rip utv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 09-12-2012, 05:07 AM - Thread Starter
srfrdan's Avatar
after a loose plug caused a power surge or something it appears after 12 yrs of service my utv is busted:mad: it does not see that the sat lines are connected, does this mean the tuners are shot? any help appreciated---d
srfrdan is offline
post #2 of 28 Old 09-13-2012, 02:10 PM
Kazak's Avatar
If you have not already done this: Unplug the power and sat. cables and let it sit for an hour or so and try again. Sometimes they will come back to life.
Good luck!
God split himself into a myriad parts that he might have friends.' This may not be true, but it sounds good - and is no sillier than any other theology. - Lazarus Long
Kazak is offline
post #3 of 28 Old 09-13-2012, 08:59 PM
lgodave's Avatar
Agree with Kazak...
UTVs have always been a bit touchy with "bad" power events. I've also tried using a reset/reboot code like 12357 (just restarts the UTV. You just need to reload the 14 day guide... doesn't lose anything else.)
I also like to try UTV Code 411 (Info.) which can also report your Tuners Signal %, etc.
Good Luck. I know back in the day we'd probably recommend the "Catch all" (Can't hurt if all else is lost) PULLING the ACCESS Card out, opening the case, and then checking/cleaning your case and pulling/reseating your various power cables/ribbons just to confirm it wasn't a bad contact/fuse/etc. Letting it sit for the above mentioned cool down and trying again. If you haven't done this after 12 years, it's probably due anyway. (If you haven't recently it probably wouldn't hurt either.)
lgodave is offline
post #4 of 28 Old 09-15-2012, 02:13 PM - Thread Starter
srfrdan's Avatar
thanks for the reply guys- it just doesnt detect the sat lines--i have other boxes that are fine ---d
srfrdan is offline
post #5 of 28 Old 09-15-2012, 10:30 PM
lgodave's Avatar
True... A UTV can do that sometimes. If the cable runs are testing OK with another receiver... then it's not a bad idea to disconnect the UTV's Sat cables... and test each tuner individually. I've had some luck using the Signal Strength "Advanced" option which tests your "Multi-Switch" and reports how many Sats it sees and the voltage. With that said it doesn't hurt to check your Sat. settings are correct. Or even "downgrade" it and see if the results change.
Fingers crossed something will work.
lgodave is offline
post #6 of 28 Old 10-15-2012, 02:30 PM - Thread Starter
srfrdan's Avatar
i just want to say thanx again for the suggestions guys. but the tuners are dead apparantly --one worked for a few minutes a while ago, then nothing.
srfrdan is offline
post #7 of 28 Old 10-21-2012, 08:14 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
http://www.dbstalk.com/showthread.php?t=209751
Edmund is offline
post #8 of 28 Old 10-21-2012, 08:58 PM
inkahauts's Avatar
No, as that uses the AVP as I recall. But to double check, I did some searching, and it looks like I am right. wink.gif
http://www.dbstalk.com/showthread.php?t=5157
http://www.directv.com/images/PR/factsheets/13551CRP_UltTVService_R08.pdf
Looks like old tivos are fine too...
inkahauts is offline
post #9 of 28 Old 10-21-2012, 09:02 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
good to hear that, personally don't have UTV's, but loved them when I did.
Edmund is offline
post #10 of 28 Old 10-22-2012, 01:50 PM
G_Moore's Avatar
Still hanging on for me. I downloaded 3.8 to a new drive Saturday.
Always ready to pull the lever on that La-Z-Boy.
G_Moore is offline
post #11 of 28 Old 12-13-2012, 09:23 PM
lgodave's Avatar
Just transitioned to Vonage today... For the first time I've been able to use My Living Room UTV's Call ID feature. (Cooooolllll smile.gif ) GTE/Verizon/Frontier just didn't want to bargain... I'll save the almost $20 a month thanks. Frontier's Call Waiting Feature alone cost over $6... it was time to get out of Dodge. (Basic Talk is $9.99 with fees it's around $13... Estimate Calculator said $18.15 before I signed up. Far better then Frontier's $40.49 no long distance only Call Waiting...)
