no 16:9 for hd channel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-29-2009, 05:45 PM - Thread Starter
MightyEric's Avatar
While i realize that UTV doesn't do HD, I expected that since there's a 16:9 setting that it would display it properly, but mine doesn't seem to.
I'm watching the Dallas Cowboy game on my 16:9 tv, with the UTV set to 16:9 in the Picture size settings, and still the sides of the screen are cut off as evidenced by information missing from both ends of the score banner across the top of the screen.
Am I doing something wrong? Or is there more to this HD/16:9 than I understand?
MightyEric is offline
post #2 of 5 Old 08-29-2009, 08:06 PM
lgodave's Avatar
I've had similar issues trying to get my UTV to display 16:9 for my HDTV...
Have you verified that your TV isn't "converting" the feed or causing a conflict.
Is there a way to verify that the channel feed you have is actually broadcasting a 16:9 feed? The UTV might default to a 4:3 feed if it isn't getting 16:9... Kind of like the Dolby Digital feed... it will output optical Digital even when Dolby isn't broadcast and switch when it is available.
Since the Digital Transition my Locals are all "cropped" (DTV is re-broadcasting the various channels' Digital OTA) and my attempts to view some of that cut off content is not possible unless I switch to the live OTA feed.
lgodave is offline
post #3 of 5 Old 08-30-2009, 06:08 AM - Thread Starter
MightyEric's Avatar
yeah, the TV seems to be good...
my best guess is that either the local station is cropping before sending to DTV since it's standard def, or that DTV is cropping to save bandwidth.
It's probably time to consider the HD leap after all...
post #4 of 5 Old 08-31-2009, 12:34 PM
Tinkerin's Avatar
The only programming that I have seen use the 16:9 feature of UTV is NBC Universal content on NBC and USA channels. It seems to require a signal to expand a compressed 16:9 image to its full width. It has nothing to do with HD since the feature far predates HD. I am sure that other channels that have been showing letterboxed content on 4:3 signals probably would work with this feature but it is getting rare.
The best we can hope for short of ditching UTV for HD equipment is programming on standard signals that are broadcast in letterbox (without this signal) that we can use the zoom feature on HD sets to fill the screen (HBO original programming works well but not movies, most channels currently on DirecTV not showing a pan and scan version of the show).
Refusing to ditch my UTV for now!
Tinkerin is offline
post #5 of 5 Old 09-26-2009, 05:06 AM
eea123's Avatar
Agree with the observation on limited letterbox format with SD DirecTV / UTV. However, I have a 4:3 projection television and set the UTV to the same 4:3, so I guess I am relying on the upstream feed for the 16:9 signal. No weirdness with stretching of the picture.
On a side note, TCM broadcasts almost everything in letterbox, uncut and without commercials. I see Spike, BBC-America and AMC still showing letterbox movies as well, however they suffer from commercials. I use the advance search feature and select letterbox when searching for content. I bet 2/3 of the returns are TMC.
eea123 is offline
Reply Microsoft UltimateTV PVR
