooooo
dlconner is offline
post #6 of 24 Old 12-14-2007, 09:41 AM
tripleM's Avatar
Quoted: 13 Post(s)
* Samsung FPT5084
Can you suggest those 3 brands but 1 tier down in price?
The 3 u listed are in the 2000 range.
Looking @ the 1500 would be more like it for me.
Of course I could be just asking for some nuisance like flickering @ that price range.
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #7 of 24 Old 12-14-2007, 09:46 AM
cjm7c's Avatar
Sure. Check these out:
* Samsung HPT5064
* Panasonic TH-50PX75U
Unfortunately you can't get anything much cheaper from Pioneer.
cjm7c is offline
post #8 of 24 Old 12-14-2007, 09:58 AM
gdavismn's Avatar
CC has the 5054 Sammy onsale...can't say price here...but let's just say it's right where your looking and it's a good set.
gdavismn is offline
post #9 of 24 Old 12-14-2007, 10:37 AM
DPowers's Avatar
Quoted: 39 Post(s)
Liked: 55
* Samsung HPT5064
I second those choices! Here's more:
TH-50PC77U
TH-50PE700U
TH-50PX600U
TH-50PX60U
TH-50PX6U
TH-50PX50U
HP-T5044
HP-T5064
HP-T5034
These should all be around your price range. Good luck!
DPowers is offline
post #10 of 24 Old 12-14-2007, 10:54 AM - Thread Starter
I'm looking for a 1080p display, what will that limit the best choices to?
post #11 of 24 Old 12-14-2007, 11:07 AM
dlconner's Avatar
Pioneer or panasonic in the current generation both have very good 1080p models. I, myself, would go for a Kuro (Pioneer) hands down, but check them both out to see what you like best.
dlconner is offline
post #12 of 24 Old 12-14-2007, 11:12 AM
cjm7c's Avatar
* Pioneer PRO-110FD
* Pioneer PDP-5010FD
* Panasonic TH-50PZ77U
* Panasonic TH-50PZ750U
* Samsung FPT5084
All are 1080p displays.
Panasonic also makes some professional models which are highly regarded. I haven't seen any in action at the 50 inch size so I can't vouch for their quality.
cjm7c is offline
post #13 of 24 Old 12-14-2007, 11:40 AM
tripleM's Avatar
Quoted: 13 Post(s)
Yeah. I worry about the flickering issue though. But if that is resolved, it is a great value esp. with the high contrast ratio.
tripleM is offline
post #14 of 24 Old 12-14-2007, 11:41 AM
tripleM's Avatar
Quoted: 13 Post(s)
* Samsung HPT5064
thanks. Looks like Samsung & Panasonic dominate up & down this segment for sure
tripleM is offline
post #15 of 24 Old 12-14-2007, 11:48 AM
cjm7c's Avatar
No problem. I like that particular Samsung. I don't know how it performs compared to the Panny, but in my opinion it looks really good.
cjm7c is offline
post #16 of 24 Old 12-14-2007, 11:55 AM
tripleM's Avatar
Quoted: 13 Post(s)
I think when you look @ this 'value' segment where it's not entry level per se but not upper level for sure, there are compromises.
I was really set on the Price/performance with the Sammys until the 'flicker' issue kept coming up in thread discussions.
The Pannys are bulletproof & it appears you definitely get what you pay for.
This will be my first Plasma not to mention flat screen - coming from a 20th century rear projection Tosh - so I am a little bit more cautious than usual.
As this literally is a big jump into the unknown for me.
Haha Thanks again to all.
tripleM is offline
post #17 of 24 Old 12-14-2007, 02:05 PM - Thread Starter
This is pretty much a jump into the unknown for me as well. Even though my current HDTV is only 2 years old, when I did all my research for it I never looked at plasmas.
So i guess my ultimate question now is which plasma in this segment is the best, irrespective of price?
post #18 of 24 Old 12-14-2007, 02:21 PM
joemama127's Avatar
I highly recommend the Panasonic TH-50PZ700U or if glare is an issue then the TH-50PZ77U would do nicely. I have the 42" version of the 77U and love it. Once you go plasma it will be hard to ever go back to an lcd as your main HT set.
"The quickest way to get over your fear of plasma is to actually own *one"- joemama127
*or 3 :)
joemama127 is offline
post #19 of 24 Old 12-15-2007, 07:20 AM
gdavismn's Avatar
You know I do seem to see a flicker ,but it seems to only be on certain channels so I don't believe it to be the set. It has not happened during a movie yet, but I have only had it 2 weeks...and I love it so far.
Have fun finding a set...took me 2 months before I leaped at a deal I thought was worth it for a tv I liked the picture on for the price.
gdavismn is offline
post #20 of 24 Old 12-15-2007, 11:09 AM - Thread Starter
Maybe asking which one is the best isn't a cut and dry answer, like everything else in the home theatre business lol.
post #21 of 24 Old 12-18-2007, 02:44 PM
cjm7c's Avatar
Well, irrespective of price, I think the Pioneer PRO-110FD is the best 50" 1080p plasma (neglecting stuff from Fujitsu and Runco of course).
Of course picture quality is subjective and everyone has their own opinion about what is actually best.
cjm7c is offline
post #22 of 24 Old 12-19-2007, 03:53 PM
xb1032's Avatar
Liked: 26
IMO the Pioneer Kuros and Samsung 71 series LCDs are about the best looking sets out there. I've been through a number of DLPs and an SXRD and they aren't in the same league as a good plasma or LCD IMO. And if gaming is your primary thing you might want to see if you can demo a 120Hz LCD and see how they handle gaming. The 120Hz option makes HD movies look very 3D'ish like you won't see on another display. This might be quite appealing on games so long a the motion is smooth and without ghosting. I personally haven't seen gaming on a 120Hz display.
Another thing you might want to consider is that news for the 08' TVs will come out next month. IMO plasmas need to be brighter and from what I've heard at least next years Panasonics are supposed to get brighter and black levels are supposed to be closed to the Pioneer Kuros and they are also supposed to be much cheaper. Panasonic's new models typically come out in the April/May time frame. If you already have an HDTV now it might be worth the wait for the new models.
xb1032 is offline
post #23 of 24 Old 12-19-2007, 06:34 PM
Auditor55's Avatar
If Panasonic comes out with a Plasma that's brighter with blacks equal to the Kuro and much cheaper, is that bad news for Pioneer?
I just hope Panasonic decides to add "lighter" to the discription of their new designs.
Auditor55 is offline
post #24 of 24 Old 12-20-2007, 11:29 AM
xb1032's Avatar
Liked: 26
I'm sure it will be at first if Panasonics plasmas come out in the spring as they typically do. My only info is what I've read on this board. Supposedly the blacks are supposed to be closed to the Pioneer but not quite there. If the displays are brighter then that will make make the small amount of difference less obvious. When you are talking 60" screens, plasmas need a boost in brightness. That's starting to become as important to me as deeper black levels. Panasonic needs to get whiter whites as well. Pioneers whites are much whiter than Panasonics (as is the Sammy plasmas as well).
My 60" Kuro is about 40lbs lighter than last years 58" Panasonic so hopefully they will get lighter as well. It will be interesting to see how much improvements there are in LCDs as well. In some scenes I like the 71 better than my Kuro but in other scenes it really lacks color and looks washed out.
xb1032 is offline
Reply OLED Technology and Flat Panels General