Haven't experimented with attempting any Software Downloads yet (as I suspect that will be still be an issue...) but since I have noticed a couple of my UTVs aren't using both Tuners... I'll probably going to have to untangle the Rats Nest... (Which I usually avoid at all costs) and do a proper "Christmas/New Year" Cleaning. Long over due... with most of my UTVs in service over 10 years they need TLC more then every 2-3 years... or when DTV comes to install a new Multi-Switch.
Worst Case... I've got an Aunt with decent Landline service (at least she did...) might try and tie up her line for a few hours someday if I need to upgrade a Hard Drive. Living Room RCA is still using a 10 year old 80GB drive... Probably should bump it up to 160GB since it gets a lot of use.
Wishing you and your UTVs a Happy 2013.
lgodave is offline
post #12 of 28 Old 04-18-2013, 08:33 PM
lgodave's Avatar
Well the Bedroom's RCA UTV decided it wanted to give me a "Green Light of Death" and no longer recognize the Hard Drive a week or so back... So until I get around to opening it up... I've swapped over to one of my "Spare" Sony UTVs. (Since the Bedroom only has 1 cable run... my Single Tuner "Spare" seem to be OK for now.)
Someday soon I might just need to give DTV a phone call and see what the Genie is all about and if an eventual upgrade will be easy or hard... Hope to keep my UTV Service going... but it's looking far easier to centralize my Recordings and simply share between TVs (the extra tuners seems cool too). Just don't spend as much time in the Family Room anymore so a few of my DVRs are going unattended. Might save a little by consolidating a few DVRs... although it seems like with HD and "advanced DVR" Service who knows... it might still cost me more. A talk with DTV may be in order just so I'm informed.
lgodave is offline
post #13 of 28 Old 04-23-2013, 07:42 AM
guitars911's Avatar
I looked into the Genie hardware too a couple of weeks ago. One thing that stood out was that it's currently only available to NEW customers only. Existing customers may upgrade later this year is noted on DTV's web site. Is this next month, six months, end of this year?? My wife wants to rearrange our bed room and swing everything counter clock wise 45*. No coax drops where the TV would go. Not looking forward to getting in the attic and fishing / extending new wall runs to the new TV location. The Genie hardware would be an easy option for me. Looks like DTV also found a new way to add fees to your account too as they have an added fee just for the use of the wireless Genie hardware. errr...
guitars911 is offline
post #14 of 28 Old 04-25-2013, 04:50 PM
lgodave's Avatar
Got an e-mail recently that Directv's Protection Plan (that I still subscribe to) will be offering an "equipment upgrade" every two years (with 2 year contract re-up) on/after May 16, 2013... May have to see what kinds of "upgrade"(s) they'll include then.
I still "own" all my equipment so will probably be forced to start leasing DTV's stuff soon... Might be worth it to "upgrade" if they'll "throw in" a Genie and the various Client device hardware.
lgodave is offline
post #15 of 28 Old 05-12-2013, 05:13 PM
rocket's Avatar
Well, I'm now down to 3 tuners working on my 2 connected utvs. My original, bought in 2001 still works, though I have to reset it every week or two. The disk must be getting tired as well, sometimes a sports event will drop a few minutes here or there. The newer unit lasted till a few weeks ago and then one tuner went dead.
So, I plugged in my last spare and it had 3.7 on it. Took me quite a while to remember how to use a computer to put a copy of my 3.8 custom build back on it. This unit has an original 40 gig drive, whereas my 1 tuner unit has a 140 gig. Having a nice capture setup with software to remove commercials lessens the need to keep stuff on the dvr.
As to the genie, it'd be nice to combine all the tuners in one unit to avoid conflicts. I do like being able to capture the output of one utv while watching another. I guess I'd have to get one of the satellite units to be able to do this on the genie. I figure if I have no utvs then I can use the $10 for something else, like maybe the extra satellite unit.
