OTA Recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 12-26-2011, 02:46 PM - Thread Starter
eea123's Avatar
This probably does not belong here, but I ask so that I can get this answered from a UTV users viewpoint.
We just put up a TV tower and are now getting some of my locals. I still pay for Eastcoast and Westcoast feeds, so I can UTV them but we had lost our PBS a few years back even though I challenged and won waivers from the local CBS and FOX stations on being in a fringe area. Our PBS station filed backruptcy and forced everyone off the national feed (eventhough it took a 35ft tower to get them, clowns).
I have a RCA DRC8335 a combo DVD-R & VCR with ATSC which I'm actually using as a tuner for our old CRT. The DVD-R is single layer, so its only 1hr at max resolution. I can get the unit to work with the RCA UTV's remote but would like a HD option.
Okay, so here is my "wish list" of features:
- OTA recording
- ideally no mothly subscription for OTA (maybe the rumored DirecTV - TiVO?)
- Ethernet for streaming (a $ subscription is understood for this)
- DVD Buring (if no ethernet)
- RCA compatibility
It might be easiest to go the PC tuner card route once we get a new computer this summer, but for now I only have a 40Gb HD, 2.2GHz P4 which won't cut it.
eea123 is offline
post #2 of 22 Old 01-01-2012, 09:39 AM
lgodave's Avatar
http://news.cnet.com/8301-17938_105-20011472-1.html
While I haven't really used it much (I bought it when it's death and the CM-7000PAL was basically announced and I didn't want to pay the price bump for an identical product) and it doesn't seem to be hitting all your "wish list" wants... It ain't too bad if you can basically return yourself back to the simpler days of VCR Timer programming. (Timers are not guide based but hard coded to a specific time and channel... so catching a Marathon of a favorite show may require some watching of the TV GUIDE or an alert TV watcher.)
Covers:
- OTA recording
As for RCA UTV Remote compatibility? I can't say I've tried but I suppose I could look into it.
lgodave is offline
post #3 of 22 Old 01-08-2012, 06:16 AM - Thread Starter
eea123's Avatar
Thanks, I was actually looking at the Channel Master offering when reviewing OTA antennas. Certainly something to consider as the path of least resistance. Does it have an ethernet connection or anything that would let me drop and drag digital records across to my PC for archiving?
I could always still 1:1 record on the DVD-R unit but you know, that is slow and often doesn't happen. I think Philips and Sony had update to the RCA combo DVD-R / VHS unit that nicked the VHS side for a 320Gb HD. I assume that is still a 1:1 transfer and would likely lose my RCA remote.
eea123 is offline
post #4 of 22 Old 01-14-2012, 11:22 AM
lgodave's Avatar
As best I'm aware it has no Recording "backup" capability via Ethernet or USB although it has both connections. The Network Connection and USB I think are basically for "Upgrade" functions. When I purchased mine... I do recall it taking an update then via Ethernet. Don't currently have it connected... Probably a good idea in case there has been anything new... but I suspect there hasn't been.
lgodave is offline
post #5 of 22 Old 01-31-2012, 04:30 PM
TheCleaner's Avatar
eea123,
I saw your thread an figured I'd reply. I'm in the same boat as you and have narrowed down some options. Hope it helps.
  • boxee live tv
  • simple.tv
  • HD homerun w/ win7 htpc
  • Tivo
Since we don't get the options that people outside the US get...that was the best I could come up with. The Channel Master stuff (especially the new 7400) got pretty crappy reviews as of late, except for the DTVpal but not sure how long that product will even last.
Personally, I'm going to start with HD Homerun and a win7 htpc. I figure I'll be investing around $400 total, but it will also allow (again hopefully) for a good 3-4 years worth of DVR/EPG/etc.
TheCleaner is offline
post #6 of 22 Old 02-05-2012, 08:24 AM - Thread Starter
eea123's Avatar
Seems like they are lots of options, none just boxed up into a single set though. Now with TV's having some of the web features built in, we should be seeing more of this sort of stuff? I'm still leaning towards the WD Media Server route, if only I could find a decent priced equivalent with TV tuning built-in.
eea123 is offline
post #7 of 22 Old 02-16-2012, 07:56 AM
TheCleaner's Avatar
ee,
Just fyi if it helps.
I ended up with a Tivo Premier from Ebay and transferred their $129/yr service. Love it.
I started off with the HD homerun and an htpc but it was such a pain to use. Granted it worked quite well and would probably be a great choice if your family is technical enough.
The problem I had was that the wife and kids simply wanted to "watch tv", so the Tivo was a great buy for us.
post #8 of 22 Old 02-18-2012, 04:07 AM - Thread Starter
eea123's Avatar
Thanks for the input. Next step is to get the TV tower guy back over to aerial mount the cellular modem antenna for a steady 3Mb/s connection.
