Random pixelization / blocks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-20-2010, 10:26 AM - Thread Starter
eea123's Avatar
Every now and then I get a program with some pixelization / blocks on my UTV. Seems to happen most with HBO. I traveled on business last week and noticed the digital cable service had similar pixelization / blocking on Treme. Curious.
eea123 is offline
post #2 of 2 Old 04-20-2010, 09:45 PM
lgodave's Avatar
Don't know the Transponder for HBO off hand... If you found out which one that was... you might see if your UTV is getting a clean/strong signal.
Now if you had access to both Cable/UTV feeds (or had a friend record it) you could compare notes.
lgodave is offline
Reply Microsoft UltimateTV PVR