If I get the genie, I'll have to get a new install since my current dish is using an old chimney mount - which I heard they won't allow anymore.
But I still don't like some of the features of the new dvrs. I'm a bit used to holding down the 30-sec skip instead of FFing and ditto for replay a trick I used to avoid the never fixed runnaway FF. I hear there's a backdoor to turn on 30-sec skip instead of the slip feature. But holding down the skip appears to skip 15 minutes; I'd have to be careful with that one.
Anyway, about done getting all the saved stuff off the dying utv; I hope I can still find the button on the website to activate my final utv. One more failure and I'm afraid it's curtains to the UTVs.
rocket is offline
post #16 of 28 Old 06-12-2013, 06:07 PM
lgodave's Avatar
I'm sort of in a similar boat. A Phase 1 dish older then my UTV setup.
Doing my research on a Genie upgrade... and it seems like I should have maybe bit the bullet a few years ago while we renovated our Kitchen. I'm thinking I might be stuck(practically) with my 2 RG6 runs to the Basement where my Multi-Switch is (Since the Electrician "secured" the cables for me before walling them up again... so fishing ain't going to be as much fun now.)
Supposedly older SWM setups allowed "Legacy" Ports and and OTA but I've heard conflicting info. on newer setups which might not offer it or at least are less friendly to it...
Fun Fun Fun.
lgodave is offline
post #17 of 28 Old 06-14-2013, 07:17 PM
lgodave's Avatar
After my first talk with DirecTV CSR... Looks like my Protection Plan will allow me to "Upgrade" to a Genie and 3 "Clients" (Mini-Genie), If I should want to switch those "Clients" to HD DVRs... I'll be paying for each one out of pocket. ($200 for each HR24 lease)
Sadly it looks like I will have to dump all my SD Equipment (Including my UTVs/HDVR2 Tivo/R15s) if I do this... Going from 14 (More like 11 at the moment) down to 5 would be kind of hard... Not sure I'm up for that.
Anyone got some alternatives/options... to take advantage of the HD Upgrade and keep at least one or more of my SD DVR setup going. I think I'd go crazy with the number of Conflicts that would be possible by not having an extra 6-9 Tuners at the ready. smile.gif
I can just think of the 5PM (CT) Time slot alone... I can think of 4 Shows that I wouldn't mind recording regularly. That does allow #5 for surfing... but then that leaves nobody else can use the TV.
I guess ideally I'd probably setup a "Classic" Dual RCA UTV setup (DTV/AUX) giving me 4 more tuners (9 Total Tuners) just for "Backup".
DirecTV says current SWM wouldn't let me have any "Legacy" Ports or OTA but I've heard there are some SWM 16 modules that might give me what I want...
Any tips/ideas? I've got a few UTVs that have some Tuner Failure Issues that I haven't requested "Repair" for under the Protection Plan... might be interesting to see if I can do the full Genie Upgrade while "Replacing" the failing UTVs instead of just "downsizing" (Junking) them.
Sounds like Double Dipping but I'm not beyond that as it should be "reasonable" to expect the New "2 year upgrade" (Regardless of Repair/Need) AND Replacing any old "Dead Tuner" DVRs with current units that just happen to be Whole House Compatible... (Hopefully HD but I suppose SD would do in a pinch)
lgodave is offline
post #18 of 28 Old 10-08-2013, 02:41 PM
lgodave's Avatar
Still looking for ideas. One of my R15-300's seems to have a dead fan (Unit will prompt that it's "Shutting down to cool off" and I've seen it resetting on various occasions on it's own too when it's not in use).
Thinking I'll be calling Directv soon with the game plan to get a Tech on-site with the intention of just going ahead with a full SWM upgrade but with the understanding I might just stick with my old setup (and swap/repair the R15-300 with a backup DVR I've already got) and pay for a "Hybrid" (Legacy Ports) system. All dependent on what the Tech says after giving my old DIY Setup a look.
