Progress Bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-19-2005, 04:14 PM - Thread Starter
dsomerton's Avatar
Boy I love my UTV but just recently I noticed the progress bar doesnt display or the display at the top corner when I FW or RW but it still goes FW and RW. Can anybody know what could be causing this?
dsomerton is offline
post #2 of 5 Old 10-19-2005, 09:18 PM
teejay44's Avatar
Is your HD upgraded?
MIne sometimes does that since I upgaded to a 160 GB .
It seems to happen when
the drive is filled up.
But always comes back.
teejay44 is offline
post #3 of 5 Old 10-19-2005, 09:52 PM
LongRufus's Avatar
Unplug the UTV for 30 seconds and it will go back to normal.
LongRufus is offline
post #4 of 5 Old 10-19-2005, 11:21 PM
Spiff's Avatar
Experienced the same awhile back. The hard reboot (unplugged for a bit) did the job. Think it has only happened a couple times over the past 3 or 4 years or so...
Spiff is offline
post #5 of 5 Old 10-20-2005, 07:50 AM - Thread Starter
dsomerton's Avatar
Yep that did the job. matter of fact after I post my first post I went ahead and unplugged it for 5 minutes. so thanks for the reply anyways.
Closed Thread Microsoft UltimateTV PVR
