USB Keyboard & UTV - AVS Forum
post #1 of 10 Old 03-27-2001, 04:57 PM - Thread Starter
Gremlin's Avatar
Here's an interesting reviews and some updated info on UTV from the dishplayer folks ... enjoy
USB Keyboard
Sounds like an update is in the works ... source unknown..
Gremlin...
UTV --- "The Ultimate DVR"
Gremlin is offline
post #2 of 10 Old 03-27-2001, 05:58 PM
TWPaulus's Avatar
good news! I sure hope UTV comes out with a UTV usb keyboard as I hate the IR one. To hard for me to point at the uni on top of large tv. http://www.avsforum.com/ubb/smile.gif
Tom Paulus
a TV nut that's hard to crack.
Tom Paulus
ISPChoce the smiles=http://www.isp-choice.com/smilies/smilies.htm
TWPaulus is offline
post #3 of 10 Old 03-28-2001, 06:44 PM
TWPaulus's Avatar
Yes but they won't have the PTV function keys or label the same. I have enough problem trying to remember what's what. http://www.avsforum.com/ubb/smile.gif
Tom Paulus
Tom Paulus
TWPaulus is offline
post #4 of 10 Old 03-29-2001, 08:31 PM
TWPaulus's Avatar
I JUST GOT MY new rca keyboard today. I don't know if the IR is wider or my old webtv keyboard had weak batteries but I no longer having promblem of enteriing dat or having to point the keyboard at a certain angle.I really like it but it is hard to read botton in the dark.
Does anybody know of shortcut to get to bottom of post besides just hitting the scrol down button a lot? http://www.avsforum.com/ubb/smile.gif
Tom Paulus
Tom Paulus
TWPaulus is offline
post #5 of 10 Old 03-30-2001, 06:10 AM - Thread Starter
Gremlin's Avatar
Try "home" to get to top and "end" to go to bottom.. be sure number lock is off. Also try page up amd down...?
Gremlin...
Gremlin is offline
post #6 of 10 Old 03-30-2001, 12:24 PM
TWPaulus's Avatar
"HOME" does not work for it takes you back to webtv home page. There is no Page up or down button just Scroll up ad down which just page up or dow a page (screen) at time. It takes a lot to get to bottom or top of a long or many post. http://www.avsforum.com/ubb/smile.gif
Tom Paulus
Tom Paulus
TWPaulus is offline
post #7 of 10 Old 03-30-2001, 02:53 PM - Thread Starter
Gremlin's Avatar
I don't have the keyboard you are using.. I am using a MS Internet Keyboard Pro with USB.. does evething I need .. but special keys aren't assigned to bad.. http://www.avsforum.com/ubb/frown.gif .. not yet anyway...
Try using shift key with arrows.. maybe some keys are dual functions
I also found esc key takes you back to UTV..
Wish I could offer you more...
Gremlin...
Gremlin is offline
post #8 of 10 Old 03-30-2001, 03:19 PM
mplumpe's Avatar
Hmm, I thought I already replied, but I don't see my reply. Anyway, hit Cmd-Scroll Down.
mplumpe is offline
post #9 of 10 Old 03-30-2001, 08:01 PM
TWPaulus's Avatar
Thanks I will try that next time I am on. http://www.avsforum.com/ubb/smile.gif
Tom Paulus
Tom Paulus
TWPaulus is offline
post #10 of 10 Old 03-30-2001, 08:23 PM
TWPaulus's Avatar
Yes it works Thanks. Do you Know any other shortcut or uses. I am not very good at finding thing http://www.avsforum.com/ubb/smile.gif
Tom Paulus
Tom Paulus
TWPaulus is offline
Closed Thread Microsoft UltimateTV PVR
User Tag List