I want it all! smile.gif The "Hybrid" I guess would be a Genie with I guess one Mini-Client and a separate Whole Home compatible HD DVR (that I can enable/disable sharing with the Genie), then maybe that classic TWO UTVs (or other SD DVRs). Should give me the "flexibility" to reduce any possible Conflicts that just having 5 Tuners for everyone would cause while still giving me access to my various "old" (Owned) hardware.
lgodave is offline
post #19 of 28 Old 02-27-2014, 04:56 PM
lgodave's Avatar
Still procrastinating... haven't even replaced the bad R15 yet. The Bedroom Sony UTV was "faking" a bad Tuner (Still had Audio and would "flash" Video when changing channels... then "Search for Sat" while giving me good audio. System Test would say 0% Tuner/Fail but again with the available Video/Audio stream.) A reset (12357) did the trick.
Got to get around to getting an upgrade. (While still keeping the Legacy Option)
lgodave is offline
post #20 of 28 Old 02-28-2014, 07:44 PM
G_Moore's Avatar
Keep pulling rabbits out of the hat !!
Mine are alive and well.
G_Moore is offline
post #21 of 28 Old 03-02-2014, 06:53 PM
buttplug's Avatar
Quoted: 16 Post(s)
Just popping in to say I still love UTV.
Everytime the HD-DVR takes forever and a day to reboot, I go reboot the UTV a couple of dozen times and the HD-DVR still will be chugging away on junky linux startup.
I think the UTV will take me through until I'm ready to cut the satellite cord, and I'll never even care to go SWM or get a modern setup. I'm glad I stuck it out with my UTV. Good times, but the future is here.
buttplug is offline
post #22 of 28 Old 04-03-2014, 01:13 PM - Thread Starter
srfrdan's Avatar
how many channels are left --my standard boxes were cut down to about 30 from 300+, my utv broke 2 yrs ago, one of my favorite features was the super fast ff ---d
srfrdan is offline
post #23 of 28 Old 04-05-2014, 03:04 PM
lgodave's Avatar
Plenty of Channels Left... Can't say I'm "missing" any. NASA TV went to the HD Side some time ago... but then I've alternative ways should I want to watch an ISS Spacewalk.
On the Retiring UTV question. It's still kicking but an HD DVR is probably not far from my future... Yet, My 32" Westinghouse TV fried it's HDMI port (The one and only) yesterday when I was sitting down to watch a DVD (Via a 3 way HDMI Switch) yesterday. Replaced it with a 42" Vizio... Just got done with the "What codes will work with my RCA UTV Remote?" dance.
Since Microsoft never updated the "Hooking Up" Remote Codes to include brands like Westinghouse (which mine used Sony codes) or Vizio (Currently using Goldstar codes) it took a little work. But just as last time... Avsforum came through for me.
Hopefully it might do so again. My Goldstar code 1006 (and several others) work for ON/OFF Power and Volume but nothing else. Hoping someone might have some experience/codes that'd allow me to switch the INPUT source. (via the INPUT button or some other button on the UTV RCA Remote).
lgodave is offline
post #24 of 28 Old 05-20-2014, 06:30 PM
Kazak's Avatar
I have 1 UTV (1 tuner) still in service. 2 weeks ago it went into "demo mode". Turns out that Dave (remember him?) just turned the UTV service off with no warning. I complained and it was turned back on.
A week later it happened again on the same day I received a letter from them telling me an audit showed that I was being charged for UTV service by mistake. A $200 credit will show on my next statement. And it did biggrin.gif
They backdated it to the time I switched to HD and Genie.
Had to dig out software and info from almost 10 years ago to get going again. cool.gif
Kazak is offline
post #25 of 28 Old 06-18-2014, 02:48 PM - Thread Starter
srfrdan's Avatar
i got the same credit for the same reason a last year---d
srfrdan is offline
post #26 of 28 Old 10-19-2014, 11:23 AM
lgodave's Avatar
Missing my UTV... (From new HR44-Genie user)
Coming up on 5 months with the Genie and while I've not looked back at my old UTVs/Tivo/DirectTV DVRs yet... I've been noticing several "limits" that I never really noticed on my trusty UTVs.
