Need RCA remote control code for Panasonic TV - AVS Forum | Home Theater Discussions And Reviews
Old 11-14-2004, 12:21 PM - Thread Starter
cwein's Avatar
My UTV is still going strong and I recently upgraded my TV to a Panasonic Tau. Unfortunately I no longer have the user guide for my RCA unit so I was hoping someone could tell me the code(s) for Panasonic TV's that will allow the UTV RCA remote to control it.
cwein is offline
Old 11-14-2004, 12:22 PM
Artisn's Avatar
You might want to consider getting a universal learning remote. It will replace all of your remotes and simplify your life.
Artisn is offline
Old 11-14-2004, 09:41 PM
LongRufus's Avatar
The codes are in your UTV help section.
Hit the Menu-Options button on your remote and select Help.
From the Choose Topic page, select Remote & Keyboard/Setting up your Remote.
On the next screen, choose "Set up remote to control your TV" and follow the on screen instructions to enter the correct codes.
LongRufus is offline
Old 11-14-2004, 10:26 PM
boondocker's Avatar
RCA UTV remote code for Panasonic Tau: 1170
HTH
The Boondocker
boondocker is offline
