Any way to reboot FIOS DVR without unplugging it? - AVS Forum
post #1 of 4 Old 03-14-2008, 06:50 AM - Thread Starter
silverbullit's Avatar
It's difficult to reach behind the cable box to unplug it as its at the top of my closet. Is there another way to reboot it?
silverbullit is offline
post #2 of 4 Old 04-02-2008, 04:41 PM - Thread Starter
Anyone???
post #3 of 4 Old 04-03-2008, 06:17 AM
ncted's Avatar
I don't know anything about these in particular, but most STBs let you reset them from a menu option. Also most will reset if you hold down the power button for 5-10 seconds. YMMV.
Ted
ncted is offline
post #4 of 4 Old 04-03-2008, 08:52 AM - Thread Starter
Thanks I'll give that a try. It's such a PITA to reach behind the box and unplug it as its in the top of my coat closet.
Reply HDTV Recorders
User Tag List