Part of it probably has to do with Dish Placement. The Standard Def Dish was partly shielded by the House and usually only went out in Severe Downpours or with Heavy/Wet Snow buildup... The HD Dish is "in the open" on the Roof and is far more sensitive to various downpours (which I witnessed on the day of Install when a storm killed signal during install/setup.).
I've been bumping up against a 100 Series Manager Limit that I never noticed on my UTVs. (Although the UTV didn't like keeping too many recordings and would tell me to delete some if I hadn't done Housekeeping in a while.) So I guess it had it's "limit" but after getting rid of some extra recordings it would let me select a show/series to record. It's rather annoying that the Genie is suppose to act as a "Server" for the Whole House and it has a silly limit of 100 Series Records. (I can "manually" record a show one at a time if I don't delete one of the 100... but it won't let me select them for series record unless it has a slot open out of a 100 entries.)
I loved PIP on the UTV, used it often... and while Genie has PIP, it's placement/selection is kind of out of the way so I find I'm not using it much.
Hope those still using UTV are doing well. Enjoy them while they last.
lgodave is offline
post #27 of 28 Old 12-18-2014, 02:59 AM
drwho2012's Avatar
Quoted: 14 Post(s)
okay will some one please explain why every one has such a devotion to a electronic device that is half as old as me i have never heard of utv subsequently has any one heard of hidef tivo tivo has died and been resurrected i have satilite and yes i am paying to much but they have a dvr i can store content till i feel like watching it now i will say that i sold my western digital live box and regretted it so i went out and bought a new one only because it plays everything i throw at unless the video is broken directv has tivo and with the tivo site you can upgrade the device new video takes up a lot of hard drive space and 1 -2 tb hard drives are dirt cheap less than a hundred dollars which i remember paying that for a hundred gigs and beside is not M.S the great Satan
drwho2012 is offline
post #28 of 28 Old 12-18-2014, 04:33 PM
lgodave's Avatar
I'll try...
I'll try and break down your "stream of consciousness" and answer your burning questions. Let me know if I'm misreading your thoughts...
Originally Posted by drwho2012 View Post
okay will some one please explain why every one has such a devotion to a electronic device that is half as old as me i have never heard of utv.
So UltimateTV was released in late 2000 and off the market around mid-2003. Tivo was/is still more well known... But if you were 14-16 back then I don't think you (or many other Teens) were big into DVRs or Smartphones at the time. I got into UTV in 2002 when most places that offered it where clearing them out for $50-$80. At the time a 40GB Hard Drive went for that... Finding a DVR for cheaper was probably impossible at that time. As a DirecTV customer at the time and wanting the ability of multiple tuners (TWO?!!), an AUX mode, PIP, etc. etc... it was a good investment.
subsequently has any one heard of hidef tivo tivo has died and been resurrected i have satellite and yes i am paying to much but they have a dvr i can store content till i feel like watching it
What's your point? By Design a DVR lets you store content for later viewing. Or are you talking about it being able to store your personal audio/video/media files on it's Hard Drive?
Not familiar with that model but sounds cool. I use a Roku,FireTV Stick, and my DirecTV Genie... each can access A/V/Media files from various outside sources... But I'd love for more "local" storage.
The UTV is upgradeable too... just can't handle 1-2TB Drives (Just up to 137GB Support) ... Sure Microsoft was/is "the great Satan" and as such created a really nice DVR that people that used it loved it... the software/UI was surprisingly solid on this device and many features are STILL hard to come-by in many modern DVRs. For various reasons it isn't as well known... probably because it was only offered by DirecTV and not offered as a standalone option or upgradable (allowing for future proofing, like allowing for Network Access vs Dialup Modem, More robust USB device support, etc.) .
lgodave is offline
Reply Microsoft UltimateTV PVR
