UTV HD Re-Image - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-19-2009, 05:11 PM - Thread Starter
eea123's Avatar
I give up!
Dialup keeps dying on me a various points on my new 80Gb HD install. I picked up two more used RCA UTV units. One wants to dial up right out of the gate, probably why the auction came with two. The other one, worked for about a day and started head clinking on the HD. It's constantly trying to dial out for an upgrade. No dice with my GTE/Verison rural connection (I had to wait a month for a private line, party lines are still common). Good news is I can offer the dual line feed I ran tested good, 87 on tuner 1 and 90 on tuner 2, when it was up.
Any kind soul willing to image one or two of the HDs if I mail them and pick up the return?
Thanks in advance.
eea123 is offline
post #2 of 8 Old 05-20-2009, 09:29 AM
Kazak's Avatar
You have a PM
kazak
God split himself into a myriad parts that he might have friends.' This may not be true, but it sounds good - and is no sillier than any other theology. - Lazarus Long
Kazak is offline
post #3 of 8 Old 05-20-2009, 01:02 PM
guitars911's Avatar
Have you tried connecting a phone line right into your phone box located outside your home? This will provide the best possible connection you have at your place. It eliminates poor inside wiring, if that the case. Also try at different times throughout the day. I had a few failures the last time I dialed out for V3.8. I was surprised to find that 4pm worked the best over late at night / early morning.
Can you take the unit into where your work and find an analog extension to try there? Fax line, etc.
guitars911 is offline
post #4 of 8 Old 05-20-2009, 02:12 PM
lgodave's Avatar
I do feel bad for eea123 having such poor phone lines...
I thought I had it bad in my GTE/Verizon market... Where I'm stuck if lucky with somewhere around 40K with dial up (no options for ISDN/DSL this far out...). Luck for me I have a local Motorola Canopy Wireless Broadband setup which is working rather well.
lgodave is offline
post #5 of 8 Old 05-24-2009, 11:45 AM - Thread Starter
eea123's Avatar
Thanks everyone. We have HughesNet sat service for our ISP (another whole set issues, but does work most of the time). Verizon/GTE isn't even thinking about DSL in my area. We had dialup a few years back. Connection speed didn't seem to be the problem, but I did seem to get dropped connections an hour or so into a session. I assumed it was the local dialup ISP, but was/is probably the phone company.
Interior lines should all show to be good. I installed them myself, using a commercial grade block and ground. All connections are home run back to the block. Not a big deal doing it before the contractor hung the drywall. I also ran the previously mentioned RG-59 wiring and some Beldon 3-conductor for a Niles IR system. Actually was pretty fun until the electrician tried charging me for my own boxes. I think I ended up with 20 or so for volume control, IR, phone and cable. All of mine were plastic and his were metal. Pretty easy to sort out, but always check those invoices.
eea123 is offline
post #6 of 8 Old 06-18-2009, 12:48 PM - Thread Starter
eea123's Avatar
Thanks to Kazak and UPS, back in business.
eea123 is offline
post #7 of 8 Old 06-19-2009, 06:46 AM
Kazak's Avatar
Glad to hear it
Oddly enough, while I was waiting on yours one of my ancient 120g drives started screaming like a slapped baby and died. I had to dig out an old 40g from one of my parts machines so I had practiced before yours came.
Glad it worked.
kazak
Kazak is offline
post #8 of 8 Old 09-26-2009, 05:27 AM - Thread Starter
eea123's Avatar
Still going strong, knock on plastic. I picked up an old version of WinHex (full) and may give the re-imaging a try next emergency. My current problem is backing up some of the recorded content. I'm still looking at standalone DVD recorders. 80Gb fills up quick! Thanks again.
eea123 is offline
Reply Microsoft UltimateTV PVR
