4K 60Hz, 4:4:4, 18 Gbps, HDMI Cable Tests - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #31 of 38 Old 11-30-2016, 09:30 AM
dunnar's Avatar
Quoted: 24 Post(s)
Originally Posted by dunnar View Post
Does anyone have any experience using this cable with an Xbox One S? I want to support 4k 60 Hz UHD and I'm looking to use the 40ft. Silverback S6 HDMI Cable between my Xbox and my Vizio M65.
For those interested, I purchased this 40ft. cable and it has worked flawlessly between my Xbox One S and Vizio M65-C1 (2015 model).
dunnar is offline
post #32 of 38 Old 12-06-2016, 04:29 AM
wildchild22's Avatar
Quoted: 29 Post(s)
Your tv does not support 4k@60hz 4:4:4 so almost any cable should work as it is not a 600mhz signal.
wildchild22 is offline
post #33 of 38 Old 12-06-2016, 06:12 AM
dunnar's Avatar
Quoted: 24 Post(s)
It does support 4k@60Hz, just not HDR. Does the Xbox adjust the signal before sending it to the TV, or does the TV downscale what the Xbox is sending? Also, I tried two Celerity cables and neither one worked without always unplugging and replugging the cable (I think it had something to do with the power, but they couldn't figure out how to make it work). Anyway, I am happy with this cable and my specific setup.
dunnar is offline
post #34 of 38 Old 12-14-2016, 10:05 AM
Desisuperman's Avatar
Quoted: 33 Post(s)
Interesting topic. Was looking at purchasing 4 35ft cables for a new set up but it looks like these can be problematic.
Can the vendor or somebody else confirm that at 35ft these will operate at 4k@60hz 4:4:4 chroma without issue.
My current setup is a Samsung unjs8500 with an Xbox one S.
I'm moving the Xbox One S to another TV samsung 65ks9000. I need the 35ft wires to run in wall so I need to make sure I do it right the first time.
How can I test these using my current setup (js8500) with my Xbox One S to ensure I'm getting full bandwith and 4:4:4 Chroma ?
Desisuperman is offline
post #35 of 38 Old 12-29-2016, 02:34 PM
Quoted: 30 Post(s)
Liked: 9
I just received the 40' cable and hooked it up between my JVC projector and Marantz 7702MKII. It passes 4K signal with no issue. I'm using Samsung 8500 and Direct TV 4K genie as sources switched through the Marantz. I've gone through 4 other cables with no luck. Glad to have finally found something that worked.
ls1ssz is offline
post #36 of 38 Old 01-04-2017, 10:04 AM
Aquarian09's Avatar
Quoted: 66 Post(s)
It seems like Sewell Silverback S6 is also having issues with passing 4K@60 4:4:4 Chroma on long runs, just now read in their Sewell thread about this and there are few who claim that it failed at 30ft.
So now am back to purchasing Celerity Fiber HDMI (which was my first choice but thought about Sewell considering the price) it seems like thats the only one which passed all tests till now at 4K@60 4:4:4
Can someone confirm this once again whether Celerity satisfies the 4K@60 4:4:4 ?
Aquarian09 is offline
post #37 of 38 Old 01-09-2017, 12:55 PM
cpinfdp's Avatar
Liked: 0
Ha, that's funny. I have the 40' cable and have had no luck connecting a Marantz SR7010 to the my JVC DLA-550XR and getting it to pass full 4K at 60 with 4:4:4. I've gotten 30Hz to go from my PC no problem, but nothing higher.
I've also tried an Xbox One S. Both tests were done without and with the receiver in the circuit and no change. Confirmed no issues with shorter generic high speed cables (10 ft).
I haven't returned my cable, but are there any specifics you can give about settings that you were able to getting it working with?
I've tried 35 and 50 ft Mediabridge Ultra cables as well as other random cheaper cables. I'm still trying a few more before I settle on dropping the dough for the Celerity.
cpinfdp is offline
post #38 of 38 Old Today, 08:27 PM
davisnub's Avatar
Quoted: 139 Post(s)
Liked: 25
In the end, the sewell didn't work for me. Now I've been waiting months to try to return it and they aren't answering my emails!
davisnub is online now
Reply Sewell Direct – Connect Anything