Your apporach sounds like the Ying and Yang of DVR days gone by with a TiVO and UTV sitting side by side.
eea123 is offline
post #9 of 22 Old 05-05-2012, 03:58 AM - Thread Starter
eea123's Avatar
Still trying to coordinate the tower climbing guy with the cell service guy and the electrican.
eea123 is offline
post #10 of 22 Old 07-10-2012, 05:11 AM - Thread Starter
eea123's Avatar
Well, we had the tower guy out. The 3G cell service is still pretty iffy at the moment. The heatwave has reeked haovic on their equipment, but we did get the Yagi installed and I also added a FM turnstyle antenna. First time I had decent FM in nearly two decades!
Having heard The Cleaner's experience, TiVo looks more and more like the way to go. Initial read on the THR22 TiVo unit is that it will OTA?
eea123 is offline
post #11 of 22 Old 11-18-2012, 06:56 AM - Thread Starter
eea123's Avatar
Well we surrendered our UTV for DirecTV's HR24, see related post "Bowing Out". I still have grandfathered East & West coast feeds and also the locals. I can DVR all three. My 3G cell modem service actually back slide to less than 500kBs, so we switched over to WildBlue's 14Mip, 60Gb per month plan under the rural internet act. It seems to be working for the most part, although I get random DNS lookup errors. We just got the HR24 so I don't know how bad that will tax our usage, but our first month we only used 3Gb of our 60Gb plan.
eea123 is offline
post #12 of 22 Old 10-20-2016, 10:29 PM
mcls383's Avatar
Originally Posted by eea123 View Post
This probably does not belong here, but I ask so that I can get this answered from a UTV users viewpoint.<br><br>
We just put up a TV tower and are now getting some of my locals. I still pay for Eastcoast and Westcoast feeds, so I can UTV them but we had lost our PBS a few years back even though I challenged and won waivers from the local CBS and FOX stations on being in a fringe area. Our PBS station filed backruptcy and forced everyone off the national feed (eventhough it took a 35ft tower to get them, clowns).<br><br>
I have a RCA DRC8335 a combo DVD-R &amp; VCR with ATSC which I'm actually using as a tuner for our old CRT. The DVD-R is single layer, so its only 1hr at max resolution. I can get the unit to work with the RCA UTV's remote but would like a HD option.<br><br>
Okay, so here is my "wish list" of features:<br>
- OTA recording<br>
- ideally no mothly subscription for OTA (maybe the rumored DirecTV - TiVO?)<br>
- Ethernet for streaming (a $ subscription is understood for this)<br>
- DVD Buring (if no ethernet)<br>
- RCA compatibility<br><br>
aa
mcls383 is offline
post #13 of 22 Old 10-20-2016, 10:30 PM
mcls383's Avatar
aa
mcls383 is offline
post #14 of 22 Old 10-20-2016, 10:30 PM
mcls383's Avatar
df
mcls383 is offline
post #15 of 22 Old 10-20-2016, 10:30 PM
mcls383's Avatar
gg
mcls383 is offline
post #16 of 22 Old 10-20-2016, 10:30 PM
mcls383's Avatar
hh
mcls383 is offline
post #17 of 22 Old 10-20-2016, 10:31 PM
mcls383's Avatar
Well we surrendered our UTV for DirecTV's HR24, see related post "Bowing Out". I still have grandfathered East &amp; West coast feeds and also the locals. I can DVR all three. My 3G cell modem service actually back slide to less than 500kBs, so we switched over to WildBlue's 14Mip, 60Gb per month plan under the rural internet act. It seems to be working for the most part, although I get random DNS lookup errors. We just got the HR24 so I don't know how bad that will tax our usage, but our first month we only used 3Gb of our 60Gb plan.
jj
mcls383 is offline
post #18 of 22 Old 10-20-2016, 10:31 PM
mcls383's Avatar
kl
mcls383 is offline
post #19 of 22 Old 10-20-2016, 10:31 PM
mcls383's Avatar
l;
mcls383 is offline
post #20 of 22 Old 10-20-2016, 10:32 PM
mcls383's Avatar
- OTA recording<br>
lj
mcls383 is offline
post #21 of 22 Old 10-20-2016, 10:32 PM
mcls383's Avatar
j,jui
mcls383 is offline
post #22 of 22 Old 10-29-2016, 05:20 AM - Thread Starter
eea123's Avatar
Thanks for keeping this alive. Actually moved within the last year and have Comcast Xfinity. Can't say that it is perfect, but given our old rural situation with DirecTV and Wildblue, their system sings.
eea123 is offline
Reply Microsoft UltimateTV PVR
