Screen on the guide- help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-13-2007, 12:03 PM - Thread Starter
lowjones's Avatar
For whatever reason the small screen that is displayed when I am looking at the guide is now on the upper left. I swear it used to be on the upper right. How do I change so it is on the right again? Thanks...
lowjones is offline
post #2 of 6 Old 04-13-2007, 01:20 PM
RangerDoc's Avatar
Highlight/selct the screen and use the arrow keys.
RangerDoc is offline
post #3 of 6 Old 04-13-2007, 01:35 PM - Thread Starter
lowjones's Avatar
Hi,
I was able to highlight it but arrows do nothing....
lowjones is offline
post #4 of 6 Old 04-13-2007, 04:47 PM
csgo's Avatar
It's on the upper left on all my boxes. I don't remember previous software versions, but I think it's been on the top left all along.
csgo is offline
post #5 of 6 Old 04-14-2007, 11:56 AM
lgodave's Avatar
I know for PIP you can select and move the PIP window to the four corners in 3.7.
As for Guide and My Show windows... the preview window may be on either right or left sides depending on the specific menu screen but for the program guide it is on the upper left I believe. Those can't be changed using the GUI as I under stand it.
I would LOVE if a preview window could be inserted in places were it currently isn't (but could be) just because they didn't "enable" or make room for it. The search menu comes to mind. Limited Searches can be done with a preview window (partially obscured by the "search" window)... Preview audio can be heard while doing full searches but no PIP (or can you? I haven't tried keeping a PIP open in "search mode" recently).
lgodave is offline
post #6 of 6 Old 04-29-2007, 12:39 AM
zcarguy's Avatar
while on the guide it is on the left
while in my shows it is on the right
it doesnt move.
only pip moves
Z
zcarguy is offline
Reply Microsoft UltimateTV PVR
